Author Topic: Throttle bracket  (Read 2282 times)
Throttle bracket
« on: March 04, 2021, 09:28:42 AM »
Specs: 81 TA running a 73 400 with the eldelbrock alum manifold and Rochester carb. Cannot for the life of me find the correct bracket for the throttle and lockdown cable. Any ideas?
Re: Throttle bracket
« Reply #1 on: March 05, 2021, 09:56:25 AM »
I don't use one, but just from google it looks like they recommended an adapter and the original bracket.  Edelbrock says the adapter 8015 was designed for 1968-71 Pontiacs, and 8014 for 72-76.  Both are in stock at Summit, but there's not much to them.  You could make your own if you have to.
I can imagine that your real problem would be finding a 1972-76 original bracket.  Is that what you're really missing?
    • Laboratory Fourteen
« Reply #2 on: March 05, 2021, 08:11:48 PM »
I made a "riser" that fits under the original bracket. The aftermarket brackets (at that time) were crappy flexible chrome plated junk.
Fbird
« Reply #3 on: March 07, 2021, 08:15:44 AM »
have always had luck just hacking up the originals and adapt as needed as all you really want is the "square" that the cables snap into.
67 Firebird
« Reply #4 on: March 07, 2021, 09:53:04 AM »
No need to hack if you make a riser.
