I thought to post up my post of my LS Swap that I started in 2013, in case it helps anyone attempting something similar.
Now please remember, I'm out in South Africa and an IT guy by trade. So the build was done with a very limited budget and it was a huge learning curve too. Unfortunately out here parts are not to easy to come by and extremely expensive to bring in. At the time, the LS thing here locally was also pretty rare. It's picked up momentum.
The aim of the build was to freshen up the Trans Am and turn it into a cruiser, yet leave it as close as possible to original.
A quick recap was that it started off when I purchased it in 2006 with a Chevy 350....then upgraded it to a 383 after it ran bearings. A few years later I landed a LS2 in pieces which I was going to fit, but landed up buying a accident damaged Chevy with an LS1 and moved it all across into the Trans Am.
Here's my thread
The time has come. My Trans Am has had its final drive with a 383ci motor to the workshop where it will over the next few months. It will be receiving a little heart surgery. The 383 has been sold off to a good friend who will be using it in his 36 Chevy and in its place my Trans Am will have a 6.0l LS2 motor.
Last night I started removing everything for the motor to be pulled on Saturday morning.
Since the conversion from 350 to 383 a few years back, I have had no issues with the motor. It's ran without skipping a beat. I’ve managed to cover about 12k km with it in the last 4 or 5 years. The 383 was a HUGE step up from the old 350. The difference the torque made to the drivability of the car was immense, and suited the car perfectly. The only thing I hated was the 3 Speed Auto. Once upon a time I decided it would be a great idea to have a shift kit fitted to it. This turned out to be a bad idea as shifting from 1st to 2nd was so hard it felt like you dropped the diff and snapped your neck every single time it changed up. It was great for when you were giving it some stick but when just cruising it was a royal pain in the neck.
On a recent trip down to Durbs with it, I had the bright idea that the 3speed auto needed to be chucked out as sitting on the highway at 120kph the motor was spinning at almost 3500rpm which killed fuel consumption and made it quite uncomfortable. Long story short, I sat with the boys at the workshop discussing fitting a gearbox with an overdrive that I had purchased and somehow am now doing a LS2 with a 6 Speed Manual gearbox project!
So…the plan at the end of the day, with a very tight and limited budget, is to have my Trans Am kitted out with slightly more modern technology. A more Pro-Street version of a Trans Am. From the outside, I want to make it look as standard as possible but underneath it must be slightly more up to date with the times. I have already purchased a LS2 and a brand new 6 Speed Lumina gearbox.
The LS2 will be fitted with fuel injection. I still need to source coil packs. It came with a Spitronics management system, but I’ve been told to rather try source an original GM system. I’m importing a set of wheels for it from the States, made by a company called Year One. They are a modern version of my original “snowflake” wheel, but just in 17x9 inch exactly the same as below.
From this
To this
This will allow me to fit a proper brake system to the car. I haven’t decided what brake setup to go with yet, but it will include a new booster, master cylinder, rotors up front and I will be doing a disc conversion on the rear axle too. The diff will be redone. It’s currently an open diff, which will be converted to a LS diff. Suspension wise, at the end of the day I would like to dump the leaf springs at the rear and have a proper coil over setup installed. This however…..at the moment is still in the “dream” part of the build as is the air con, but I’m hoping to eventually get this done.
Converting it to a manual is also going to be lots of fun. I’m going to need to source a pedal box and do something with the centre console. From what I’ve read on the web, it doesn’t seem I will need to do any sort of cutting to get the box to fit. Interior wise I may need to do some cutting on the centre console, but will tackle it when I get there. I’ve already sourced a Centre Force clutch for it, which apparently is quite decent.
The plan is also to have the car painted. I will be doing a lot of the prep work myself, slowly over the next few months to save on cost for the paint job. A friend of mine has his own paint booth and will be helping me out with the spray. The car will be kept black and gold, but this time, it will have the budgie on the bonnet
This is going to take a while, but I’m pretty amped for it. I’m going to miss not having my toy for now, and am frightened as to how much work and money is going to into this…..but I do love my TA and the end result will be worth it.
Wish me luck!
