2020-B4-4
Author Topic: Rear gears for 77 trans am?  (Read 2424 times)
Bscheit65
« on: February 04, 2019, 11:47:25 PM »
Does anybody know what most 77 trans am 400 6.6 had for a rear gear ratio gonna change it too 323 think it has 273 but not sure anyone know for sure off top there head? Thanks
Re: Rear gears for 77 trans am?
« Reply #1 on: February 05, 2019, 07:02:29 AM »
It'll only be a guess until you check. If not sure then what better way than giving an oil change, no messing around jacking up and spinning wheels and counting.
1979 Black and Tan
  • '79 in Sunny San Diego
« Reply #2 on: February 05, 2019, 12:37:23 PM »
it's stamped on the rear end housing
1979 Trans Am
100% California Car, originally Atlantis Blue/ Black...All Original Unmolested 403, TH350, 2.41
63,300 orig. miles
1971 Chevy K20 4x4
« Reply #3 on: February 05, 2019, 05:33:12 PM »
I think its marked on the pass side tube kinda facing towards the front. May be a lettered code.
Bscheit65
« Reply #4 on: February 06, 2019, 01:01:50 AM »
I looked both those places and still couldn’t find anything let you know what I find out putting 323 gears in it
« Reply #5 on: February 06, 2019, 01:17:03 AM »
I'd find out what they are before you swap them or you have based the decision on nothing.
« Reply #6 on: February 06, 2019, 08:09:06 AM »
Did you scrape the tube down good and clean all over. From what I recall its not real obvious until you do some scrubbing. Someone had a chart (maybe butler) that had the codes to decipher the marks. I think there is a date code as well. I'll go out on a limb and say an "s" mark is for the 2:73, but dont hold me to it.
« Reply #7 on: February 06, 2019, 08:11:52 AM »
It's in every Service manual too. A 2.73 ratio Posi would have 2PU.
Bscheit65
« Reply #8 on: February 10, 2019, 11:31:14 PM »
Yeah I scrubbed it good with a wire brush still couldn’t find anything ended up opening it up it was a 2:41 couldn’t believe how low that was didn’t know they had that!
« Reply #9 on: February 11, 2019, 12:05:02 AM »
Keep us updated or at least me lol. My 77 has that gear or the next up but smaller than 2.73. I’ve been debating 3.08 or 3.23 with my 4 speed. Really leaning to 3.23. Almost picked up a complete 3.42 axle since price was right but I didn’t wanna go that size.
« Reply #10 on: February 11, 2019, 03:08:21 AM »
That was lucky you checked. Goes to show you can't swap gears simply by guessing what it might be and then jumping a step or two whichever way you prefer. By the way, that's a 2 series carrier which only allows you to go 2.56, 2.73 and up are 3 series.
Bscheit65
« Reply #11 on: February 11, 2019, 10:29:13 AM »
Yeah I’m still gonna get 3:23 just have to save up a little more money I just need a different carrier since it’s not  273 or above which cost about $500
Ryoko
« Reply #12 on: February 11, 2019, 05:20:02 PM »
I changed my 74 from an auto to a 4-speed, but left the 3.08 rear end alone. It worked out very well for me and made for a nice cruiser.
Bscheit65
« Reply #13 on: February 12, 2019, 12:45:13 AM »
That is an option I’ve been playing with is converting to a manual
« Reply #14 on: February 23, 2019, 04:00:52 PM »
2.41 is the most common for a 77 T/A, for what that's worth.  It's typical.
I suppose though, since you need another carrier, you ought to think about a brand new one.  I pulled out a lot of ruined spider gears when we were parting stuff out.
« Reply #15 on: February 23, 2019, 07:00:41 PM »
Also, look for entire rear axles with the diff you want. It's easier to set up or simply to fit as is, use it as an excuse to change leafsprings etc if needed. Generally, if you feel the diff ratio isn't quite ideal, then it's often more work than the result to simply go one step unless fine tuning, the results would still be similar, unless that's what you are after.
Garry
« Reply #17 on: March 03, 2019, 03:05:20 AM »
If you're not going to be excessively hard on it you might be able to use a spacer with your 2 series carrier. You can buy ring gear spacers through summit or jegs.
Quote from Super Chevy
"Ring gear spacers like this steel unit from Summit can be used to mount a 3-series gear on a 2.56-style carrier. The carrier has a thicker inside-diameter gear register that offers more surface area than other carriers, so Moore feels this is not a bad compromise. Summit offers this steel spacer with ARP bolts for under $30."
« Last Edit: March 03, 2019, 03:18:53 AM by Garry »
Garry
« Reply #18 on: March 03, 2019, 03:21:38 AM »
When I say excessively hard I'm talking about any form of boost.
Fbird
« Reply #19 on: July 30, 2019, 09:34:47 AM »
a couple of centuries ago they used to make a "thick" gear just for this situation!! been a LONG time now but 3.42 and 3.73 were always the typical swap.
67 Firebird
annasanders12
« Reply #20 on: September 26, 2019, 06:18:31 AM »
Are there also any new updates?
glenn911
« Reply #21 on: November 10, 2019, 07:18:35 AM »
I used a ring gear spacer back in the 80's in a 400 4 speed car.  Broke alot of stuff on that car racing it, but never the rear.
'79 400 4 spd esprit
'78 455 WS6 auto
'74 461 4 spd T/A
« Reply #22 on: November 11, 2019, 11:08:07 PM »
You're still here to tell us!
