Quick mid-week update. Since it is a process for me to get out in the garage to fire up the welder and grinder, I thought I would start on some other items that have been bouncing around in my mind. After much research and great past experience with GM fuel pump assemblies, I decided that the best bet for my fuel system was to source a 5th Gen Fbody pump. They are much shorter than the 4th gen pumps(meaning that it will fit in a stock 1st gen tank), and can support well above 400 hp, and don't require any baffling, so for me that is a win-win-win! After talking with Carl at Vaporworx, I bought his kit to modify the stock assembly to run constant, vs. in stock form that would require a PWM.
So after searching around for my tank options and keeping my budget in mind, I have decided to modify my stock tank rather than the stamped Rick's tank that is all set up for the 5th Gen pump assembly. The tank that came in my car has been replaced somewhere along the line and is in very good condition rust wise. So the plan is for me to add a recessed panel into the front sump of the fuel tank, and add a factory style fuel pump mounting ring for OEM reliablity.
Here is what I am starting with. It is a 2011 SS Camaro Fuel pump assembly from a 53k mile car. I scored this on ebay for $59 bucks free shipping! Later, I will show how to modify the pump with the Vaporworx kit.
With a little research and looking around at different tanks, I found that the tank from a '07 Colorado has the same exact mounting ring dimensions as my LS3 pump. After a quick trip to the pick-a-part, my sawzall make quick work to get this little guy out!
After sketching out some dimensions and seeing what would work with this pump and the mounting ring, I had my game plan.
I wanted to get the mounting ring as round as I could, so with some "engineering", I was able to come up with this method. I was using the inner circle as my template, and fixed my grinder into position. It worked great!
Next up was getting the gasket surface as flat as I could. After giving this some more thought, I decided to use a similar method. I used my phone's level, and got the grinder perfectly level both side to side and front to back. I mounted it in place, and slowly worked the surface. Since I am going to use a Viton(r) gasket, it should take up some of the imperfections that this surface has. Overall, I was very pleased with the results from my makeshift methods... or whatever you want to call it.
And the final result.
For the final installation, it will have a Viton(R) gasket sealed up between it and the recessed panel I will be putting on my fuel tank. I will make a ring that will fit inside the tank that will bolt everything down.
That's all for now.
