2020-B2-5
Author Topic: Overdrive with a 403  (Read 147 times)
General Mopars
      • Photobucket Album of all my Trans Ams
« on: September 13, 2020, 10:32:40 AM »
So, I was driving a very nice IROC yesterday, and of course began comparing it with a Second Gen. The most noticeable difference is the fourth gear the automatic transmission has.
I'm currently having a Holley Sniper EFI system installed and of course the next logical upgrade would be an overdrive. I had toyed with the idea years ago, but ultimately dismissed it because my transmission is fine, so why mess with it and open up a can of worms?
I searched a bit, and it seems like a 200 4R is preferred over a 700 R4. Is there a general consensus here? Is it better to just to an (expensive) Gear Vendors unit? Obviously it would need to bolt up to a 403. Does the EFI conversion play into it either way? FWIW, this is not a race car, I'd just like to drop the RPM on the highway.
"It takes a tough man to sell a screaming chicken."
Re: Overdrive with a 403
« Reply #1 on: September 13, 2020, 10:38:40 AM »
Your existing rear gear will also depend if suitable or not, select something better.
General Mopars
« Reply #2 on: September 13, 2020, 10:59:05 AM »
I think I have a 3.08 or 3.23.
tribute
« Reply #3 on: September 13, 2020, 12:25:21 PM »
your rpms will be extremely low with that rear gear.  I switched to 3.73s with my 2004r and while much quicker off the line still pulls pretty low rpms on the highway.  I wouldn't go less then 3.42 with the overdrive.  Many will tell you the 700s are stronger but you will have to get an adaptor and get a shorter driveshaft or shorten yours.  The gearvendors are amazing but really expensive.  I wanted simplicity so I went with the 2004r but it does have some troubles with the extra power I am putting down (425hp/496torque) with my 403.  Most shops work with the 700s and will steer you towards them but there are builders that can make your 200 stout.  Is your engine stock?
« Reply #4 on: September 13, 2020, 02:28:02 PM »
It may not matter but my car has 2.73s with a 4L60E (LS swap). The car I pulled the engine and trans from (98TA) also had the 2.73s.  It does have low rpms, at 55 I'm putting at 1500 rpms. J have plenty of power and I'm sure 3.73s would make it even quicker but the 2.73s work.
General Mopars
« Reply #5 on: September 13, 2020, 02:51:06 PM »
Other than the sniper EFI that it will soon have and dual exhaust sans cats, it is stock. My other '79 (the Mayan Red car) has a 2.41 rear and honestly, I love it.
Fbird
« Reply #6 on: September 16, 2020, 07:21:01 AM »
its just $$$$$
obviously several ways to get there...each with it's own issues.
2004r BOLT IN ...ish MUST be built to handle POWER = $$$ because stock...it will die.
700r4 ..adapter plate, driveshaft,...stock will live...just not great. The 3.00 first gear is DEEP
Vebdors OD.... $$$$ driveshaft VIBRATION concerns due to excessive shortening of d-shaft ..makes the u-joints ..unhappy
all work...pick your pioson.
67 Firebird
