Author Topic: Today I...  (Read 773568 times)
Vroom_vroom
  • ka-kawwww
      • my build thread
Re: Today I...
« Reply #880 on: January 17, 2016, 02:48:22 AM »
End of the year it's getting the boot! TKO time!! Woop woop
'77 T/A Poncho 400-4spd.|kre-d port heads|comp hydro. roller valve train|scorpion 1.5rr|800 smi q-jet|tomahawk forged I beams|kb flat tops|OER 15x8 snowflakes|rpm intake&drop base|try-y headers|pypes kit|champion 4 core|rancho sways|Subframe connecters|
'11 sierra 6.2 4x4
"13 avenger
77 TA man
Re: Today I...
« Reply #881 on: January 18, 2016, 01:41:29 PM »
The LT-1/Auto Z/28s have caught my eye now, and they're not too bad with $1,100-1,500 for a driving example.  I looked at a '94 that'd been smashed  in the nose and needs a new bumper, hood and driverside fender but the guy wanted too much for it. I'll get one here in about 3 months or so.
« Last Edit: January 18, 2016, 01:43:50 PM by 77 TA man »
1986 T-Top T/A:
Casey
Re: Today I...
« Reply #882 on: January 18, 2016, 02:40:18 PM »
Donor or new project?
77 TA man
Re: Today I...
« Reply #883 on: January 18, 2016, 02:50:44 PM »
as a daily driver. Only requirements are Z/28 and T-Tops.
1986 T-Top T/A:
Casey
Re: Today I...
« Reply #884 on: January 18, 2016, 04:38:17 PM »
Well there are plenty of 4th gen Z28s and Trans Ams with T-tops and automatics for comparatively little money and in decent shape.  It only becomes a headache if you're like me and will only buy a 6-speed car and preferably without T-tops at that.
Re: Today I...
77 TA man
Re: Today I...
« Reply #885 on: January 18, 2016, 04:51:47 PM »
I'm changing my requirements slightly in that there needs to be no doors and back damage.
After checking around it seems like the blue '94 is the best one. All others needs trans or interior or went off the road and hit a guardrail and tore off a door..etc
1986 T-Top T/A:
Casey
Re: Today I...
« Reply #886 on: January 19, 2016, 12:43:15 AM »
'93 was the only year with MAP instead of MAF, and then Opti-Spark was revised and a vacuum vent added in '95 or '96?  The Camaro especially I rather have a LT1 car, the Firebird I like both but I lean more towards the LT1 though.
77 TA man
Re: Today I...
« Reply #887 on: January 19, 2016, 08:03:51 PM »
the Vented Opti was introduced in '95. I scraped a spot of thick bondo off my trunk pan and guess whats under the layer of bondo? A patch work of galvanized sheet metal patches that are rivited together on top of the old metal. Turns out most of my trunk pan is galvanized sheet metal. At this rate the car will need a full blown restoration before I even think about driving it.
1986 T-Top T/A:
Casey
Re: Today I...
« Reply #888 on: January 20, 2016, 06:09:18 AM »
What's worse is what can be hiding under the exterior sheet metal at this point...  That's ok, if I ever manage to sell the Firebird I'm not sure if I want to bother taking a chance on a fourth gen as it seems like constantly the T56 of all transmissions has issues because for some reason people have to beat the hell out of their car.
77 TA man
Re: Today I...
« Reply #889 on: January 20, 2016, 10:00:42 PM »
.  I'm not sure there is any sheet metal at this point....case in point my passenger rocker. Full length front to back of pure bondo. I was doing some body work and found bondo on the doors and thats what scares me, if I find out the full extent of it I'll probably need new doors too before I can drive it.  I saw an LT-1 Z/28 with T-Tops for $1,700....missing 3rd,4th and 5th gear on its T-56.
1986 T-Top T/A:
  • Parts vender
      • Scarebird Classic Brakes
Re: Today I...
« Reply #890 on: January 20, 2016, 10:52:42 PM »
Revising 1980 dash harness for AC and Speedhut gauges.
Casey
Re: Today I...
« Reply #891 on: January 21, 2016, 09:13:06 PM »
If I had a car to transplant my motor into I'd offer to sell you the roller for cheap.  Yeah it's a pain to find one and it seems like when they do pop up for sale there's something wrong with the synchros and/or gears.  Supposedly the T5, T45, and TR3650 are much weaker but I've seen less Mustangs with gearbox issues and there were a lot more of them made, especially with a manual.  I would've bought a '94-95 or '99-04 but the cable clutch was just too much for my knee.
Re: Today I...
« Reply #892 on: January 23, 2016, 03:18:12 PM »
Just bought my next project car... 72 Lemans convertible
1970 Firebird
Re: Today I...
« Reply #893 on: January 23, 2016, 03:52:57 PM »
Nice car Jim, I think you said you were looking for a first gen firebird, but I think you did good with that one.
1975 ta
Re: Today I...
« Reply #894 on: January 23, 2016, 04:40:09 PM »
very nice!
Re: Today I...
Vroom_vroom
  • ka-kawwww
      • my build thread
Re: Today I...
« Reply #895 on: January 23, 2016, 05:50:07 PM »
Finished switching all the interior lights over to led bulbs
'11 sierra 6.2 4x4
"13 avenger
77 Pontiac
Re: Today I...
« Reply #896 on: January 23, 2016, 06:18:05 PM »
Started installing poly bushings in my leaf springs, got the kit from energy suspension with heavy duty shackles - only to find out that their kit does not include the front eye bolts - only the 4 rear bolts were supplied.. Why would they possibly do that when you order a kit with bushings for both the front and rear of the spring?
« Last Edit: January 23, 2016, 06:20:34 PM by 77 Pontiac »
Pats TA
Re: Today I...
« Reply #897 on: January 23, 2016, 06:23:45 PM »
Shoveled SNOW
Pats TA
Re: Today I...
« Reply #898 on: January 23, 2016, 06:29:41 PM »
  Nice Lemans, a neighbor down the road has a 71 or 72 blue convertible GTO. I don't see it much anymore since he had his pole building built.
Re: Today I...
« Reply #899 on: January 23, 2016, 07:00:18 PM »
I have been looking real hard for a first gen, but I couldn't find what I was looking for a suitable price, I saw one or two but they were snagged up real quick. I think I got real lucky on this one. The price was right for a resto project (atleast for me) plus I have always liked the Lemans/GTO.
1970 Firebird
DeCaff2007
Re: Today I...
« Reply #900 on: January 24, 2016, 08:41:55 AM »
Went through that same thing myself during my resto.  Yeah what pain that was.
As for me, Yesterday I was bedridden for 90% of the day.  Had a fever of 100.4 degrees. That SUCKED.  I drank water/dayquil/nyquil all day.  Went to bed at 8:30  :shock: and woke up 13 hours later, laying in my own sweat and shivering... but felt A LOT better!
So Today I... had a good breakfast and might actually try to be productive.
Only bad part is my sinuses are still blocked.  Everyone is telling me to try either Mucinex or Zyrtec.  Those are both for allergies/chest congestion.  What I need is an antibiotic.  Hehe try getting decent medical care when you are 600 miles from home, on business.
77 Pontiac
Re: Today I...
« Reply #901 on: January 24, 2016, 10:20:10 AM »
Sounds like a bad case of manflue - if you see a bright light don't walk towards it :)
Do you remember where you found a new bolt for the front spring eye? Might try ebay uk, as that would save me yet another overseas shipping and handeling fee.. Im starting to think that reason so many shipping companies exist is directly related to the amount of gearheads that keeps shipping large heavy boxes around the world
Re: Today I...
« Reply #902 on: January 25, 2016, 07:05:29 PM »
Shoveled more snow :shock:
DeCaff2007
Re: Today I...
« Reply #903 on: January 25, 2016, 07:19:36 PM »
Sorry, gotta laugh.  The woman got stuck with all the snow shoveling this time around.
I know karma is a b*tch but for now I'm laughing it up.
With that, Today I...  am suffering through day 5 of completely clogged sinuses.  No fever anymore but wow this sucks.  I've tried sudafed, pseudoephedrine, MuscinexC, Zyrtex. Dayquil, Nyquil...  NOTHING will clear these sinuses.  On a whim, I took a few shots of Afrin... FINALLY can breathe through my nose!!  Only problem is I've read not to take this crap for more than 3 days.   Ruh Roh.....
79merlin
Re: Today I...
« Reply #904 on: January 26, 2016, 09:01:20 PM »
You could try smearing a little bit of Vicks Vapo-rub under your nose (i.e.on your upper lip) right before going to bed. That usually helps me if my sinuses are plugged.
Todd
Casey
Re: Today I...
« Reply #905 on: January 27, 2016, 01:14:51 AM »
Eat some spicy peppers/sauce or some wasabi to clear it out, then use a source of menthol to open and soothe the sinus passages.
DeCaff2007
Re: Today I...
« Reply #906 on: January 27, 2016, 05:31:26 AM »
Man... I would something to smoke right about now.  Too bad I quit that stuff years ago.
Pats TA
Re: Today I...
« Reply #907 on: January 27, 2016, 08:56:28 PM »
Filed my taxes.
VANSD455
Re: Today I...
« Reply #908 on: February 02, 2016, 03:10:29 AM »
Any updates on the LS shaker
  • Parts vender
Re: Today I...
« Reply #909 on: February 02, 2016, 05:54:49 PM »
Ready for LS3 orders.  This type uses the blade style MAF sensor and goes over the top like our prototype.
Casey
Re: Today I...
« Reply #910 on: February 03, 2016, 06:03:45 PM »
Someone is supposed to be picking the car up Friday. Their brother? had stopped by the day before to get pictures and ask about it and he contacted me yesterday. Seems serious since today was asking about the transmission and saying was wanting to already get the parts to fix it. I'm not entirely sure how to feel.  Hopefully I can find a 5-speed third gen or 6-speed fourth gen to fill the void.
hakitup
  • What more do you need?
Re: Today I...
« Reply #911 on: February 05, 2016, 09:42:55 AM »
Hope it works out, today I drove the car in notice a couple of new rattles in the doors. Friday and driving the Trans Am........perfect day!
Tom H
Casey
Re: Today I...
« Reply #912 on: February 05, 2016, 02:50:41 PM »
Thanks, he should be here in the next few hours to get it.  After having so many people flake out it's almost surreal to have someone actually going through with it.  He said on his own he'd give it a good home and that he's been looking for one for some time now, so at least there's solace in that.  I couldn't sleep last night and I'll probably be depressed for the next week or two.  It's not exactly how I wanted one, but I've ALWAYS wanted a '79-81 Firebird and it's just aggravating I don't have the place to do what I want to with it.  I could just hold onto it until then but I don't want it to just end up sitting for who knows how long.  Which I checked Craigslist and that didn't do anything to help, not the first manual bird out there unless I have $10,000+ for a late model fourth gen. :cry:
Casey
Re: Today I...
« Reply #913 on: February 05, 2016, 06:29:21 PM »
Well, it's officially gone now... :sad:
79GoldnTan
Re: Today I...
« Reply #914 on: February 05, 2016, 07:48:34 PM »
Mmmm. Bumming.  Wasn't looking for a trans am when I got mine,just fell into it, now I don't think I could let it go. Keep your head up something will come along.
79 solar gold
461.   Factory 4 speed
PTFB SFC
PTFB 1LE
3.08 rear  for now
Lots O Fun
DeCaff2007
Re: Today I...
« Reply #915 on: February 06, 2016, 02:55:13 PM »
Today I... started the long, arduous task of sorting out the electrical issues in my basement.  It has been needing to be done for YEARS now, so since I'm waiting on T/A parts, I figured I'd start the next house project.
lskip10
Re: Today I...
« Reply #916 on: February 06, 2016, 06:55:58 PM »
Fired the bird up, let her warm up good, 46 degrees and sun in Illinois in Feb, ....getting itchy to drive :-D
  • Parts vender
Re: Today I...
« Reply #917 on: February 06, 2016, 08:57:31 PM »
Drove the T/A to the local Lexus dealership for research on a possible electric master cylinder.  The 450h has an electrically boosted master and seem to work well.  The T/A looked like a swan amid all those fugly Lexus' grilles...
tonyTA
  • 45acp
Re: Today I...
« Reply #918 on: February 07, 2016, 06:03:17 AM »
Today I.........really miss driving the TA. Cold and snow please go away.
Casey
Re: Today I...
« Reply #919 on: February 07, 2016, 03:26:03 PM »
I'd take a RC-F if it came with a manual.
Re: Today I...
