Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Login
Register
TAC Tech
Electrical
Fuel sending unit wiring
« previous
next »
Pages: [
1
Author
Topic: Fuel sending unit wiring (Read 1193 times)
Avalanche
Forum Member
on:
April 10, 2021, 12:28:37 PM »
Anyone got a schematic for the wiring from the fuel tank/sender forward? My gauge is not working.
Re: Fuel sending unit wiring
Reply #1 on:
April 10, 2021, 03:47:18 PM »
Not much to it. One wire from the sender to the gauge. Then the gauge gets power from a pink wire. You can test for power at the pink wire. If it has it, try grounding the other terminal and see if the gauge reacts.
Reply #2 on:
April 11, 2021, 02:44:24 AM »
Is the gauge pegged right off the face to the right? If there is a good grounding it will pull back onto the dial. Check the ground wire under the rear panel, clean the metal and refit, easy thing to check.
Avalanche
Forum Member
Reply #3 on:
April 11, 2021, 01:28:47 PM »
Hi all - it's stuck in the middle. I disconnect the wire near the tank and the gauge goes past full, which from I read is right - I just have to ground it now to insure it goes to empty. If that happens it seems I have an issue with the sending unit. Right?
Reply #4 on:
April 11, 2021, 03:08:10 PM »
Avalanche,
You are correct. Second generation Firebirds have 90 ohm sending units. 90 ohms should read a full tank and 0 ohms = empty.
As Wallington mentioned, there is a ground wire from the sending unit on top of the tank that runs to rear panel area right behind the tank. Not far from where the filler tube is located. If the ground is broken, dirty or corroded it could cause a high reading on the gage.
Reply #4 on:
Reply #5 on:
April 11, 2021, 05:50:55 PM »
That seems to indicate it is grounded and gauge working, how accurately is hard to say. If you don't know the history of the sender unit then it is probably overdue for dropping the tank anyway, new fuel hoses, pickup sock, maybe a buildsheet.
Reply #6 on:
April 12, 2021, 07:12:42 AM »
You can guess where this is going: Zero ohms is empty. The gauge has to be accurate at "E" and that's how they did it. If you can't get the gauge to show E then it's the gauge. If the gauge does show E with that wire grounded, then evidently you don't have zero ohms in the tank, for whatever reasons that could be.
The gauges do go bad somehow.
1971 Esprit TA Clone W72 1972 Formula 68 350 HO
Reply #7 on:
May 01, 2021, 05:22:17 AM »
It's sounds to me that your float is clogged and stuck. The gauge and wiring is fine if you disconnected the ground and the gauge dropped.
Reply #7 on:
Pages: [
1
« previous
next »
TAC Tech
Electrical
