Author Topic: Ever run borla single muffler  (Read 827 times)
itllfly
« on: August 21, 2021, 08:57:56 PM »
I have a stock exhaust single muffler on my 78.  Anyone running a single borla?  If so would you recommend one
Re: Ever run borla single muffler
« Reply #1 on: August 22, 2021, 05:43:34 AM »
A friend of mine is running one on his 72 Formula.  Sounds excellent.  I'm running a Flow Master single.  Only issue I had is that the trunk pan gets super hot.  I have a duel heat shield that was sprayed with Lizard skin around the muffler.  Still got hot so I used the wrap to isolate the trunk and fuel tank from the muffler.  It still gets hot but at least you can touch the trunk pan for a  few seconds before burning your self.  If your car is not lowered I would go the traditional route.
https://www.summitracing.com/parts/flo-51022
https://www.summitracing.com/parts/hsp-175102
« Last Edit: August 22, 2021, 05:46:25 AM by 81Blackbird »
