Water PumpI came out one morning and noticed a couple of drops of coolant on the top of the water pump. Upon further inspection, the area on top of the pump shaft was discolored (see picture). As much as I wanted to ignore this, I need to keep the Pontiac engine running and in good condition. I started to disassemble and the inside of the water pump pulley was filled with gunk (see picture) so maybe this had leaked for awhile.
After the old pump was off, I observed rust on the inside of the housing (aluminum), the divider plate, and the sleeves. The bearing in the old pump was definitely bad. Fortunately, the housing was in good shape with no heat stress cracking. The right sleeve came out ok, but the left one was stuck in the housing and took some effort to remove. There is a gasket in the front of the sleeves and these had deteriorated to complete goo.
I ordered a new Milodon aluminum high flow water pump, a stainless steel divider plate, and stainless steel sleeves (see photo). I made a couple of 5/16 stainless steel pins by cutting off bolts (see photo) and used these to mount everything together. The torque spec was 15 ft.-lbs. but after a couple of heat/cool cycles, i had to retorque.
I made the rookie mistake of throwing in the coolant and just starting in the engine without thinking about it. Of course, it hot pocketed on me and spit a bunch of new coolant out onto the floor. After this, I was much more careful, added coolant and just brought up the engine to temperature, shut it off, cooled and repeated. I could tell this was working as it was drawing the coolant into the engine.
Old Water Pump Stained
Gunk On Pulley
New SS Divider and Sleeves
Small Amount of Sealant On Surfaces
Fitting New Pump with Pins For Holding
Cleaned and Painted Pulley
Completed Install
