Author Topic: 403 olds in 79 Trans Am  (Read 1004 times)
adicks1
« on: August 02, 2021, 01:17:54 PM »
Looking for any advice on whether to rebuild or replace engine probably main bearing or cam bearings are bad. Also does anyone have a good mechanic for this project in western NC or Eastern TN
Re: 403 olds in 79 Trans Am
« Reply #1 on: August 02, 2021, 08:18:07 PM »
Depends...what the issue turns out to be and if it is suitable as a core. Original engine always good to keep if it is, likewise original type of engine is easiest to swap if you already have the brackets, accessories, air cleaner and shaker, wiring and plumbing to suit that type. Depends what replacement options are around. I'd be looking to freshen up what you have based on what's typically required. Easy to double the hp but look stock during a simple 403 rebuild.
Maxthe222
« Reply #2 on: August 03, 2021, 07:06:12 PM »
Keep original
1987 T/A GTA L98
1979 T/A Y84 WS6
1979 F/A W72 WS6
1978 T/A L80 WS6
1978 Formula L80 W50
1971 Formula 400 4-Speed
