Author Topic: lifting an old sbc?  (Read 1136 times)
Vroom_vroom
  • ka-kawwww
    • my build thread
lifting an old sbc?
« on: May 12, 2021, 01:24:34 PM »
ran into an odd question and based on the collective knowledge i thought id ask.
 i have an old sbc im getting ready to yank but it has no accessory holes in the heads. how bad of an idea is it to bolt the chain to a intake bolt? (no intake on it) it has a t10 attached to it as well.
'19 Silverado 3500
'15 terrain
langss
Re: lifting an old sbc?
« Reply #1 on: May 12, 2021, 06:38:38 PM »
Why Not. Probably been done a Million Times before whether under a shade tree or in a comfy garage.
SoupMan
« Reply #2 on: May 12, 2021, 08:23:33 PM »
Vroom_vroom
  • ka-kawwww
    • my build thread
« Reply #3 on: May 13, 2021, 02:53:20 AM »
i have one i have used before, intake is already off and its not a carb intake anyhow. intake or bell housing/ water pump may be a safer alternative curious to see the clutch that came apart.
'19 Silverado 3500
'15 terrain
DeVilliers
« Reply #4 on: May 27, 2021, 03:47:19 AM »
I took my sbc out and put back in using the bolts on the exhaust headers. I was to scared to use the intake bolt.
1979 Trans Am
