Author Topic: Can't Spin the Tires :-(  (Read 1121 times)
allenga
« on: December 04, 2018, 09:21:49 PM »
I love my car.  Had it 5 months now.  You know, when you want to pull away and are looking to make some noise in front of your friends?
It's depressing when your black 77 TA W72 auto with full dual Magna-flow exhaust and 3.23 gears can't spin the tires at will.   :-/
I know, I know, it's only got 200 or so horsepower.  Still depressing!
1977 Trans Am, stock 400 W72, auto.
Re: Can't Spin the Tires :-(
« Reply #1 on: December 04, 2018, 09:58:25 PM »
turbo hydramatic - where hopes and dreams go to die. :lol: :lol: :lol:
« Reply #2 on: December 05, 2018, 12:50:43 AM »
it's easier to lose the friends than meet their expectations
1976 SE SF
  • Stealing home plate on a bunt
« Reply #3 on: December 05, 2018, 04:14:26 AM »
What motor? Any mods?
No one looks this cool and still passes smog https://flic.kr/p/2buNiyP
Ryoko
« Reply #4 on: December 05, 2018, 07:55:30 AM »
200hp and a 3.23 rear end should be able to spin first gear at a least part of the way. Sounds like the engine is not performing as it should. My 74 with a th400 and 3.08 rear gears would do it easily without any engine mods.
allenga
« Reply #5 on: December 05, 2018, 08:13:46 AM »
Its a 60,000 mile car, all stock except exhaust.  Starts, runs and drives good.
« Reply #6 on: December 05, 2018, 08:37:08 AM »
I believe the technique is called a "brake torque".    Could always carry some sand around and spread it near the rear wheels just before you leave. :-D
I'm sure there are other ways to coax a squeal out of it.
« Reply #7 on: December 05, 2018, 09:49:24 AM »
Use both feet, step on the brake and rev the engine to about 1200 rpms, release the brakes and floor the gas pedal.
allenga
« Reply #8 on: December 05, 2018, 09:52:52 AM »
Yes, if I want to do a burn out, I will dump some water on the ground while no one is looking, then peel out.  :-). I will have to get a cooler or something for the trunk
DeCaff2007
« Reply #9 on: December 05, 2018, 11:25:08 AM »
That's ridiculous.  My 96 Blazer with a 4.3L V6 and an ailing 700r4 can do burnouts.
My TA, otoh, has a worked 400 and at the time, had a functioning TH350 with a 3.23 rear.  It smoked the tires a little too easily.
allenga
« Reply #10 on: December 05, 2018, 11:32:47 AM »
Great!  What should I look at first.  Timing?
I just changed spark plugs which made a world of difference for hot and cold starting.
Trans was rebuilt already.
mz-formula
« Reply #11 on: December 05, 2018, 11:35:56 AM »
My 175hp bird can.... But... It's only a 1 tire fire being an open rear end.... Nobody is perfect.
pancho400cid
  • Viva los PONCHOS!
« Reply #12 on: December 05, 2018, 12:17:33 PM »
Air the back tires up to 60 PSI!    :lol:
<safety warning - do not inflate tires beyond manufacturer's recommended max pressure>
« Reply #13 on: December 05, 2018, 12:28:46 PM »
Could install "line lock" for a little over a hundred dollars. Then you apply brakes, hit line lock button & hold, release brakes and the line lock holds the front brakes clamped while you apply power to get wheels spinning. Release line lock button to allow forward motion immediately if you don't want people to know you have it or sit & fry tires into a cloud of smoke!
EOD9339
« Reply #14 on: December 05, 2018, 01:12:48 PM »
When mine was a stock L78 with 2:41 it would spin the tires no problem. The only thing done was trues exhaust (no cat), long tube headers, recurved the Dist, and a good tune. With 3:23 you should have no issue.
81Blackbird
« Reply #16 on: December 05, 2018, 03:08:08 PM »
I had the same problem with my '02 WS6....
then I turned off the traction control  :-D
« Reply #17 on: December 05, 2018, 04:42:13 PM »
Funny guy.
DD78TA
« Reply #18 on: December 05, 2018, 05:40:27 PM »
I agree a stock ish pontiac 400 that is running good should do a burn out of some sort with a 3.23 rear gear in a TA.
How does it run otherwise... at idle, down the road, through acceleration to about 4K rpm.
allenga
« Reply #19 on: December 05, 2018, 05:47:19 PM »
Thanks Guys.  It's an original unmolested car.  The only tune related thing I have done is spark plugs, and adjusted the choke.  Car starts, runs, drives great.  It accelerates without missing or hesitation.  I was going to look at plug wires, distributor cap, rotor, and adjust timing next.
squirrel
« Reply #20 on: December 05, 2018, 09:28:43 PM »
i have the same set up but in a 78 and it spins the tires just fine but not for long.
Dan from Cincinnati Ohio
1978 TA W72/WS6 Brown/Black
1976 Mustang Cobra II 4 speed
allenga
« Reply #21 on: December 05, 2018, 09:42:00 PM »
Anyone have any tuning suggestions?
john finneran
« Reply #22 on: December 05, 2018, 09:45:23 PM »
a can of carb cleaner is a agood  start
johnny
aussieta
« Reply #23 on: December 06, 2018, 12:08:58 AM »
choose a nice safe spot
accelerate from standstill to a point about 1/4 mile down the road
note mph at this point
increase timing 1 degree and repeat
 if mph increases repeat until maximum and then remove 1 degree
if mph decreases remove 1 degree and repeat
any sign of pinging back it off and try again with higher octane fuel
1978 Y84 W72 WS6
1976 SE SF
« Reply #24 on: December 06, 2018, 06:33:07 AM »
allenga
« Reply #25 on: December 06, 2018, 07:57:11 AM »
That Performance Distributor looks like a nice add on.  Anyone done this..Thanks!
SP Steve
« Reply #26 on: December 06, 2018, 08:33:58 AM »
Get a Moroso curve kit for it and swap out the weights and springs and set full mechanical advance at 36 degrees.  A stock 77 400 has pretty low compression so you should probably be able to use the lightest springs without detonation.
highway star
« Reply #27 on: December 06, 2018, 09:24:50 PM »
Yes! I was adjusting the oem distributor, springs, weights etc. and was chasing my tail with trial & error.
I sent them my engine/drivetrain info and they curved a new one accordingly.
My engine is not stock so it made a world of difference with the new distributor!
allenga
« Reply #28 on: December 06, 2018, 09:38:03 PM »
Thanks Highway start.  What did you notice a difference..
highway star
« Reply #29 on: December 06, 2018, 10:57:56 PM »
Start up, idle & acceleration with no hesitation!
« Reply #30 on: December 07, 2018, 03:29:04 AM »
Yes, it's depressing that these cars look the goods but are pathetic in power. So enjoy driving it instead of cheap thrills. Paint chips are expensive.
cyber104
« Reply #31 on: December 07, 2018, 07:08:42 AM »
Well said
Moon75
  • lifes short- long burnouts
« Reply #32 on: December 07, 2018, 12:04:38 PM »
Possibly give it a tune up. check everything. how old is fuel? These cars sit too long sometimes. im just shooting in the dark over here thou. pew pew.. cheers
JUST GIVER
80Pacer
« Reply #33 on: December 08, 2018, 12:26:11 AM »
Add a few more degrees intial to the timing, rejet the carb, go with 1 or 2 jets larger, open the scoop or buy one that's already open and use a good high flow air cleaner, put dual exhaust on the car with no cats. You shouldn't have a problem spinning the tires.
squirrel
« Reply #34 on: December 08, 2018, 11:34:07 AM »
i think power braking is a fake burnout.  gas pedal only and you get what you get.  don't like doing burnouts anyways, just cruise.
phil400
« Reply #35 on: December 08, 2018, 08:36:30 PM »
Check for rust in/on the dizzy weights. Make sure your gettimg all your timing in. Clean, replace the springs but KEEP the Factory weighs. Use one heavy and one meduim spring, this should get your all timing in around 3-3500k. Set initial for 12-18*
Check make sure throttle blades are full open when peddle is to the floor,  stock 200hp 400s with DK mods ran low 14s with their tune.
Any Pontiac with 3.23 gears should have no problem lighting up the back tires.
Is the trans slipping?
Next would be a compression check.
What size of tire?
78 T/A 4 speed, Marty Blue, original paint, match #s mine since ‘99, 3rd & final owner as long as I'm alive.
https://www.youtube.com/watch?v=CbM_iVhwVQc
https://www.youtube.com/watch?v=AgqYOsWTJsE
98 Ford Ranger flare side 2.5L 5speed "old reliable" 187k and still going
77 T/A sold
85 Monte Carlo SS sold
83 Mustang GT sold
“Let me tell you what Melba toast is packing”
allenga
« Reply #36 on: December 08, 2018, 10:32:31 PM »
I just ordered dist cap, rotor, wires and will take it all apart next week and look at timing.  Trans rebuilt, not slipping.  Compression good.  Tires brand new 235/60/15.
allenga
« Reply #37 on: December 13, 2018, 06:54:06 PM »
OK, I have it apart.  The dist cap contacts are crusty corroded, the coil looks original, the wires look ancient.   Here is the inside of my distributor.  Looks crusty.  Just a new spring kit?
« Reply #38 on: December 13, 2018, 07:57:06 PM »
Many times the factory springs can be the best.  It looks normal to me.  I would take it all apart and clean it up.  All those rusty parts including the springs can go in a bath of Evaporust.  Check the wires where they attach to the coil pick up as those attachments can become brittle and break off there.  Check the vacuum advance to make sure it is not leaking.
It would be good to remove the distributor and check for end play.  There is a spec for that and you can add shims to adjust it.  You have to remove the roll pin in the gear to do this.
80Pacer
« Reply #39 on: December 14, 2018, 12:14:30 AM »
If you need to shim the distributor go to the 301garage website. I did a tutorial on it.
