2020-B1-1
Author Topic: 1980 Indy Turbo 301 with failed ESC  (Read 1423 times)
TA6.6Liter
« on: May 25, 2017, 11:13:39 AM »
I know about ESC failure with the 1980 Turbo TA Indy Pace car.  I just bought one and it has that issue, so got a lower price.
Elsewhere on TAC, someone mentioned the failure was of a capacitor and that seems a simple fix. Got the car started by putting a temporary jumper in the ESC connector, which I learned from 301 Garage.  Can't drive it, but got it started which is a big step forward.
I have a source of an original ESC box, but has anyone found a way to repair the ESC or manufacture an alternative that does the same spark ~ for the turbo to prevent detonation?
Re: 1980 Indy Turbo 301 with failed ESC
« Reply #1 on: May 25, 2017, 11:32:13 AM »
Is that a 7-wire HEI distributor?  Megasquirt 2 computer are very plug n play with those.  I posted a video of one of these cars running a GM TBI instead a carb recently.  I know there's a computer for 81 models but I'm not sure about the 80.
Don't let the top picture of the computer board intimidate you!  There's prebuilt computers for this.
BlueTTA
« Reply #2 on: May 25, 2017, 11:49:48 AM »
If I remember correctly, Mini TA on the 301 garage does test and fix the ESC units.
You can get much farther with a kind word and a gun than you can with a kind word alone. - Al Capone
Chris
1979 Solar Gold T-top 403
« Reply #3 on: May 25, 2017, 12:18:25 PM »
Joe at TTA Performance would be a good source to talk to on this subject.
TA6.6Liter
« Reply #4 on: May 25, 2017, 01:53:59 PM »
If you mean the number of terminals on the ignition module that sets under the rotor, mine has five.
TA6.6Liter
« Reply #5 on: May 25, 2017, 01:56:54 PM »
Thanks. I'll sign up on the 301 Garage forum and ask Mini TA about that service.
TA6.6Liter
« Reply #6 on: June 11, 2017, 09:41:07 AM »
Located a 1980 Turbo ESC box.  Car is up and running :-D
« Reply #7 on: June 11, 2017, 03:21:24 PM »
Good Deal, hopefully the temp situation will be resolved easily. Glad to hear it cleaned up nicely.
