2020-B2-3
Author Topic: New center cap loose  (Read 410 times)
itllfly
« on: November 08, 2019, 06:06:01 PM »
Bought new gm licensed caps uncomfortable with the looseness  have bent tabs to point hard to pull off yet and turn with hand.   Should this stay on
Mac
Re: New center cap loose
« Reply #1 on: November 08, 2019, 06:40:12 PM »
Put a small amount of silicone in two or three places around the cap.
The Never Ending Punch List!
allenga
« Reply #2 on: November 08, 2019, 07:47:21 PM »
I complained to Ames and the supplier is retooling.  Send the defects back.
1977 Trans Am, stock 400 W72, auto.
allenga
« Reply #3 on: November 08, 2019, 07:49:31 PM »
What I have done instead is buy used ones.  Take them to a metal polish shop and have them polished.  Then just buy new bird emblems.  Then you have a brand new used factory center cap, fits perfect.  Cheaper than aftermarket.
« Reply #4 on: November 09, 2019, 02:12:02 AM »
Imagine if the supplier actually was retooling. Yes, bend until firm, dob of silicone.
winks79
« Reply #5 on: November 10, 2019, 08:38:44 AM »
The stainless caps turning is not an issue. As long as you can not pull them off you will be fine. If you have bent the tabs back a little that is all you need. Just for you info, when these cars were new you could turn them by hand. The plastic ones on the the other hand are junk IMO. If you ever use them, you had better use some silicone, as stated, in spots around the inside of the cap. Even if you have the metal retainer that goes with the plastic caps that is suppose to help, it doesn't. The round stainless caps are the best.
« Last Edit: November 10, 2019, 08:42:58 AM by winks79 »
Chad
« Reply #6 on: November 10, 2019, 09:02:54 AM »
I bought a set from Ames a few years ago. Yes, once they seat into place they seem loose, however if I remember correctly (theres a good chance I am not) there was a slight groove in the wheel where the cap registers. All 4 are still there after many a miles driven down the road. I did not bend any tabs and did not use silicone.
