Author Topic: Garage Build (Fixed)...I think  (Read 5945 times)
Re: Garage Build (Fixed)...I think
« Reply #80 on: July 20, 2019, 03:05:23 PM »
Today we started emptying out the basement into the garage. The electrician comes Monday to start putting the panel up, running the cable to the garage and to the old panel (upgrading to 200 amp) and running the cable under ground out to the main pole!!
« Reply #81 on: August 03, 2019, 05:31:39 AM »
A few things moved in
Dads toolboxes
20190726_104104 by Charles Marson, on Flickr
Storage cabinets
20190726_104109 by Charles Marson, on Flickr
Everyone needs a TIG Welder in the tool collection
20190726_104128 by Charles Marson, on Flickr
220V MIG and 110V MIG...missing is the other 110V MIG...also our band saw in the background
20190726_104142 by Charles Marson, on Flickr
My boxes even found a home inside as well
20190726_115833 by Charles Marson, on Flickr
Small Oxy/Acetylene bottles
20190726_104154 by Charles Marson, on Flickr
Missing are the two cutoff saws we have, one is a Rigid and the other is a Milwaukee
I didn't bother posting pics of the trench that the cable was running through but the new panel is installed, everything is ready to be hooked up and we are just waiting for the electrical inspection and the electrician come back and hook everything up. We are hoping that al takes place this coming week but I guess we shall see
« Reply #82 on: August 03, 2019, 09:03:30 AM »
Its nice to finally get tools where they belong. Looking good.
DeCaff2007
« Reply #83 on: August 26, 2019, 08:41:18 PM »
Looks awesome and I'm sure many are in envy.
Question:  Why paint white drywall.... white?
« Reply #84 on: August 27, 2019, 06:22:33 AM »
Not sure of Charlies reason, but bare drywall needs painted with something. It will turn dark and ugly over time when left alone.
« Reply #85 on: August 27, 2019, 06:28:30 AM »
And to cover up the joints, etc.
« Reply #86 on: August 27, 2019, 08:56:30 AM »
I painted both of my storage garages bright white. Helps 'brighten up' the place, and generally looks nice. Easy to clean too. Much easier to see everything than a dark or muted color.
I used to be indecisive. Now I'm not sure.
I feel like I am diagonally parked in a parallel universe.
1968 400 convertible (Scarlet)
1976 T/A - 455 SE (No Burt)
1968 400 coupe - R/A clone (Blue Pearl) (for sale)
1968 350 - 4 speed 'vert - 400 clone (the Beast!)
1968 350 convertible - Wife's car now- 400 clone
2008 GP GXP - New one from NH is AWESOME!
1980 T/A SE Bandit - Sold :(
« Reply #87 on: August 27, 2019, 02:52:45 PM »
Yes, white is nice. Reflects the light greatly. What walls I have finished in my shop are painted a very light grey, and I plan on putting white metal on the ceiling just for reflectivity. Nexus' garage looks fantastic!!
« Reply #88 on: August 29, 2019, 03:01:40 PM »
As mentioned, it seals up the surface to make easier to clean...if it ever comes to that but more importantly, it helps to brighten up the space so it doesn't feel like you're working in a cabe
« Reply #89 on: August 29, 2019, 03:04:11 PM »
I am behind with pictures and I will update that soon enough but not much has changed visually.
Dad has been busy making cabnets and hanging them on the wall for strorage.
The Electrician was in yesterday and we FINALLY HAVE POWER IN THE GARAGE!!!!!!!!!!!!!!
Waaaahhhooooooo
Again...need to update witb pictures!!!!
« Reply #90 on: August 29, 2019, 06:33:04 PM »
« Reply #91 on: August 29, 2019, 07:32:43 PM »
Looking good and I forgot how big the garage/shop was, very nice.
« Reply #92 on: September 03, 2019, 07:26:48 AM »
Thanks...yeah it is a decent size for sure. My father still isn't happy with it so he has a contractor bringing him back a quote for the extension off the back side. We had it set up in the plans, so all the doorways are ready to go. Just going to go with an unheated shell for now and finish it off slowly.
As they say...you could build a warehouse and it would still be too small. This is perfect for me but I can do one job at a time (even if it takes e forever) where he has to have a few things on the go. He needs to stay busy all the time.
« Reply #93 on: November 12, 2019, 06:18:27 PM »
A bunch of updates to add
Back garage door is installed and working
testing buckets
20191022_111050 by Charles Marson, on Flickr
20191022_125648 by Charles Marson, on Flickr
4" square steel solid bar stock, threaded and eye bolt installed with cables attached
20191024_145135 by Charles Marson, on Flickr
custom weight guide installed
20191026_105240 by Charles Marson, on Flickr
20191026_105156 by Charles Marson, on Flickr
« Reply #94 on: November 12, 2019, 06:21:50 PM »
in some of the pictures above you can see the furnace attached to the ceiling!!
it is now working
20191112_102900 by Charles Marson, on Flickr
gas line run along the ceiling and the tank was installed today. Garage was warmed up to 54 degrees F as it started out at 24 degrees F this morning!!
« Reply #95 on: November 13, 2019, 08:21:09 AM »
Not sure I understand the garage door, looks like a torsion spring would have been easier. What heater (and specs please) are you using? I put off another summer of getting one in my shop now I am regretting it. Originally I had thought about using a couple of those like you have, hot dawgs, but I have been told that the overhead infra reds work really good. Not sure what I want to use, and they both cost about the same.
« Reply #96 on: November 13, 2019, 10:08:46 AM »
Looks like a traditional gas unit heater.
« Reply #97 on: November 13, 2019, 12:31:18 PM »
Yea, there are a couple of brands, Hot Dawg, and Modine come to mind. I am curious as to the BTU rating and how well it heats the space up.
« Reply #98 on: November 13, 2019, 12:53:41 PM »
Kerry,  don't you ever come across standard house furnaces for cheap? I shoved one into my attic and ran ceiling ducts.  I got the furnace for free as they were upgrading.   The only expense was the short exhaust vent pipe and flexible duct. I made th cold air return from scrap plywood.
To the OP, the shop is looking great! It's nice to have a place to work and where everything is organized.
« Reply #99 on: November 13, 2019, 03:47:05 PM »
I have an oil furnace in my attic that is only about 10 yrs old. Nothing wrong with it. I replaced it with a gas unit (had problems getting the oil to the attic, a whole story in itself). I kinda forgot about it to tell the truth, until your mention. I might have to look into that.
« Reply #100 on: November 13, 2019, 10:14:10 PM »
I'll have to get exact specs tomorrow while I'm out there...i was told but can't remember.
As for the door, it's second hand and according to the door guys the spring isn't designed to hold the weight only to help assist it up as it rests horizontally, but we have no horizontal with this set up obviously...they recommended this setup
« Reply #101 on: November 14, 2019, 07:50:14 AM »
Gotcha, looks like a wood door as well. Very heavy.
« Reply #102 on: November 14, 2019, 05:57:01 PM »
Furnace is a Big Max and it puts out 123000 BTU's
the counter weight is about 160 lbs and the door is indeed wooden...I'd like to see an insulated door there in time but this is ok for now
« Last Edit: November 14, 2019, 05:59:13 PM by Nexus »
« Reply #103 on: November 15, 2019, 08:00:47 AM »
Thanks Charles, that's the info I was looking for. I assume you guys are happy with it and it heats the garage pretty good.
« Reply #104 on: November 15, 2019, 08:14:35 AM »
Kerry, just remembered that he lives about 1000miles north of you.
« Reply #105 on: November 15, 2019, 03:42:42 PM »
Yes I am aware, but it still gets cold here in the mid-atlantic as well.
« Reply #106 on: November 16, 2019, 04:18:22 AM »
I'm going to say yes...we haven't given it the proper exercise yet as it is running with little propane in the tank. They are supposed to be out today to fill it up and the furnace guy was supposed to be out yesterday to make sure it was working properly.
It does work and it does keep the place warm. We only had it set to 45 degrees so the real test will be when it dips down to zero and colder.
« Reply #107 on: January 03, 2020, 08:03:09 AM »
I'm so jealous of that shop!!!
1977 Y82 W72 Auto
2007 F-150 Lariat 4x4 (5.4)
2007 Ford Edge SEL AWD V6
2012 Mustang
« Reply #108 on: January 03, 2020, 04:14:55 PM »
Well Mike, I'm not one to make waves and disagree with you, so I'll just say it has been darn sweet so far!!!
We have always worked under tarps or in the rain or snow so having this is pretty cool for us.
Funny thing is, my dad still complains it's not big enough but I think he could be in a warehouse and still complain about space!
