Author Topic: Tires for a 4th gen  (Read 2166 times)
Tires for a 4th gen
« on: March 25, 2021, 12:18:20 PM »
Thinking about new tires for my 02.  Currently has 275/40ZR17s. I like the look so I’ll probably stay with the same.  Any recommendations for make/model of tire?  Just a driver/cruiser driven almost exclusively in good weather.  Look for decent wear, low road noise, and reasonable price.   Thanks
    • Mark's Cars Inc.
Re: Tires for a 4th gen
« Reply #1 on: March 25, 2021, 09:43:23 PM »
All depends on what you want to do.
On my '98 Trans Am, I had good experience with BFG Comp 2 A/S (All season) tires but that's an all-season tire.
$141.99
https://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel=g-Force+COMP-2+A%2FS+PLUS&partnum=74WR7GFC2ASP&vehicleSearch=false&fromCompare1=yes
On my '79 I have the BFG Comp 2 Summer tire.  I have yet to drive on these so I can't give full analysis at the moment.
$184
https://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel=g-Force+Sport+COMP-2&partnum=74WR7GFSPC2&vehicleSearch=false&fromCompare1=yes
If you want a good performance street tire that has track potential, look into the Falken Azenis RT615K+.  This is the only 200TW treadwear tire available in 275/40-17.  You could take this and do autocross.
$180
https://www.tirerack.com/tires/tires.jsp?tireMake=Falken&tireModel=Azenis+RT615K%2B&partnum=74WR7RT615KP&vehicleSearch=false&fromCompare1=yes
Mark's Cars Inc.
https://markscarsinc.com
« Reply #2 on: March 27, 2021, 07:03:24 AM »
Thanks for your response.  The Falkens are probably too much towards performance for my use.  Although I don’t need an all-season they look good.  Especially for the price.  Thanks again.
71455formula
« Reply #3 on: April 01, 2021, 04:57:13 PM »
I'm currently running Firestone firehawks on my Formula. Decent tire. I'm gonna be going to the bfgoodrich g-force sport comp-2's later this year. Not cause they're bad tires by no means. Their over 5 years old now and I'm looking for a more aggressive tire.
BAD2000TA
« Reply #4 on: April 16, 2021, 01:12:19 PM »
I run the Firehawks on my '01 Trans Am. It has good grip, last pretty long and rides nice.
1980 Trans Am Y84 SE, WS6, 455, Sniper EFI, T-tops
2001 Trans Am WS6, 6-speed, Stroked LS6 (383), Custom Comp Cam, LS6 heads, Strange 60
"That's an attention-getter"
Seven
« Reply #5 on: April 16, 2021, 07:06:57 PM »
Also recommend Firestone Firehawk Indy 500.
Great handling and supple ride.
LT4 Firehawk
1979 Y84 T-top Delete
1972 Esprit 455 HO
Re: Tires for a 4th gen32psi.
« Reply #6 on: May 28, 2021, 07:51:25 PM »
I bought a set of the BFG g-force comp2 a/s for car.  The tire dealer inflated them to ~32 psi.  Seems low to me.  The max pressure on the sidewall says “51 psi”.  I thinking they should probably be at least 40psi.  What do you guys run?
71455formula
« Reply #7 on: May 28, 2021, 09:04:20 PM »
On the 98-02 Ws6 cars with 17x9.5s should be 30-32psi. There is a sticker in the door jam that tells you the tire pressure recommended. 40psi I think will be too much. Especially when the tire starts warming up and the pressure increases. You'll start riding more on the center of the tread. Hope this helps.
