Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Login
Register
TAC Tech
Electrical
1981 Tachometer Quit working HELP 😡
« previous
next »
Pages: [
1
Author
Topic: 1981 Tachometer Quit working HELP 😡 (Read 1010 times)
In Relentless Pursuit
EAST BOUND & DOWN !!!
on:
August 31, 2021, 05:37:54 PM »
The Tachometer quit working in my sons 81 Trans Am
..I cleaned all contacts plugged back in and nothing ..Pulled the tach wire from distributor turned key on used test night and no power cleaned those contacts and still nothing ..Anyone have any ideas? Thanks In Advance !
1980 Trans Am / T - Top / 400/ TH 350
1971 Esprit TA Clone W72 1972 Formula 68 350 HO
Re: 1981 Tachometer Quit working HELP 😡
Reply #1 on:
August 31, 2021, 06:41:45 PM »
The tach has a separate harness directly from the fuse box, I'm assuming you checked that connection as well.
Reply #2 on:
August 31, 2021, 07:24:07 PM »
Just the harness on the back of the cluster cleaned those connections ..Didn’t Think about it running to the fuse box I will check that tomorrow..Thank You
Last Edit: August 31, 2021, 09:35:24 PM by In Relentless Pursuit
Savage Larry
Reply #3 on:
September 01, 2021, 02:49:22 PM »
I have a small fuse inline with my tach wire on my '77 not sure if you have one but take a look in your engine compartment. That might be the problem
Jay
Calgary, AB
1977 4 speed W72
Reply #4 on:
September 04, 2021, 09:43:51 PM »
I pulled the dash took a wire hooked it up to Tach on the distributor to Tach on back of cluster & took another wire ran it from batter to back
Of cluster to where it says batter ..Started up the car and Tach didn’t work , so would it be fair to say the Tach is no good?
Reply #4 on:
Reply #5 on:
September 05, 2021, 05:43:33 AM »
One final thing to check is the ground, if I remember correctly the tach had it's own ground connection (but can't say for sure).
Reply #6 on:
September 05, 2021, 12:14:06 PM »
Be sure the tach has a good ground.
Reply #7 on:
September 06, 2021, 02:04:24 PM »
They ground through the cluster, so do what can there. My guess would be that it's bad, but i suppose it's hard to be sure. I used to bench test them using a running vehicle. Crude but effective enough for me.
Reply #8 on:
September 06, 2021, 10:22:25 PM »
I looked for about two hours for the ground never found it ..Then read that it was griund through the cluster …Guess I will start looking for a cluster or Tach ..Noticed my Oil gauge was pegged to the right also ..Might just be sending unit ?
Reply #8 on:
Pages: [
1
« previous
next »
TAC Tech
Electrical
