Author Topic: 2nd gen TA aerodynamics and modifications  (Read 71640 times)
70RAIV455
Re: 2nd gen TA aerodynamics and modifications
« Reply #200 on: January 17, 2018, 06:46:22 PM »
Have you guys done anything for rear brake cooling ducts?
Not sure the rear brakes need anything much unless it is a roar race car that is going to do more laps than your average track day but I'm sure John will be all over it :-)
You should come over to the Vette forum with me.
The Guys will like your antics & comments.
We are a rough bunch of guys.
The Mods Love me there.
« Reply #201 on: January 17, 2018, 07:00:19 PM »
The exhaust headers create Immense amounts of heat Road racing and drag racing John.
Have to get that heat out or the engine oil temps will really skyrocket.
Without an engine oil cooler the engine will not last then.
Agreed, my tray system allows air to flow freely out between the tray and floor of the car which will hopefully keep things cool enough so I won't need additional coolers for engine oil, rear end, etc.   I will be running Hooker side pipes and the area of my tray under the headers and side pipes is aluminum.
My tray system is easily removable so the car can look normal anytime I want as opposed to under trays, splitters, and diffusers that are fastened directly to the car.
70RAIV455
« Reply #202 on: January 17, 2018, 07:03:00 PM »
OK John.
I just don't want see you have any mechanical issues.
Sharing my knowledge with You.
It just may work your ideas.
Go For it my friend.
« Reply #203 on: January 17, 2018, 09:02:42 PM »
Not quite yet. When It gets warmish enough, I'll venture out into the garage to correct the gaps depicted in the below under-hood shots :-)
The bottom shot attempts to show what I have going on in front. Most of the air entering the left marker light hole is forced through the oil cooler and out through the gap between the core support and driver side fender. Both grill sections by the headlights are blocked, so the only air entering the engine bay from the front comes through the bottom feed and marker light holes.
The area in front of the core support becomes a pressurized box at speed. The sides by the fenders needs to be blocked off (and any other openings to the engine compartment) in order for the block off you installed on the top of the core support forward to be effective. Ideally you want to seal off the front either at the core support so there is a sealed pressurized area forward of it OR by using ductwork that confines airflow from the nose to the radiator/oil cooler and brake ducts. The radiator should be sealed to the core support (or duct to bottom feeder opening) so no air can get around it.
Essentially you want to seal off the front of the car so air goes over, under, or around the car except air used for cooling things.
« Reply #204 on: January 17, 2018, 09:25:20 PM »
I'm not putting any on my car currently but have plans to monitor brake temps once I get the car back on track. I'll probably only be on track 20 minutes at a time and have huge (for rear) 14" discs so I don't think I'll have a need for rear ducts. If I was still running stock drums out back I'd probably run some ducts for track use.
1981RoadRace
« Reply #205 on: July 19, 2018, 06:28:59 AM »
Hi guys, it's been a while since I've been on (I need to fix all my pics), but I ran across a CL posting that would be if interest in this thread. Check out the aero on this guy...
https://flint.craigslist.org/cto/d/pontiac-455-super-duty-power/6639965511.html
Karl R. - Editor, Silver Blade Magazine
2008 Grand Prix GXP | 1981 Trans Am WS6 - LS3, T56 + other bits of gearhead joy.
« Reply #206 on: July 19, 2018, 06:48:20 AM »
Neat, interesting car.
« Reply #207 on: July 19, 2018, 07:13:06 AM »
Yea, there was quite a polarizing thread on PY forum about that car. It has an interesting history.
Jeremy
« Reply #208 on: August 07, 2018, 08:00:53 PM »
After reading through the thread, I worked on blocking all openings in front of the core support to force all of the air through the AC condenser and the radiator.
It made quite a difference in the efficiency of the AC.  Before, it would cool the cabin, but just barely.  After sealing off the front, the AC was cool enough that my son asked me to turn down the blower.
The engine also ran cooler with the AC on.  Before sealing everything, the engine would creep up to 200-205 in town and come back down to 190 on the highway.  The highest I saw today was 186 in town and it stayed 183 on the highway.
When you get to looking, there are quite a few openings in the core support.  I was surprised.
« Reply #209 on: August 07, 2018, 08:19:14 PM »
Thanks for the feedback Jeremy!
 Because I get so focused on  performance things like engine cooling, brake cooling, increasing down force etc. I don't think I ever mentioned the benefits for AC or automatic transmission coolers.
1976 SE SF
  • Stealing home plate on a bunt
« Reply #210 on: November 22, 2018, 10:41:19 PM »
This post is the best thing about I've ever read
No one looks this cool and still passes smog https://flic.kr/p/2buNiyP
« Reply #211 on: December 02, 2019, 03:32:47 PM »
Well thanks! This post will bump the thread up for new people to see. There's always a lack of posts around the holidays so this will provide content.
I did put my car back on the ground and roll it outside so I could tack weld the last of the frame mounts for my tray contraption to the subframe. Anyone else working on their aero stuff?
skisix38off
« Reply #212 on: December 03, 2019, 07:19:15 AM »
John - What's your intention for the car once complete?  That's time attack crazy aero there!
skizzlefish
  • new school kid who likes old school stuff
« Reply #213 on: January 29, 2020, 12:51:46 PM »
I never learned more about the concept of aero before until i stumbled across this thread. Now all im gonna be doing is figuring out how i can bottle neck all of the air hitting the front end of my car to the radiator.
John, im finishing up my wing extension but i think i might borrow your Track Jack design and figure out the inner fender ventilation ducting for it.
looking forward to the next update!
1980 Firebird Espirit "Project:Crybaby"
1971 Pontiac Lemans - SOLD
"Constantly Fantasizing about anything and everything I cant afford."
« Reply #214 on: January 29, 2020, 10:47:42 PM »
There's plenty of air pressure at the front of the car. To increase cooling capabilities look to reducing the air pressure in the engine compartment so more air moves through the radiator and make sure you have a properly sized radiator for the modified engine. Trying to "bottleneck" air to the radiator by fabricating duct work or other means won't have as much of an effect as reducing under hood air pressure. AND there's a possibility you may increase drag and actually slow the car down depending on the modifications done trying to channel air to the radiator.
The modified fender vents like the Track Jack are one means of reducing under hood pressure. Vents in the hood itself would be another. Both require that other things are taken care of first to get the most gain, like sealing off the core support, cowl seal, etc.  The ducting I was working on for inside the fender would improve flow to the vent openings but would be a lot of work for the gains I'd expect. The highest pressure air under hood is by the firewall so my duct was a design to create a smooth transition from the area by the firewall to the vent opening. This would speed up the airflow Vs. no ducting thereby allowing a larger volume of air to pass out the vent during a particular time period.
Did you get the Hydroboost set up?
Send me a PM.
« Reply #215 on: February 06, 2020, 06:55:58 PM »
Link to a good short entry level article about aero by Steve Stafford. He's a race car aerodynamicist currently working in NASCAR. https://grassrootsmotorsports.com/articles/aero-mythbusting-tackling-bad-questions-bad-info/
skisix38off
« Reply #216 on: February 07, 2020, 07:17:02 AM »
Good article- thanks for sharing!
« Reply #217 on: February 07, 2020, 07:46:31 AM »
Agreed,
I always had a lot of assumptions with out giving much thought to it.
Thanks for sharing that!!
(20 years and counting but still have her)
MalteseFalcon
« Reply #218 on: September 15, 2020, 07:50:32 PM »
Block off:
Here's another one. This one is on a Fire Am built by Matt Adams and Jim Haller:
Steve
1978 WS6 - W72 4 Speed, Martinique Blue on Light Blue - Fire Am Restification Project
2000 WS6 6-Speed Trans Am, Black on Ebony (sold
« Reply #219 on: September 16, 2020, 12:23:28 AM »
That FA one is neat, almost stock in appearance for anyone who didn't know. It belongs there rather than the clearly added stainless sheet of the race car. Even if it had nil purpose on a road vehicle, it could be marketed as a bolt-on for those who like the cleaner look. Is Matt any relation?
« Last Edit: September 16, 2020, 12:27:06 AM by Wallington »
MalteseFalcon
« Reply #220 on: September 16, 2020, 08:14:51 AM »
It is, but as far as I know it's a one-off.
Matt Adams is Herb Adam's son.
Steve
