Author Topic: Power steering and alternator bracket set up  (Read 1036 times)
Poncho461
« on: May 11, 2021, 01:40:54 AM »
Does anyone know if the factory power steering and alternator brackets will work on a set of KRE aluminum heads? Thanks.
1978 Pontiac Trans Am 461 w/KRE heads, full roller engine making 592hp/610ft lbs on pump gas w/Holley Sniper efi. 2004r built. Factory rear end w/3.23 gears.
Savage Larry
Re: Power steering and alternator bracket set up
« Reply #1 on: May 11, 2021, 08:43:10 AM »
Yes they do
Jay
Calgary, AB
1977 4 speed W72
Poncho461
« Reply #2 on: May 11, 2021, 02:49:14 PM »
Ok thanks for the reply. I just need to try harder to line it all up then is what your saying which is ok because I really dont want to spend the money on an aftermarket set up right now. Ha! Thanks again.
Savage Larry
« Reply #3 on: May 11, 2021, 08:41:40 PM »
I should clarify, are you running the D-port heads? I believe they have race heads and the d-port which essentially bolt onto a stock engine. I am running the d-port ones.
Jay
Calgary, AB
1977 4 speed W72
Poncho461
« Reply #4 on: May 13, 2021, 07:13:34 PM »
Yes I am running the D port heads. I was able to get everything hooked up it was just a matter of figuring out what water pump bolts I needed to use for the alternator bracket.
