Author Topic: Pre heat shroud 71 455 HO  (Read 1199 times)
JAL71 TA
« on: July 25, 2021, 02:12:05 PM »
Guys, anyone have a picture of the correct heat shround from exhaust manifold to carb?
I see one listed on Firebird Central but I am not sure its correct? Any help is appreciated.
69TA
71TA 455
69GTO
71455formula
Re: Pre heat shroud 71 455 HO
« Reply #1 on: July 26, 2021, 09:22:49 AM »
I should be able to get you one this afternoon. It's at the house and I'm at work.  :cry: :cry: :cry:
pancho400cid
  • Viva los PONCHOS!
« Reply #2 on: July 26, 2021, 11:21:26 AM »
I found the pic below off the web.  Not my car (unfortunately) but looks like a nice resto so hopefully the exhaust shroud is correct?
Some pics on the web look stamped like the one I posted.  The firebird central shroud looks more "fabricated" to me, with sharper corners, etc. but I can't say which is "right" or maybe both are  (more than one supplier to Pontiac, etc.)?
It will be interesting to see pics from 71455formula.
JAL71 TA
« Reply #3 on: July 28, 2021, 07:42:02 PM »
Thanks!!!
69TA
71TA 455
69GTO
71455formula
« Reply #4 on: July 30, 2021, 06:24:30 PM »
I haven't forgotten you. Been a busy week. You are looking for the one that goes over the exhaust manifolds?
JAL71 TA
« Reply #5 on: August 01, 2021, 07:01:34 PM »
Yes sir, drivers side pre heat ehaust to the base of the air cleaner.
69TA
71TA 455
69GTO
71455formula
« Reply #6 on: August 03, 2021, 08:30:56 PM »
I'm sorry. I cannot locate my heat shield. I never installed mine. It is the same one as a ram air 4. Gto's use the same one. If i recall the ra4/455HO heat shields had sharper corners than the standard ones and ra3 motors. I'll keep looking for it and get a good pic of one. Once again I am truly sorry for the delay in getting back with you on this. I'm in the beginning stages of moving at the end of the month.
Ben
JAL71 TA
« Reply #7 on: August 07, 2021, 07:33:56 AM »
Hey no worries, I just appreciate the follow up.
69TA
71TA 455
69GTO
