Author Topic: No power steering unless rev engine  (Read 166 times)
JJ 109
« on: March 10, 2019, 09:35:29 AM »
Stock LS1 power steering pump with aftermarket Al reservoir. . New/reman gen 3 power steering box 2.5 turn.
When the car is idling, I have no power assist. If I rev the engine to ~2000 RPM,  I have assist.
Any thought where to start?
JJ
76 pro tour project
Twin Turbo LS1
Detroit
Re: No power steering unless rev engine
« Reply #1 on: March 10, 2019, 06:39:35 PM »
The belt isn't slipping, incorrect profile or worn tensioner?
nas t eh
« Reply #2 on: March 10, 2019, 06:54:47 PM »
Do you have the hoses hooked up in the correct direction?
current
73 T/A 4speed
past birds
75 T/A 455 4speed
75 T/A 400 4speed
JJ 109
« Reply #3 on: March 10, 2019, 08:16:37 PM »
Thanks. Belt is not slipping.
Hoses are different sizes so cannot invert them.
JJ
76 pro tour project
Twin Turbo LS1
Detroit
cyber104
« Reply #4 on: March 14, 2019, 05:36:20 AM »
Can you get a gauge on the high pressure line from the pump to the steering box?
My first guess is that the pump isn't generating enough pressure.
My second guess is that there is something wrong with the steering box or that the pair (pump/steering box) are mismatched.
But these are just guesses - you can either throw parts at it or diagnose properly with gauges.
1978 TA 4-Speed W72
« Reply #5 on: March 14, 2019, 06:03:54 AM »
How long has it been hooked up? It took a while for mine to bleed the air out. I just kept turning the wheel, lock to lock. If it's been hooked up and working for a while then then it sounds like the pump went.
JJ 109
« Reply #6 on: March 15, 2019, 08:14:11 AM »
Not long. Pretty sure all the air is out though. It makes a whining sound when there is air and it doesn’t now.
I’m leaning toward bad pump. Spoke to turn one and they thought the pressure valve is prob stuck.
Looks like I will be replacing the pump.
JJ
76 pro tour project
Twin Turbo LS1
Detroit
