Author Topic: 79 not starting  (Read 1711 times)
DeVilliers
79 not starting
« on: March 26, 2021, 01:48:44 PM »
Hi all,
Need some help please
My 79 with the 350 Chevy motor won't start. The motor swings, but there's not enough spark.
I did a few measurements. First ignition switch gives 11.5v  to the coil. When starting, the motor swings, and the voltage drops to 8v
Now I understand that there should/could be voltage drop because of the resistor wire. As I understand there should be a bypass when cranking the motor in order to get 12v.
Now I can't figure out where I missed this wire or where it's located.
What am I missing?
1979 Trans Am
Re: 79 not starting
« Reply #1 on: March 26, 2021, 05:56:42 PM »
If I had to guess I would think that your wires from the battery to the starter and/or the ground wire is rusted or not making good contact. I would start at the battery and make sure your cables are good and the connection at the post is solid. Next I would check the grounds, if all checks out it should start by jumping it.
DeVilliers
Re: 79 not starting
« Reply #2 on: March 29, 2021, 01:40:46 AM »
Thanks Jack!
It's alive!. Cleaned off the ground wire again and fiddled with the starter ground, retighten. Then Bam!
1979 Trans Am
Re: 79 not starting
