Author Topic: BAD squeaking over any little bump - Coil Isolators?  (Read 1364 times)
78400stud34
« on: August 12, 2021, 03:57:11 PM »
I've replaced almost my entire front end suspension and put in lowering springs. Now, I'm suffering a BAD squeak over any bump in the road. Seems to be isolated to the drive side but it's driving me crazy. All grease fittings have been lubed, poly bushings/end links have been greased per recommendations. I'm at a loss!
The next thing on my list is to take out the coil spring and ensure it's clocked correctly. My 78 did not come with coil isolators, but should I consider either greasing the coils OR installing isolators?
1978 Pontiac Trans Am 400 WS6
XE262 cam with hydraulic lifters
Pypes 2.5 X Pipe
Tribal Tubes Tri-Y headers
Functional Shaker with K&N filter
Bilstein and MOOG suspension
Current Project
Electric choke conversion
Sourcing a rear end other than 2.56's
Re: BAD squeaking over any little bump - Coil Isolators?
« Reply #1 on: August 12, 2021, 05:13:03 PM »
Can you duplicate the noise with the car parked and bouncing the front nose? I have never heard of anyone having to grease springs. Is it possible the noise is coming from the upper or lower control arm bushings. Since you just had the entire front end apart is everything tight? More than once after a front end alignment I have seen lose bolts on the upper control arms where the shims are drawn to the subframe.
78400stud34
« Reply #2 on: August 12, 2021, 05:52:01 PM »
Yes, I can duplicate with bouncing the nose... control arms could be a culprit. Probably the only thing I haven't checked... as it's the only things I haven't gotten to yet. Will go out and check
« Last Edit: August 12, 2021, 06:14:50 PM by 78400stud34 »
Pypes 2.5 X Pipe
Current Project
« Reply #3 on: August 12, 2021, 08:44:37 PM »
They would be the first thing I'd check. Are they rubber or poly? Even when greased, poly seems to find a way to squeak there as they are used in a twisting, rotating motion rather than a compression style which it is more suited.
Warren Seale
« Reply #4 on: August 13, 2021, 08:04:24 AM »
What I do in a case like this is to soak down the suspected bushings one at a time with penetrating oil.  When the squeak stop then you found the culprit.
79 T/A,WS6,403,A3
96 T/A,WS6(#1344),M6
72 442,W30,A3
