Author Topic: Speedo Cable  (Read 1327 times)
Speedo Cable
« on: August 17, 2021, 06:42:48 AM »
There was a question posted on the py forum about 2 piece speedo cables for 78/79 4 speed cars. Not much other info.  I have a 79 4 sp but it came to me in pieces so I have no idea on this part. Could it be in 2 pieces as a way to deal with the removal of the cruise control servo?
    • Mark's Cars Inc.
Re: Speedo Cable
« Reply #1 on: August 17, 2021, 07:13:38 AM »
Mine was only piece on my ‘79 400.  Direct from speedo to transmission.  Two piece would be if you have cruise control.
Mark's Cars Inc.
https://markscarsinc.com
Re: Speedo Cable
« Reply #2 on: August 17, 2021, 10:37:42 AM »
They're talking about the cars using a calibration gearbox and in those cases, with a 4 speed, they used little short cable and the box wasn't screwed directly into the transmission.  Lo and behold, I found a source of new cables for that setup:
https://www.ebay.com/itm/281117655486
Re: Speedo Cable
« Reply #3 on: August 17, 2021, 04:48:40 PM »
Good work Joe, now the question is... What is a calibration gearbox?
Re: Speedo Cable
« Reply #4 on: August 17, 2021, 05:24:13 PM »
They used a lot of them, although it seems like they really weren't necessary.  If you look at the parts books they had multiple speedo gear ratio options for the same gear ratio and tire size.  They were made by Stewart Warner.  they were made to screw directly into the transmission, but the 4-speeds that had them, at least some I've seen, had a little short cable there instead.
Appearance is like this:
Re: Speedo Cable
Re: Speedo Cable
« Reply #5 on: August 18, 2021, 06:22:11 AM »
Very good. As a cross reference going back to the PY thread, there is a company Speedometercablesusa.com that has this stuff.
Re: Speedo Cable
« Reply #6 on: August 18, 2021, 06:39:54 AM »
Good info., thanks for sharing. Did not know of a calibration gearbox.
    • Mark's Cars Inc.
Re: Speedo Cable
« Reply #7 on: August 18, 2021, 07:24:35 AM »
This has eluded me.  Learn something new every day with these old cars.
Mark's Cars Inc.
Re: Speedo Cable
« Reply #8 on: August 18, 2021, 11:33:16 AM »
Going back a long time ago I recall many cars with manual transmissions had these. I never thought much about it but maybe it was necessary for certain rear axle ratios.
Re: Speedo Cable
« Reply #9 on: August 18, 2021, 07:56:50 PM »
They are.  Each one is a fixed ratio and there are a bunch of different ratios.
They were used on 1978 L78 automatics (2.56 axle), so due to that one application they're somewhat common.  They made a lot of those.  but in that case it was screwed directly to the transmission and the cables were just ordinary.
I never took one apart, but now that i think about it, I am so curious.  I wish I had.
Re: Speedo Cable
