Author Topic: Mini tubs with coilover spring torque arm conversion  (Read 1035 times)
Ryoko
« on: November 19, 2021, 07:40:47 PM »
I'm getting way ahead of myself. But I was browsing thru my wish list and was looking at doing mini tubs for the rear. I was also considering converting to a coilover torque arm set up to allow for ride height adjustment and to control rear axle windup with the motor that's planned. The question I am concerned about is if I do go with the coilover/torque arm and mini tub combo, will I need to also relocate the trailing arm links? Or better still, what would be the largest rear tire I could run without having to move the trailing arms? (Would like to avoid hacking into the frame rails if possible.)
79T/Aman
Re: Mini tubs with coilover spring torque arm conversion
« Reply #1 on: January 18, 2022, 09:43:59 AM »
first what size tire do you want to run? we run 315s with leaf springs.
You didn't mention what torque arm you are referring to.
