Author Topic: Needed: Machine shop in Phoenix, az  (Read 1228 times)
TammyTA
« on: March 29, 2021, 07:47:22 AM »
As the subject says, I'm looking for a good machine shop(s) in Phx.  Here's my sad story:
Took my block in and had it cleaned, mag'd, align bored, decked, bored...  It took a while to get it together, but shortly after, we noticed crud in the radiator & water in the oil. The car has never been on the road & is still on jack stands.  1st thought was head gasket...   Did a leak down and also found that the valves were leaking despite a complete valve job.  Hand lapped the valves & installed new Perma torque gaskets.  Redid the leak down & still have a leak.  Off come the heads again & was able to get my phone down into #7 (where I couldn't see) and I've got a cracked cylinder...  Found another in #2.  Lots of time & $$ waisted.  :-(  :sad:
So, I need a trustworthy machine shop(s) to determine if the block is worth saving and can check the heads for leaks.
Thanks,
Keith
