2020-B2-3
Author Topic: 79 TATA Project in VA  (Read 17163 times)
Re: 79 TATA Project in VA
« Reply #200 on: October 28, 2019, 05:21:53 PM »
He is. It's at least double the stock engine... :cool:
« Reply #201 on: October 30, 2019, 10:54:25 PM »
I would stuff the holes tight with rags and be careful cleaning around them...at least when you pullout the rags, the dirt will come with it but I would also vaccum up the loose dirt before pulling the rags out of the holes.
Someone smarter might have a better idea though!!
mereness
« Reply #202 on: November 07, 2019, 07:52:14 PM »
It has been awhile since I last updated my thread, but I really haven't made a lot newsworthy progress.  I have been cleaning up the engine in preparation to throwing some rattle can paint on it.
From the reading I have been doing, I won't need the Oil Level Sensor that sits in the side of the oil pan.  I ordered a plug from Amazon (ICT Billet P/N 551413).  When I started to thread it in it seemed like the threads were different on the plug as opposed to that of the sensor.  I do know that my engine is an early 98 LS out of a camaro.  Has anyone run into this issue?  I scoured the internet and haven't been able to find another one with different threads.
1979 TATA (Restoration has just begun)
« Reply #203 on: November 08, 2019, 06:04:47 AM »
I thought the ecm needed the signal.  Maybe I'm wrong.  I pulled the plate and drilled and tapped it, installed a 45 elbow and the 79 oil sending unit.  My car has both sending unit.  Maybe Ryan will chime in. He know more than I.
« Reply #204 on: November 08, 2019, 11:02:24 PM »
Hey! Something I might be able to help with!
  I researched that oil level sensor for my '99 F-Body LS1.  The ECM does not require that signal.  It was only used for an idiot 'low oil' light on the dash.  To plug it  I used PN 551413 from Jegs: https://www.jegs.com/i/ICT-Billet/335/551413/10002/-1.  It's listed there as 'M20x1.5' with an O-ring.
You didn't ask, but on a related note...
I also found that (at least) the 98-99 ECM's do not require a signal from the Oil Pressure sensor (The one at the rear of the intake manifold) either.  I replaced that oil pressure sensor behind the intake manifold with the appropriate sensor for my stock oil '81 pressure gauge using an adapter (JEGS PN 551172).  Because of the size of the '81 oil pressure sensor it didn't fit right into that position at the rear of the manifold. So,  I had to use a small tube to relocate the sensor itself.  I got the 'tube to relocate the oil pressure sensor' idea from the '79 Olds 403 which came stock with a tube to solve the same problem on those motors. (Sensor too big to fit in the oil pressure port).  I  have pics of that in my build post somewhere.
Hope this helps!
-Tom
P.S. Both the plug and oil pressure stuff are mentioned and pictured on page 5 of my build thread (link in signature).  And, to clarify the oil pressure sensor "in 1998-2002, the oil pressure sending units were not used by the computer, they were only used by the Body computer and gauges, in 2003+ the computer uses them".  (That info is from one of the LS Swap harness vendors.)
« Last Edit: November 08, 2019, 11:14:09 PM by TATurbo »
mereness
« Reply #205 on: November 09, 2019, 05:25:57 AM »
Tom,
Thank you for all of the info.  I will check the jegs site out and order those parts.  Since I started doing my engine I have been going to your thread for some of the great detailed information.  If you have any other info or recall any specific parts that you ordered for your swap, please send them along.  I remember when I was doing my brakes, suspension, etc you emailed me a very useful spreadsheet of the parts that you used for a reference.  Did you happen to do the same for your swap?  LOL  My engine is out of a '98 Camaro, so should be very similar to yours.
Next step is to find out a way to print both your thread and Ryan's thread so I can have them in the garage with me as I go through my swap.
As always TAC's members are the greatest resource for anyone going through an F-Body rebuild.
Thanks a ton.
Kevin
« Reply #206 on: November 09, 2019, 05:54:07 AM »
Great info Tom! It's been a while since I did mine and I didn't do half of the research you did. Thanks to Ryan, I have mine running.
« Reply #207 on: November 10, 2019, 12:58:10 AM »
I'm glad I am able to help!
I have pretty much every part I used for my swap in that spreadsheet.  There's a 'drive train' tab at the bottom of that sheet..click on that...all the engine/trans stuff is in there.  It looks like I did most of that stuff from like March '18 through Fall '18.  If the spreadsheet you have is older than that(or if you're not sure) let me know. I'll send you a new copy.
IIRC '98 and 99 are exactly the same engine wise.  The computer is a little different(but interchangable), and the '98 Temp sensor wires are different.
I ended up with a bit of a mixed bag with '99 LS1 using a later model PCM.  That's just because the wire harness package I bought came 'all inclusive' and they chose to provide a later model PCM.  Anyway...that's a whole 'nother discussion.  That place sort of left me hanging with a 'tune related' set of 'Too Lean condition' codes.
Anyway...Let me know if you want another copy of the spreadsheet. (Did I email it the last time?)
mereness
« Reply #208 on: November 20, 2019, 07:53:32 PM »
Not a lot of great or exciting news to report, but thought that I would give a quick update.  All my work in the past weeks have been concentrating on freshening up the engine.  I was able to separate it from the transmission.  Clean it up, install oil pan gaskets, intake gaskets, belly pan gaskets, oil filter, spark plugs, wires, etc.  Also, I was able to through a coat of paint on the valve covers, intake, fuel rail, and engine.
This picture doesn't reflect all of the updates.  The fuel rail and new water pump are now installed as well.  I have since moved on to freshening up the transmission.
IMG_20191112_173258897 by Kevin Mereness, on Flickr
Over the next few weeks I am hoping to relocate the oil pressure switch and install the temperature sensor, then move on to marrying up the engine and transmission to drop them back in the car.
« Reply #209 on: November 20, 2019, 10:02:47 PM »
That looks cool
« Reply #210 on: November 20, 2019, 10:08:12 PM »
Wow that looks so good! I should have done something similar but I just dropped it in the car after I removed it from the donor.
I like the color choice too.
« Reply #211 on: November 21, 2019, 08:26:47 AM »
Looks great!
« Reply #212 on: November 21, 2019, 10:39:32 AM »
Very cleanly detailed!  That should look really nice installed.
« Reply #213 on: November 21, 2019, 11:59:00 AM »
Wow, that motor looks great! Depending on what gauges you use, you probably won't need that stock oil pressure sensor. If using the stock gauges, you would use the stock Pontiac sensor, or if aftermarket you would use their specific sensor.
mereness
« Reply #214 on: November 26, 2019, 06:16:33 AM »
Thanks for all the positive responses for part of the project that I actually downplayed.  I was thinking clean it up real good, prep it, paint it, and plop it back in.  But typical me I ended up re-gasketing most of the engine without digging into the heads.  Then that lead to buying new sensors (throttle body, map, etc.).  So I will be glad getting the trans off of the engine stand, married up to the engine, and finally back in the car for now.
So moving onto the next project I have a few questions:
-What is the sensor on the tail piece of the transmission?  I can get a picture of it if someone would like.  I was just wondering if I should replace this as well.
-What is everyone else using for a fuel system (tank, lines, pump, filter, etc.) for their swap?  My car engine is a 5.7 out of a 98 Camaro if that makes a difference.
-While researching (saving?) for the fuel system I am also wondering what everyone is using for radiator and fan?
To try to let the funds build back up I bought a few things to start on the dash.  So hopefully I will be posting those pictures in the coming month.
Thanks again and Happy Holidays to all!!!
« Reply #215 on: November 26, 2019, 07:47:17 AM »
Like most I used a spectra EFI fuel tank, a Corvette fuel filter (which converts it to a returnless system) and plastic nylon fuel line (like what is used on new cars) I'll see if I can find some part numbers for you. It's been a while since I did my swap so there is probably better options out there. But that's what I did and it seemed to work.
The nylon kit below is just to give you and idea, I didn't buy that kit, I bought everything separate from my local Napa.
***edit***
« Last Edit: November 26, 2019, 07:58:19 AM by FormTA »
mereness
« Reply #216 on: November 27, 2019, 10:13:24 AM »
Thanks for the info Form.
Below is a link to the Spectra Tank.  Great Deal.  Unfortunately I do not have a Pep Boys near me and they do not ship.  The nearest store is over 2 hours one way.
https://www.pepboys.com/spectra-premium-fuel-tank-and-pump-assy-w-fn-/product/1259153/1998/CHEVROLET/CORVETTE/V8-346%20%205.7L%20GEN%20III
« Reply #217 on: November 27, 2019, 03:04:12 PM »
If you do get one, double check to make sure the sock filter didn't fall of in shipping. I heard many folks had this problem. As you can see on the picture I bought mine on Amazon in 2015. I think I paid $225 back then.... There may be better options out there now. I haven't looked.
mereness
« Reply #218 on: December 01, 2019, 05:16:22 PM »
Thanks for all the great information on fuel delivery.  It definitely gives me some numbers (cost) to shoot for.
The long weekend was a success.  The transmission got cleaned, painted, filter changed, and married back up to the engine.  From there I dropped the transmission and engine back into the car.  I am hoping that I don't have to pull it back out.
IMG_20191130_154118059 by Kevin Mereness, on Flickr
IMG_20191201_125546329 by Kevin Mereness, on Flickr
After the trans and engine were installed, I decided to move forward with the dash repair.  Thanks to some detailed threads from Roadking and others, I started to pull off the brittle portions.  Well, it seemed like what I thought wasn't going to be bad, I am going to have to repair the bulk of the dash.  I have 1 can of Padded Dash Filler, but I might just as well order another can....
IMG_20191201_123501902 by Kevin Mereness, on Flickr
« Reply #219 on: December 01, 2019, 05:32:50 PM »
Engine looks amazing! Oh wow! That dash needs some help... Good luck! I hope it come out like the engine!
« Reply #220 on: December 02, 2019, 07:20:42 AM »
Great progress!!!
I have a cap the I purchased years ago but after seeing how people are using the filler, I'm not sure what route to go...the one dash I have has little wrong with it but watching everyone fix their dashes makes me lean in that direction.
I look forward to seeing that progress
updates look great...thanks
« Reply #221 on: December 02, 2019, 07:56:48 AM »
Transplant looks fantastic! Good luck with the dash repair, ive seen worse.
mereness
« Reply #222 on: December 07, 2019, 02:43:05 PM »
Thanks everyone.
I ran across this EFI package.  Curious if anyone has any experience with this company??
https://www.classicperform.com/Complete-Fuel-Injection-Ready-Tank-Kits/fuel-injection-tank-kits.htm
« Reply #223 on: December 08, 2019, 11:09:08 PM »
The motor looks great! Congrats on getting it installed.  That's a big milestone!
  I think replacing gaskets and sensors at this stage is a smart move.  I did the same thing with mine. I've only put maybe 1200 miles on the combo there's been no problems (knock on wood).  And I was confident enough to make an 800 mi. road trip no problem.  Additionally, my brother was thankful it hasn't leaked a drop of anything on his new (at the time) shop floor.  (Having known this car many years, and having several of his own F-Bodies he was surprised it hasn't tried to mark it's territory down there.)
Regarding that fuel system kit...
I don't have any experience with that company or their kit.  But, I can tell you that the CPP kit would be much cheaper than what I ended up using. I used kits from BRP Hot Rods. They had a Tank and Pump kit for 550.00 and a fuel line/regulator kit for 399.00.  So, I spent 950.00 for my fuel system, almost twice the cost of the CPP kit you found.  The only difference might be the line. The  BRP kit uses P.T.F.E fuel line.  I think PTFE is very heavy duty stuff which might be overkill in our applications.  There are links to the BRP kit I used on that Parts List spreadsheet, Drive Train tab.
I don't see a list of parts on the CPP site, but the pic seems to show everything you need from tank to fuel rail.  For the price, it seems like a great deal to me.
Regarding the Trans sensor question...
I'm no expert on the 4L60E Transmission (or any other Transmission for that matter.  But I suspect the sensor on the Transmission you mentioned is probably the speed signal/sensor on the passenger side of the Trans tailshaft.  I don't think they are a wear item or send any signal that would inhibit getting the car fired up and running.  I did not replace mine.  It's not in a tough spot to access either, so if you did have some sort of code or trans related drive-ability issue it'd be easy enough to replace it at that time.
Congrats again on the progress...Looks awesome so far!
« Reply #224 on: December 09, 2019, 04:47:15 AM »
Wow, that looks to be a nice kit for the price.
mereness
« Reply #225 on: December 10, 2019, 05:08:18 PM »
Thanks for the input on the few deals that I came across on the fuel systems.  I still haven't decided which to move forward with.
My dash has been throwing me fits.  After the first pass with the padded filler and a sand down, I noticed that where the new filler meets the old dash that it is separating.  Has anyone else experienced this?  The only thing that I can think about is I didn't use any adhesion promoter.
IMG_20191202_175116775 by Kevin Mereness, on Flickr
After the first pass with filler and sanding, I had to order more filler.  I did go ahead with another pass of filler.  We will see if I get better results.  Any advice or tips would be great....  I am starting to consider a dash cover.
Thanks.  Have a great day.
« Reply #226 on: December 10, 2019, 10:21:14 PM »
Sorry...I got nothin' on the Dash restoration except to offer a viable plan B if problems persist....
  I used this Dash pad  overlay from Ecklers: https://www.ecklers.com/firebird-dash-pad-overlay-1978-1981-75-282286-1.html
 I was hesitant about using one of these.  I was concerned it would look awkward, show as an obvious 'cover', not fit properly or show seams. But for less than a hundred bucks I figured I'd give it a shot.  I was pleasantly surprised by the results.  Taking time to install the piece carefully and do some fit and finish work after it was glued down, we were able to get the cover to be entirely unnoticeable.  Honestly, I found it remarkable.
There are several pics of the dash in my thread beginning on page 2. (You need to click on the Photobucket pics to get full resolution.). If you're not happy with the resto results, I would definitely recommend this cover as a Plan B.
Also...
 I didn't go back to look,  but I think you asked about the cooling system earlier? If so... I used this set up from Firebird Central: PN RAD-410K
https://www.firebirdcentral.com/searchresults.asp?Search=rad-410k&Submit=. 425 for the radiator, dual fans and shroud was a decent deal I think. But you might find a cheaper solution.
 There were a few things I hadn't thought of that I had to work through...Steam Vent return line,  Hoses, Radiator mounting, overflow, and Trans cooling lines.    Let me know if you want input on those things.
« Last Edit: December 10, 2019, 10:26:51 PM by TATurbo »
mereness
« Reply #227 on: December 23, 2019, 04:18:21 PM »
Not much to report on here.  I have been knocked down with an illness.  I am getting anxious to getting back in the garage to see if I can overcome the separation from the filler and old material.  The plan is to try Roadkings suggestion of drywall tape.  I picked up a roll just before I got sick.  If I can't get this to work.  I will picking up the dash pad that TATurbo used.
One big purchase that I did pull the trigger on was the fuel system.  I found the CPP System on Ebay for $480 plus tax.  Below is the link if anyone else is looking.
https://www.ebay.com/itm/1978-81-Chevy-Camaro-LS-EFI-Fuel-Injection-Gas-Tank-FI-Conversion-Kit-90-ohm/283460956120?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Maybe next month I will start looking for a cooling system (radiator, fans, etc).
As always thanks for the great advice.
« Reply #228 on: December 24, 2019, 11:44:08 PM »
Nice find on that fuel system kit. I think one would be hard pressed to find a complete end to end kit for a better price.  Looks like a score to me.
Hope you're feeling better soon!
mereness
« Reply #229 on: February 18, 2020, 06:22:36 PM »
Finally getting some time in the garage after the holidays and an extended illness.  Although I was under the weather it didn't keep me from purchasing some parts.
I have received my battery relocation kit, Fuel System, and just yesterday my radiator.
The battery relocation kit looks to be pretty straight forward, but like everything else that I order, I will have to get some additional items.  Such as longer ground cable and an additional grommet for the ground wire to be routed through the sheet metal.
The fuel system is coming together nicely.  The sender and pump are installed.  I need to fabricate a bracket for the vent.  This shouldn't be awfull bad.  I am hoping to have that installed by the end of this weekend.  And of course I will need to purchase some wiring prior to setting and securing the tank in place
IMG_20200218_190122908 by Kevin Mereness, on Flickr
Now for the radiator.  I just cracked open the box tonight that contains the radiator, shroud, and both fans all in separate boxes.  Prior to ordering I read on some reviews that Cold Case was not making these radiators with the trans cooler ports, although on the picture to purchase the kit it shows the 2 ports.  This is the link if anyone is interested.  I though the price was pretty fair. https://www.amazon.com/gp/product/B07C9SBQGX/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
Here is a picture of the radiator.  So my next logical question is, has anyone else in this situation had to purchase a separate unit for the transmission?  If so, what do you recommend.
IMG_20200218_185331238 by Kevin Mereness, on Flickr
« Reply #230 on: February 19, 2020, 07:39:05 AM »
Great progress! I saw those Cold Case radiators when I was at Spring Carlisle last year. They looked to be very high quality. You'll like the dual pass radiator too, it really cleans up the engine bay with an LS swap.
« Reply #231 on: February 19, 2020, 09:39:51 PM »
So, do I understand you correctly that the current Cold Case 'dual pass' (inlet and outlet on passenger side) LS Swap radiators do not have Trans cooler provisions any more?  You -have- to run a separate dedicated Trans cooler? I didn't realize it was so long ago now, but I got mine back in October 2018.  It had the Trans cooler provisions but did not have the 'steam vent return' line provision.  Back then it was a surprise to me that there was no steam vent provision because it was pictured in the pic on the Firebird Central website.
I think I mentioned this before, but you might want to check to see if the fans include a pig-tail for the wiring connection.  I was annoyed that they provide a unique female 2 pin connector on their fan wires but don't provide the male side of that connector so you can neatly wire it up to the fan relays on the PCM fuse block.   Cold Case happens to be be based (or at least have a shop) just a few miles from me. I drove up there and they gave me a set of male connectors.   Obviously you could just replace them with a generic set of terminals, but still...it bugged me that they don't include them.
I don't have any advice or suggestions for a cooler, but I posted some info about the steam vent return, mounting the shroud, and mounting the radiator itself on page 7 of my build thread.
Congrats on the progress! From here it feels like you are sort of getting close to almost being ready to get ready to fire it up. ;-) Keep at it!
Oh...One more thought...
Careful installing the ground wire to the post on top of the fuel sender.  The ground post on mine broke off a lot easier than I thought it would!  It was an easy fix, but it still sucked at the time.
mereness
« Reply #232 on: February 20, 2020, 06:59:48 AM »
I did find a Trans Cooler from Jegs and of course googled the heck out of installing one.  They seem pretty simple.  I did not verify through Cold Case that they discontinued the radiator that included the transmission.  I just took my readings online as gospel.  Could be one of many errors that cost me additional money.
Tom - thanks for the tips on the radiator fan and fuel sender ground.  I will definitely be mindful when I get to them.  I am hoping to dry fit the radiator this weekend as I am sure that I will have to order some mounting hardware.
I am hoping that I am inching closer to a start up.  There are many things that I need to tie up prior to cranking the key though.
Thanks for all of the advice!!
mereness
« Reply #233 on: February 23, 2020, 05:38:54 PM »
Has anyone used these types of connections on their fuel line?  They came with my fuel line kit from CPP.  I have never seen them before and unsure if I use them with clamps or just a push fit.
IMG_20200223_144409424 by Kevin Mereness, on Flickr
