Author Topic: Flowkooler aluminum water pump  (Read 1038 times)
Roadie
« on: May 28, 2018, 07:08:10 PM »
About 8 years ago, I put a flowkooler aluminum water pump in my Pontiac 400. I don't drive it much... It was on there for about 3000 miles. The impeller came apart where it meets the hub that attaches to the shaft. I replaced it with a GMB aluminum one with a cast iron impeller. I will never use another flowkooler product as long as I live.
« Last Edit: May 28, 2018, 07:11:57 PM by Roadie »
70RAIV455
Re: Flowkooler aluminum water pump
« Reply #1 on: May 28, 2018, 07:34:57 PM »
Flowcooler used to be Top Notch.
It was one of the original High flow Pontiac V8 water pumps.
GMB pumps are made in China.
Good is did not fail.
Bad is it failed too.
Ugly is same or worse as today shown.
Roadie
« Reply #2 on: May 28, 2018, 08:20:46 PM »
I'd rather have a Chinese bearing fail than an impeller failure. The temp went from 180 to 260 within a 4 mile stretch between my guage checks. At least with a bearing failure, coolant is still flowing.
Roadie
« Reply #3 on: May 29, 2018, 08:31:03 AM »
Funny thing about those Flowkooler aluminum water pumps... They use GMB housings. lol
Mine has "GMB G28 1" casted into it. So does the image at Butler Performance.
https://butlerperformance.com/i-24452956-flowkooler-pontiac-11-bolt-1969-1-2-77-hi-volume-aluminum-water-pump-w-billet-aluminum-impeller-brw-1649.html
And they grind the numbers off before polishing their polished version:
https://www.ramairrestoration.com/pontiac/timing-covers-waterpumps-rela/awp-1p-high-flow-aluminum-water-pump-69-81-pontiac.html
So, when they buy their parts from GMB, do you really think they replace anything before pressing on their impellers?
« Last Edit: May 29, 2018, 08:34:30 AM by Roadie »
Roadie
« Reply #4 on: May 30, 2018, 08:50:04 PM »
Received my GMB one today. It is IDENTICAL to the flowkooler pump, down to the casting numbers, except the impeller. There goes the Chinese part argument...
gstrandfarm9420
« Reply #5 on: May 30, 2018, 08:51:58 PM »
Did it significantly help the cooling (while it was working) ? Seems like stock Pontiac water pumps have been reliable but not overly efficient.
Roadie
« Reply #6 on: May 30, 2018, 08:58:34 PM »
I made sure to massage the plate to .025" away from the impeller before installing tonight and drove it for 30 miles in 90* ambient temperature. There was no difference in temperature from the flowkooler to the GMB according to the Holley Sniper logs (including cruising, several WOT runs, and 20 minutes of idling).
That said, I do run a 4 core aluminum radiator and electric fans. I never had a cooling issue with this setup.
Roadie
« Reply #7 on: May 30, 2018, 09:11:59 PM »
Setting the plate clearance to .025" is the most important thing with Pontiac water pumps. If that gap is too big, pump efficiency is lost due to water flowing back around the impeller... I think that is far more important than impeller design.
I have also read to stay away from stamped steel impellers, but I've never ran one to compare.
« Reply #8 on: May 30, 2018, 10:39:43 PM »
Stay away from stamped impellers. They do not work very well with Pontiac engines.
1970 Firebird
cyber104
« Reply #9 on: June 01, 2018, 09:39:35 AM »
I'm very surprised that happened - Flowkooler has a good reputation.
Did you call them to discuss?
Chris
1978 TA 4-Speed W72
Roadie
« Reply #10 on: June 01, 2018, 10:07:17 AM »
I contacted via web. No response. I'm not really interested in a replacement from them, so no biggie.
« Reply #11 on: June 23, 2018, 05:14:58 AM »
Wow....thats no good.....  :shock:
