Author Topic: pontiac 455 cranking problem  (Read 1182 times)
coolboy76
« on: November 24, 2016, 10:38:25 AM »
Hello everyone! i am having a weird issue with cranking my 455.  It seems to only crank 1 time, then stops, then cranks one time, then stops again.  I cannot get the motor to crank over smoothly.  Even if i remove all the spark plugs and cover one of the holes with my finger, the engine has the same problem.  If i dont cover any of the spark plug holes, the engine cranks over fine.  The engine is free and has been looked over on the engine stand.  Could i just have a weak starter?
Re: pontiac 455 cranking problem
« Reply #1 on: November 24, 2016, 11:11:03 AM »
Your stopping the engine from turning over with only one finger in one of the eight empty spark plug holes?
« Last Edit: December 20, 2016, 04:58:58 AM by 81Blackbird »
coolboy76
« Reply #2 on: November 24, 2016, 11:15:17 AM »
yes and i can only think of it being a weak battery or the starter.  I have checked the battery and switched it three times and the same problem continues.  its strange that it want to stop cranking with one spark plug hole covered.
tinpusher
« Reply #3 on: November 24, 2016, 01:47:32 PM »
Definitely electrical. I would focus on checking your ground and positive cable for hidden corrosion (ohm meter). Make sure the positive and ground wire is secure. If those items check out , I would then focus on the starter solinoid and starter. I did at one time have a internally corroded cable, same symptoms as you are describing.
tinpusher
« Reply #4 on: November 24, 2016, 01:56:43 PM »
BTW, also check the ignition key switch.
Hurst 455
  • BEAST!
« Reply #5 on: December 19, 2016, 11:27:13 AM »
Just now seeing this. I had a very similar problem. I installed a 220 mini starter and a oversized alt. haven't had any starting problems since.
THE LINE BELOW IS TRUE!
THE LINE ABOVE IS FALSE!
Brashanic_IM
« Reply #6 on: December 19, 2016, 06:32:29 PM »
crazy that you can stop it covering one hole with your finger.
besides that it sounds like very advanced timing.
but it still doesn't make sense.
