Author Topic: 305  (Read 184 times)
swany6mm
305
« on: July 05, 2019, 06:10:25 PM »
Hey all. I picked up a 77 Esprit with the Chevy 305 in it. Barn find I guess (as in, it was stored in a barn since 1992). She runs, but am doing some major tune up work. Right now, I'm fighting with finding information on the 305 so I can set the carb idle (2bbl Rochester) - Not sure what RPM/Vacuum - I can find all kinds of information all day long for Pony blocks, but the only 305 info I can find is all related to Chevy cars'n'trucks. Can anyone confirm the settings for a '77 Camaro will match up for the 'Bird, or were they different?
Re: 305
« Reply #1 on: July 05, 2019, 07:01:37 PM »
I’m PRETTY sure I have it in a manual at home but I’m 450-some mile from there for the next ten days. If someone doesn’t find it by then I’ll see if I can.
oldskool
Re: 305
« Reply #2 on: July 05, 2019, 08:33:50 PM »
I'm not a Chevy guy. But why would the same 305 engine be any different in a Camaro than it would be in a Bird ?
Re: 305
« Reply #3 on: July 05, 2019, 10:00:58 PM »
Wouldn't think so, the engines like that are generally complete and running before they are assigned to a body, unless requiring special brackets for non-Chev use.
I'll check my 77 Service manual shortly.
swany6mm
Re: 305
« Reply #4 on: July 05, 2019, 10:51:11 PM »
I would think everything would be the same, thinking all the bits'n'pieces under the hood would all be the same - But, not being a Chevy guy either, I don't know. Was hoping someone had experience with a 305 that was in a 'Bird ;) and could confirm before I just "ass"umed
Re: 305
Re: 305
« Reply #5 on: July 05, 2019, 11:19:16 PM »
Assume the emissions sticker is no longer there? Possibly the AU code, for 305 Auto and Manual, 2BB used across GM line.
Ok the 1977 Service manual info is scattered over several pages.....but this should cover it.
https://i.ebayimg.com/images/g/4RIAAOxyuCJRfpXq/s-l1600.jpg
« Last Edit: July 05, 2019, 11:22:46 PM by Aus78Formula »
swany6mm
Re: 305
« Reply #6 on: July 06, 2019, 09:21:27 PM »
Yeah, lots of the decals are gone. Aus78, you're brilliant! Thank you man. That is EXACTLY what I was looking for. As of now, I'm idling too fast and timing isn't right. And she's purring lol. Can't wait to see how she runs once it's dialed in right.
Again, thank you. VERY much appreciated :)
Re: 305
« Reply #7 on: July 07, 2019, 01:00:18 AM »
All good, I took the lazy way out of getting all the info in one spot!
swany6mm
Re: 305
« Reply #8 on: July 08, 2019, 10:36:07 PM »
Quick note for you Aus. After getting her idle set and timed right (thanks again!), she's purrrring. Runs very very smooth. No hiccups or anything. Not bad for a car that sat since 1992 in a garage (new interior (kept the seats) - Didn't do anything with the engine other than rebuild the carb and put new valve seals on the heads.
Re: 305
« Reply #9 on: July 09, 2019, 07:03:40 AM »
Perfect, love a good result from minimal work. How it should be!
Re: 305
