Author Topic: Strengthen Instrument Bezel  (Read 143 times)
78TA_In87
« on: March 14, 2019, 11:07:36 PM »
My new gauges are designed where they can easily mount to the engine swirled instrument bezel.  For extra support (even though the new gauges are light), would adding a coat of fiberglass to it be an ok idea?  The only thing I think could be an issue is if that would make it too stiff, it it needs to flex a little to re-install.
PONTIAC - We (Did) Build EXCITEMENT!!
Re: Strengthen Instrument Bezel
« Reply #1 on: March 15, 2019, 01:15:57 AM »
Wouldn't bother, sounds like it would only do more harm than what it would possibly protect it from.
78TA_In87
« Reply #2 on: March 15, 2019, 03:54:18 AM »
In what way?
« Reply #3 on: March 15, 2019, 04:47:16 AM »
I would be afraid the glass will pull and bend/warp the panel.  It does shrink as it sets.
cyber104
« Reply #4 on: March 15, 2019, 05:38:44 AM »
I agree with Aus - not sure what value it would add - but if you want to give it a go I'd use West System Epoxy Resin since it is less likely to distort than Polyester resin.
1978 TA 4-Speed W72
78TA_In87
« Reply #5 on: March 15, 2019, 10:06:02 AM »
Well, I was just asking.  You didn't explain anything.
78TA_In87
« Reply #6 on: March 15, 2019, 10:07:10 AM »
Thanks.  That make sense.
« Reply #7 on: March 16, 2019, 06:19:14 AM »
I thought you were actually going to support it from the bezel... otherwise I don't see the value.
