Author Topic: Post your basic install pic  (Read 1369 times)
Pennywise75
« on: August 26, 2018, 12:51:03 PM »
Hey guys. I’m really drawing a blank here. I’ve got my amp, 6x9s and 12” tube ready to go in the trunk. I’ve got the wires run to the trunk. Just wonder where you guys have put the amp and where a good place for a ground in 2nd gen trunks. Pics would be helpful. My car is a 79
Re: Post your basic install pic
« Reply #1 on: August 26, 2018, 03:18:50 PM »
Can't help with the amp... no room for large amp or sub-woofer, but I'm not into that anyways. As far as ground anywhere works, just make sure the screw comes in contact with bare metal.
aussieta
« Reply #2 on: August 26, 2018, 11:29:28 PM »
you need to run your ground wire to the battery or you will create a ground loop
my amp is mounted to mdf which is mounted to (firewall?) behind rear left hand seat
1978 Y84 W72 WS6
brdzword
« Reply #3 on: September 03, 2018, 07:44:18 PM »
Check out!   "F-body audio install. Better late than never."  On this website. Use the search.  Audio section August 10, 2014. Wow! How time has past since I posted this.
« Last Edit: September 03, 2018, 07:49:48 PM by brdzword »
