Author Topic: Mounting Aftermarket Gauges  (Read 1725 times)
« on: April 04, 2021, 11:54:03 AM »
Can I just mount aftermarket gauges in the brushed aluminum panel on the dash?  Or do I need some kind of backing plate or inner mount
structure?
Is there anyone here that has replaced their gauges?
JJ 109
Re: Mounting Aftermarket Gauges
« Reply #1 on: April 04, 2021, 07:08:17 PM »
I made a new face plate which is thicker, ~1\8” but I think the stock would be ok too.
https://photos.app.goo.gl/LhV8h5yTHkk5b2PU8
« Last Edit: April 05, 2021, 09:01:12 AM by JJ 109 »
JJ
76 pro tour project
Twin Turbo LS1
Detroit
Gene-73
« Reply #2 on: April 04, 2021, 09:06:17 PM »
I mounted my aftermarket gauges the same way the factory did it, which is fastened to the dash frame behind the face plate. I used VDO gauges which have a shallow flat bezel which hides behind the factory bezels that are mounted on the face plate.
This way I didn't have to deal with wires hanging off the faceplate. Probably wouldn't work with gauges that have a thicker bezel though.
Gene
« Reply #3 on: April 05, 2021, 11:51:56 AM »
JJ 109, your face plate looks great and you have an integrated push button start to boot!  I am going to install the proximity locks and PB start this summer.
Gene, I agree that is the best way to do it with the wiring/gauges independent.  It is hard to see and your gauges look look like they were made that way.  I am going to see if I can do that with the Autometer gauges.
Thanks for the info, guys.
« Last Edit: April 05, 2021, 12:32:30 PM by MNBob »
