2020-B1-2
Author Topic: Rostra Blutooth  (Read 767 times)
Kerbs
Rostra Blutooth
« on: March 07, 2019, 07:52:56 AM »
Folks,
I would like to add Blu Tooth capability to my 2002 Trans Am.
My GM dealer recommended the ROSTRA BluTooth device.
Does anyone have any experience with these devices, do they work well ?
If not, any other recommendations ?
I do not want to buy a new stereo, and would like to make this as unobtrusive as possible
thank you !
SNK
Steve B
Re: Rostra Blutooth
« Reply #1 on: March 07, 2019, 09:43:11 AM »
I don't know anything about ROSTRA, but have used devices similar to the one in the link below that work well.
https://www.walmart.com/c/kp/bluetooth-car-adapters
Steve
Gold member
Re: Rostra Blutooth
« Reply #2 on: March 07, 2019, 10:13:35 AM »
1979 Gold Bird
Re: Rostra Blutooth
« Reply #3 on: March 07, 2019, 10:28:53 AM »
Not sure how much you’re wanting to spend but this would probably accomplish what you want. I wanted it but it won’t work with pre78 common ground radios so it wouldn’t work for me.
Re: Rostra Blutooth
« Reply #4 on: March 07, 2019, 10:29:59 AM »
Link would probably help lol
http://www.outofsightaudio.com/mark-2.html
Re: Rostra Blutooth
« Reply #5 on: March 07, 2019, 11:28:38 AM »
No radio required for operation! Looks like it's a self contained unit that just needs power and speakers to operate.
Re: Rostra Blutooth
« Reply #6 on: March 07, 2019, 05:38:49 PM »
For a cheaper option but a little more work to install possibly you could try this. https://www.walmart.com/ip/Kenwood-KAC-M1824BT-Compact-400-Watt-Bluetooth-Connected-4-Channel-Amp/44641023
It’s what I intend to use in conjunction with my factory radio and console 8 track once I have some line outputs added. 8 track is almost done so the radio goes next. Once they’re both done I plan to add an update to my original post.
« Last Edit: March 08, 2019, 11:02:44 PM by b_hill_86 »
Kerbs
Re: Rostra Blutooth
« Reply #7 on: March 08, 2019, 06:15:15 AM »
Thank you all for the replies.
i will report back on which option I choose
thank you!
SNK
Re: Rostra Blutooth
