2020-B1-1
Author Topic: EFI on 301  (Read 1081 times)
jamesrm3
EFI on 301
« on: January 27, 2019, 03:57:00 PM »
Has anyone used Holley Sniper EFI and tank on their 301
80 T/A
301
DSE 2in drop springs front and rear
PTFB body mounts,sub frame connectors,rear sway bar
18X8 front  with 245/45/18
18X9.5 rear with 275/40/18
Re: EFI on 301
« Reply #1 on: January 27, 2019, 04:57:49 PM »
I know TTA Performance installed FiTech recently.
I would contact them for advice on that engine.  The owner Joe does some really nice work. He’s a really nice guy and knows his way around those engines.
https://ttaperformance.com
jamesrm3
80 T/A
301
Re: EFI on 301
« Reply #3 on: January 28, 2019, 11:10:07 PM »
I was looking at this https://www.holley.com/products/fuel_systems/fuel_injection/sniper_efi/sniper_efi_quadrajet/parts/550-869
This is probably your best option upfront due to having the spreadbore carb pad on your turbo inlet manifold.
jamesrm3
Re: EFI on 301
« Reply #4 on: January 31, 2019, 04:42:34 PM »
Mine is N/A. This Holley set up is similar to the regular sniper but is
supposed work with stock intake manifold. I was curious if anyone was running one. I'd like to know how well it fits. A friend has the regular one on his olds it works great.
80 T/A
301
Re: EFI on 301
« Reply #5 on: February 04, 2019, 08:41:44 AM »
Should fit with no problem since it’s a spreadbore.  Hope to see you install it.  These are definitely interesting for the stock intake crowd.
Re: EFI on 301
« Reply #6 on: June 05, 2019, 03:22:24 PM »
hakitup
  • What more do you need?
Re: EFI on 301
« Reply #7 on: June 05, 2019, 03:54:28 PM »
Here is my thread on the sniper spreadbore, I am very happy with the results.
http://transamcountry.com/community/index.php?topic=80622.0
Re: EFI on 301
« Reply #8 on: June 06, 2019, 08:47:23 AM »
read through your article and it was a great write up.
One question, as I am super clueless but was there a choice option for it to setup on a 301 or is that something I will have to try a 305 setting and tweak the numbers?
Re: EFI on 301
« Reply #9 on: June 06, 2019, 11:33:31 AM »
just My 2 cents , but for the 301 , I would just start with the basic parameters in the initial setup and then adjust it from there if needed. For just a basic setup for the 301, I would keep the timing stand alone if your happy with it now. The base settings on the Sniper work really well with a stock set up, just program in the numbers in the set up and I think that would work very well.
1970 Firebird
Re: EFI on 301
« Reply #10 on: June 06, 2019, 11:35:02 AM »
My apologies for my ignorance but what is that?
hakitup
Re: EFI on 301
« Reply #11 on: June 06, 2019, 06:22:54 PM »
On initial set up it ask for which system you have, cylinders, cubic inch, cam, target idle and ignition type, that easy.
https://documents.holley.com/199r11367.pdf
Tom H
Re: EFI on 301
« Reply #12 on: June 10, 2019, 06:41:20 AM »
Ahh...ok ok...thank you!!
Re: EFI on 301
