2020-B1-9
Author Topic: 1971 Firebird LS (L76) swap with 6L80e 6 speed auto, PICTURE HEAVY  (Read 2533 times)
Cape T/A
  • Nathan- Cape Girardeau, MO
I figure ill make a post in here summarizing my LS swap I started (and finished) last year.
here is my car before the swap.
More of the build and engine swap by nathan kluesner, on Flickr
and here it is 8 months later
Untitled by nathan kluesner, on Flickr
I came across this 70k mile g8 pull out on facebook, I offered a little more than asking price so I could get all accessories, harness, computer, gas pedal, fans and I'm sure a few other things, I got it for $3,700. For those that don't know, the g8's came with an L76 and 6L80e trans, which is an aluminum 6.0 with ls3 style heads, displacement on demand, and a 6 speed automatic transmission.
So i started pulling the original pontiac 350 out.  It ran good, just didnt have power, got 10 mpg, and had a lot of leaks.
I ordered up a pile of parts for the new engine from Scoggin Dickey.  A cam spec'd for boost, and DOD delete kit.
Next i took the heads off, cleaned them up, and put the new hardware on.
Engine going back together
ready for paint
painted
dropping my test block in place.  I am using BRP engine and trans mounts, and I am very pleased with them,  they keep the engine very low.
next i stuck the transmisson on to see if it would even fit with the mounts.  i was fully ready to cut the trans tunnel to make it work.  It fit though with no issues.
now that the transmission is on, i was able to put the accessories on and check their fitment.  i wanted to keep the low mounted alternator and A/C compressor because i hate how they look up high and with the relocation brackets they tend to look like an afterthought.  as suspected i need to notch my frame for the alternator and a/c compressor.
i started cutting back the unused wires of the stock harness.  all that i kept past the firewall was for the lights, horn, wipers, and starter coil.
engine ready to go in
since i got g8 fans with the engine i bought a g8 radiator from ebay.  it took A LOT of work and test fitting to make it fit, but in the end it turned out very good.
vintage air kit came in, so now i can figure out my exact ac compressor placement.  turns out the brackets vintage air would send for low mount dont keep the compressor close enough to the block for what i needed.  So i ordered dirty dingo brackets (which needed modification to work)
here is the dirty dingo setup
here is where i needed to notch the frame for it
frame notch in progress
test block set back in, bolted to trans, accessories put back on, and checking for clearance.
1971 lucerne blue Esprit
Cape T/A
Re: 1971 Firebird LS (L76) swap with 6L80e 6 speed auto, PICTURE HEAVY
« Reply #1 on: May 17, 2018, 08:01:38 PM »
test block removed for notch finishing.
i had to end up trimming the front edge of the engine frame mounts to clear the notches, no big deal though.
frame is finished and painted, now the fire wall can get painted body color.
A friend came by and painted my firewall and radiator support for me.
now the real engine can go in
my son posing for this proud moment!
getting the transmission ready to go in now.  fluid and filter change, and some paint.
there it is all put together!  That is an F body oil pan by the way.
accessories put on.
very tight clearance on passanger side (G8) manifold. I used manifolds because i plan to turbo the car soon and didnt want to waste money on headers that will be eliminated.
Radiator and fans mounted.
my custom speedhut canbus gauges came in
mighty mouse catch can
2" hole in the firewall for the engine harness
laying out the PSI harness.
harness finished
time to work on the vintage air.  what a pain in the ass this was.
trying to get a game plan for all of the under dash wiring and figuring out the best way to do it.
gauges wired up
More of the engine swap by nathan kluesner, on Flickr
my cruise controls.  This still isnt working to this day, i think i can get it to work, just am not really motivated to dig all my wiring apart to do it.  the issue is i am using a g8 gas pedal and its designed for an ls3 pedal.
the wiring gettting even more complicated.
current state of the engine bay.
both inner fenders on, ebay $50 99-07 truck intake installed, and fuel pressure regulator installed
fuel lines tied in
my custom slip-spline driveshaft finished.  i had to use a bolt on th400 yoke in the trans and had to have it milled to fit.
my tanks inc efi tank and my Chris1313 dual 450 pump setup.  this fuel pump setup is only $650 and good for 1200 hp.  since boost is in the plans i didnt want to do this twice, so fuel will not be an issue for me!  this pump is designed for a 4th gen so some (a lot) of modification had to be made for the tank. in the end i have had trouble keeping it sealed up to the tank, i have tried to fix this 3 times now without a solution.  my latest attmept was to weld a 4th gen lock ring onto the tank and use the 4th gen gasket and it still leaks, not as bad though, and only when the tank is first filled up.
Cape T/A
« Reply #2 on: May 17, 2018, 08:03:29 PM »
marking out where to cut the hole
g8 gas pedal mounted
vintage air controls done
sorting out some wiring
panel i made for the glove box to do all the wiring.
cruise control is mounted to the back, which turned out to be a bad idea now that its not working and dakota digital wants me to do voltage readings at the terminals.
engine harness fuse box mounted underneath and my fuel pump and fan relays are up top
gauges lit up
working on my Pypes 3" exhaust x pipe kit
driveshaft finished
READY TO BE STARTED!!!!!!  I couldnt get it to start though, computer had it locked out, so my friend came by and flashed a tune on it.
Finishing the engine swap by nathan kluesner, on Flickr
loaded and heading to the exhaust shop to get the exhaust finished from the manifolds to the x pipe.
new hood getting painted at the body shop
back from the body shop and with Trans Am stripes too.  you can see how much higher the front end sits with the aluminum LS engine vs the old pontiac.
Finishing up the firebird build and trip to Trans Am Nationals by nathan kluesner, on Flickr
shaker scoop installed, its just on the hood for now.  eventually ill mount it to the engine.
getting the ac charged.
working on fitting the g8 seats.
seat tracks modified to bolt down using factory seat holes
both seats finished, about 18 hours of work went into this.
its all about the details.
trans am nationals is 1 week away, so i cut the springs to bring the front end down, i cut 1.5 coils off, in hind sight i should have cut 1.25, its very low, looks agressive though.
wiring finished.
pulled the old shocks off with helper springs to bring the back down.
alignment time, just a few days left before trans am nationals
Cape T/A
« Reply #3 on: May 17, 2018, 08:04:36 PM »
getting the back window tinted, and this bird is ready to fly!
or so i thought, my transmission pan is 1 1/2" off the ground now that the car is at ride height, so i had to make a skid plate with just a few days before a 1100 mile trip.
skid plate done
fuel punp leak fix attempt #2, the day before trans am nationals
cleaned up and ready to go!
and here we go!  deadline!  8 months from when i bought the ls engine, we (my girlfriend and i) are leaving from missouri to go to ohio for the Trans Am Nationals!
179 test miles before we leave.
we made it with no issues, other than smacking that skid plate about 30 times.  then at the Tipp City cruise in we won Best Of Show!!! what an honor!
While at Trans Am Nationals I also got a photoshoot for Timeless Muscle Magazine, very cool stuff.
ended up getting 22 mpg with the A/C blowing cold on the trip!
here is the magazine article for those that care to give it a look, make sure to watch the video!!!
http://www.timelessmuscle.com/features/car-feature-modernized-2nd-gen-firebird/
« Reply #4 on: May 18, 2018, 08:17:33 AM »
So cool man! Congrats on the article.  8-)
Cape T/A
« Reply #5 on: May 18, 2018, 08:37:32 AM »
Thanks ryeguy!!!
Here was my skid plate after the trip, it was smashed up against the trans pan.  I ended up pulling it off, adding some more welds to it, and putting new hardware on it.
so as I see it, I have 3 options.
1- pull the engine and trans, re do all the mounts, cut the trans tunnel out, and make it sit about 2-3" higher in the car.
I'm not a fan of this idea as id be messing up everything i've done to this point.
2- switch the 6 speed out for a 4 speed.
I am also not a fan of this, as I purposly searched for a 6 speed auto setup to run, I love how strong these transmissions are, their quick shifting, tunability, and fuel economy.
3- Air ride suspension-
This is the route I am going to take, the car currently has all stock suspension that needs replaced.  So once i can save up the 4-5k to pay for it, I'll be adding the Ridetech shockwave system to my car.  It uses air bags with a double adjustabe shock built inside of them ( like a coil over), it 4 links the rear axle, and ill be using their Air Pod which is a pre made pump, tank, relay, and controller setup.  It will give me a remote toutch screen with several pre set settings on it.  So ill be able to raise the car up when going down the high way, lower it down when cruising slow in a car show or where ever id like, and then put the car real low when parked.
I'm buying a house next month so that will be taking up most of my money along with my 2010 GMC lost oil pressure, so firebird is on the back burner for a bit.
Cape T/A
« Reply #6 on: May 18, 2018, 08:56:33 AM »
So once I fired up the engine I noticed my A/C belt kept jumping off one rib to the back.  No matter how many times I put it back to the correct spot it would immediately jump off once the engine was started.  So this winter I corrected that problem.  After some measuring I found out that the compressor was 5/32" to far forward.  So I had to cut, drill, and add some spacers and was able to get it right where it needed to be.  I have since put several hundred miles on the car and many WOT pulls and the belt has stayed put!
Next I noticed my balancer was very slightly wobbling.  The bolt was tight as I had followed the GM torque sequence, so I concluded that the rubber was working out of it.
I had my friend Aaron at SDPC send me a new balancer and ARP bolt (along with all the components to build the rear axle).  The new balancer is straight as an arrow when running.
not really LS related so ill skip the details, but here is my axle I built and finished a few weeks ago.  3.23 Richmond gears. eaton tru trac, mouser 31 spline axles, and 4th gen disc brakes.  The car runs so much better with this setup.  And I still only turn 2k rpm's at 75 mph.
So on my 3rd attempt to fix my fuel leak, I got a 4th gen plastic tank, cut the lock ring out, melted the plastic off, cut it down to height, and had a friend Tig weld it to my tank.  Using a 4th gen gasket this seemed to seal up really well, and I thought it would fix my leak when the tank was freshly filled up, it did not though, as it still drips, unless my leak is coming from somewhere else?
axle and tank back in the car
« Last Edit: May 18, 2018, 10:07:39 AM by Cape T/A »
Cape T/A
« Reply #7 on: May 18, 2018, 09:04:20 AM »
Fast cars have to stop good right?  I got more money back from my income taxes than I thought so I decided to finish my brake upgrades since I had already started on the rear.  I ordered up a cpp C5 brake kit.  That kit has got to be the easiest big modification ive made to my car.  It took way more time to paint it all up than to actually install it.
And the wilwood master cylinder.  works great and makes the engine bay look so nice!
So that brings me up to date on all of my LS related mods to the car.  I initially thought I would be putting a turbo on the car by now, but the swap cost me a lot more than I intended, and the Ridetech suspension is more than double what I thought id spend on suspension as well.  So it will be several years before this car sees boost, but it will happen!
Dreamn2
« Reply #8 on: May 18, 2018, 12:05:35 PM »
Very Good Job Nathan, Love the car!
79 Fire Am
76 Fire Am
1972 Formula 400
  • Parts vender
      • Scarebird Classic Brakes
« Reply #9 on: July 23, 2018, 09:02:13 PM »
Nice work.  I saw your upper radiator hose and ran out to see if it would work with mine - nope, 3's have the outlet on the drivers side  %$#@&!
I noted your water pump hoses exit about 1-1/4" lower than mine, most likely why your trans cleared and mine did not...
Picard
« Reply #10 on: December 05, 2018, 03:43:40 AM »
Truly beautiful man. Good work!
Live long and prosper
Cape T/A
« Reply #11 on: December 05, 2018, 08:38:16 AM »
thanks!!!
skisix38off
« Reply #12 on: December 29, 2018, 07:28:05 AM »
Great thread!  Thanks for posting all the pictures, I found them very helpful now that I am swapping in an LS3.  What catch can is that?  and where did you get your fuel lines to go from the tank to the engine?
Lurk
« Reply #13 on: December 29, 2018, 11:44:41 AM »
Thanks for sharing, Nathan!  Beautiful, consistent and thoughtful work.
Ryoko
« Reply #14 on: December 30, 2018, 09:26:22 AM »
Are you running without a brake booster? Doesn't that make for a lot of pedal effort?
  • Parts vender
« Reply #15 on: December 30, 2018, 01:30:09 PM »
I am running a manual master also - once dialed in they work fine.  The Mrs. drives it occasionally, even in heels she says she has no issues stopping.
Ryoko
« Reply #16 on: December 30, 2018, 05:30:13 PM »
Interesting. I would have thought the pedal effort would be unpleasant without a booster, especially in stop/go traffic. It would be nice to get rid of the booster. I've been told there's sometimes clearance issues between the booster and the LS valve covers.
  • Parts vender
« Reply #17 on: December 30, 2018, 05:53:28 PM »
It is a bit more than power but not by much and more linear, not as sensitive.
Mark
Cape T/A
« Reply #18 on: December 31, 2018, 06:20:50 AM »
mighty mouse catch can. Www.mightymousesolutions.com is his website I think. I ordered my fuel lines from Aaron Shoaf at Scoggin Dickey.  It wasn’t a kit, I had to cut the lines and assemble the ends.
Cape T/A
« Reply #19 on: December 31, 2018, 06:44:39 AM »
thanks!!
Cape T/A
« Reply #20 on: December 31, 2018, 06:46:28 AM »
it’s harder than power for sure, but my master is made for manual brakes.
« Reply #21 on: January 17, 2019, 10:21:40 AM »
I go back and keep looking at your car. You did such a nice job on it!
Cape T/A
« Reply #22 on: January 25, 2019, 11:22:11 PM »
thank you so much!  I remember going through your swap thread long before I had the money to do mine I made a ton of notes and gained a lot of confidence to do my swap by seeing how you did yours!
