Author Topic: PTFB spring hanger measurements  (Read 1804 times)
« on: March 29, 2021, 03:27:58 AM »
Does anyone have the measurements of a PTFB rear spring hanger? I nee thw hole to hole measurement of the farthest space ones. I cut mine down planning to only use the lowest setting but my rear is too low now. I will have to make a new set.
    • Mark's Cars Inc.
Mark's Cars Inc.
https://markscarsinc.com
Re: PTFB spring hanger measurements
« Reply #2 on: March 29, 2021, 10:18:08 AM »
Thanks.... I was hoping someone had a kit they haven't installed yet or one installed they could measure for me.
    • Mark's Cars Inc.
« Reply #3 on: March 29, 2021, 12:11:42 PM »
They’re about 1”-1.5” out.  I would not be overly concerned about getting it the same to the .001” measurement.  The main thing is getting your desired stance and make sure whatever distance you create is consistent on each shackle plate you make. Also make sure to check your pinion angle afterwards.
Mark's Cars Inc.
