Author Topic: Best pass to date was a disappointing 13.1  (Read 22248 times)
hdinch
Re: Best pass to date was a disappointing 13.1
« Reply #240 on: November 07, 2018, 07:40:59 AM »
  Thanks, as for me I just dropped the trans and had it looked at yesterday...high band clutches were burnt.  So that's actually good news...now hopefully I can get some mph back and third gear will pick up at well as what I'm losing from shifts...when your trying to pick up a 1/2 second  everything counts.
I will not get back to the track until next spring but will se howi t goes...keep posting your updates..I will do the same.
Garry
« Reply #241 on: November 07, 2018, 10:09:19 AM »
Sounds good. There's one more Midnight Mayhem coming up and the end of this month & hopefully I'll get a time slip this time.
Garry
« Reply #242 on: November 10, 2018, 02:10:57 AM »
Some shots of when I installed the cage
New nitrous solenoids
New fuel pump
The last time it was at the track
silvert/a
« Reply #243 on: November 10, 2018, 08:57:10 AM »
I love to see second gens on the track. They are just a classic body style.
Mark        1978 Silver Trans Am 400 Automatic1967 Firebird 326 3 speed manual
Garry
« Reply #244 on: January 19, 2019, 11:40:27 PM »
<a href="http://www.youtube.com/watch?v=COCK67oDsqg" target="_blank">http://www.youtube.com/watch?v=COCK67oDsqg</a>
« Last Edit: January 20, 2019, 10:22:44 AM by Garry »
Garry
« Reply #245 on: March 03, 2019, 04:02:08 AM »
Another view of the same pass
 <a href="http://www.youtube.com/watch?v=So8KI4aODPk" target="_blank">http://www.youtube.com/watch?v=So8KI4aODPk</a>
Garry
« Reply #246 on: March 03, 2019, 04:14:39 AM »
That was my best pass to date and I definitely needed the cage. I got booted for no fire jacket after that one.
Garry
« Reply #247 on: March 03, 2019, 04:24:08 AM »
10.99 & quicker requires a fire jacket so it was a pretty drastic improvement.
hdinch
« Reply #248 on: March 06, 2019, 08:35:17 PM »
Nice launch..what time did you end up running?  Spray out the gate?  Looked good out the gate hard to see on the big end.
Garry
« Reply #249 on: March 07, 2019, 01:46:13 AM »
It was on a 175 shot all the way with no progressive. Time wise it did a 7.0 in the 8th and I was having problems with my shifter. I'm pretty sure the next pass would have been in the 6's.
Garry
« Reply #250 on: March 07, 2019, 11:51:15 PM »
A 7.0 in the 8th is like a 10.98 in the quarter so we totally skipped the 11's. The next move would be a 250 shot and I'm guessing low 10's. I don't really expect much more out of the car than that. I figured mid 10's on spray when I built the motor.
« Last Edit: March 08, 2019, 12:01:17 AM by Garry »
hdinch
« Reply #251 on: March 09, 2019, 03:50:52 PM »
Those are great numbers..I guess the drive train and read can handle all that?  Never used nitrous so I assume your setup is built for that or your going with just enough power that your car can handle.  Your half track look great..what did your mph end up being?
Garry
« Reply #252 on: April 13, 2019, 02:31:24 AM »
I had a minor issue the last time I had it at the track. Valve float, bent all 8 exhaust valves.
Garry
« Reply #253 on: April 15, 2019, 09:35:30 PM »
New setup is on the money for a .650 lift solid roller
Garry
« Reply #254 on: April 19, 2019, 11:23:52 PM »
Specs on the new cam.
Advertised Duration (Int/Exh): 295/303
Duration @ .050 (Int/Exh): 262/270
Gross Valve Lift (Int/Exh): .582/.582
LSA/ICL: 110/104
Valve Lash (Int/Exh): .020/.022
RPM Range: 3800-7200
I wanted to get more aggressive on the duration but it would have required more lift. With my 1.65 rockers I'm already at 640.
Garry
« Reply #255 on: April 26, 2019, 02:43:39 AM »
Scrap that last cam. Comp Cams spec'd this one out for me today. I'm probably going to order it.
hdinch
« Reply #256 on: May 30, 2019, 05:22:35 PM »
Thats fairly radical...do you install that one?  If so how is the new setup?
