Author Topic: Drive Shaft Removal  (Read 166 times)
Robertr
Drive Shaft Removal
« on: July 11, 2018, 10:01:54 PM »
In an effort to gain access to my drive gear, I need to get my extension housing off of the trans.  In order to do that, I need to take my drive shaft off.i have taken the 4 bolts out of the rear u joint and thought that it would slide slightly forward and come apart.  I have pulled hard on a pry bar, and the thing will not come apart.  Is there a step I am missing?
1977 Trans Am - SOLD
1978 Trans Am - Getting there...
1977 Trans Am - Not there.....
Bluebandit
Re: Drive Shaft Removal
« Reply #1 on: July 11, 2018, 10:23:37 PM »
You've got it right, sometimes those things can get stuck pretty tight. Tapping with a hammer sometimes helps loosen it.
81Blackbird
« Reply #2 on: July 12, 2018, 04:54:16 AM »
x2  a little penetrating oil may help too.
Robertr
« Reply #3 on: July 12, 2018, 07:59:05 AM »
Thank you sirs.
