Author Topic: Admin Help with search tool  (Read 1364 times)
72fmula
« on: October 09, 2017, 05:21:41 AM »
I Keep getting a data base error message, say's I;m not logged in, tried signing out then resigning in, site is allowed to set cookies, Please help, Thanks
Re: Admin Help with search tool
« Reply #1 on: October 09, 2017, 05:31:18 AM »
I'll refer this to the site owner....I get a similar result w nI try to search....I think something is broken....its not your login at fault.
Database Error
Table './transamc_smf1/smf_log_search_results' is marked as crashed and should be repaired
File: /home/transamc/public_html/community/Sources/Search.php
Line: 1001
Ag77T/A
« Reply #2 on: October 09, 2017, 03:53:02 PM »
A work around when the search feature is broken is to use the "SITE:" search feature in google to only search for your keywords for this site.
In the GOOGLE search field type site:transamcountry.com "your search keywords"
You probably want to use w/o quotes unless your looking for that specific string or phrase.
Hope this helps. Good luck.
« Reply #3 on: October 09, 2017, 06:25:56 PM »
Interesting work around, Brian. Thanks.
MrBandit has fixed the site's search program.....apparently, this happens occasionally.
72fmula
« Reply #4 on: October 09, 2017, 07:55:15 PM »
Thanks!
Ag77T/A
« Reply #5 on: October 09, 2017, 08:34:12 PM »
Thanks!
You're welcome. Just happy to contribute.
