Author Topic: Today I...  (Read 785046 times)
Casey
Re: Today I...
« Reply #800 on: December 16, 2015, 05:29:05 PM »
Outside of the cooling system stuff which I'm sure you've run through everything the only other thing off the top of my head that could cause it would be detonation and/or over advanced ignition, or being an automatic the transmission fluid running through the radiator can cause it run hot which putting in a cooler in parallel or if in a warm enough climate just the cooler, can help as well.  Strange it happened after the rebuild, I would say perhaps too much mechanical friction from tolerances being off but I'd imagine that'd have shown signs elsewhere by now.
I thought GTA mesh rims look nifty, now they have 17 reproductions. :cool:
Re: Today I...
« Reply #801 on: December 16, 2015, 09:09:00 PM »
OK guys, sit down for this one, I made a major accomplishment. I put black tape insert into one (not two) of my door handles. I ordered these and they came in for the short handles, of course my car has the long handles. I don't know why they don't sell these for the long and then they can be cut if you have short handles. Anyway, I got some black decal from a sign shop and cut it to fit. I haven't had time to turn around lately, and had this stuff sitting for some time, finally had a minute and decided to do one and see how it looked. At this rate I may have the car done about the third week of NEVER!!!
DeCaff2007
Re: Today I...
« Reply #802 on: December 16, 2015, 09:32:24 PM »
Normally, I have to get up for work at 5 am.  Today I... had to BE at work for 5 am  :shock:  Then I worked until 4:30 and went to job #2 for 6 pm.   LoL thought I was only supposed to be there until 9 pm but it was actually 10pm!!!  Needless to say I'm overtired.
The good news is that those 2 hours of over time this morning were voluntary.  I just wanted to see if I could actually still do it.
I'm NEVER doing this again.
77 TA man
Re: Today I...
« Reply #803 on: December 16, 2015, 09:49:55 PM »
Trans Am wise I started sanding on the driver side 1/4 panel and the center spoiler section.
Non Trans Am related: its the middle of exam week and exam reviews and eagle scout paperwork is piling up. Its going to be a long night.
1986 T-Top T/A:
77 TA man
Re: Today I...
« Reply #804 on: December 16, 2015, 11:49:09 PM »
And just finished with all the night's paper work, May 17th cant come fast enough IMO.
1986 T-Top T/A:
Re: Today I...
DeCaff2007
Re: Today I...
« Reply #805 on: December 20, 2015, 06:18:18 PM »
Today I... finally fixed the exhaust leak in the flex pipe on my fathers HHR.  Man those things are junk.  Whole job took about 4 1/2 hours.  That's from the pulling in the garage, a parts run, welding/grinding, and exiting the garage.  The hardest part was indexing the new flex pipe with the existing exhaust.  I even took the time to grind down my welds this time.  I wanted it to look half decent (where normally I don't care how exhaust looks, as long as it seals)
Only thing that kind of ticked me off is that my father didn't show up until after 12 pm.  I would have liked to have started that job @ 9 am sharp.
cal30_sniper
Re: Today I...
« Reply #806 on: December 20, 2015, 06:36:00 PM »
Today I did some big time sand blasting. I bought a hanging tent to go inside my 10x10 Canopy from Academy, and hooked my Harbor Freight blasting cabinet sandblaster to a detachable air line and a 5 gallon bucket full of 80 grit black diamond. Works wonderful on stripping the paint off of the endura. I tried 80 grit glass beads first, but that was painfully slow, so I switched to the diamond and found it works much better.
And, while I took breaks, I gawked at my Christmas present:
'73 Formula 350
'88 Trans Am GTA L98
'86 Suburban C20 454/NV4500
Formula build thread: http://transamcountry.com/community/index.php?topic=75375.msg705571#msg705571
77 TA man
Re: Today I...
« Reply #807 on: December 20, 2015, 08:23:38 PM »
Today I found out that effectively anything rear of the doors and lower than the deck lid is effectively bondo, fiberglass netting, or rust and/or any combination of the three. With the things thats been done to this Trans Am you'd think it would kill somebody to fix something the right way.
1986 T-Top T/A:
TA6.6Liter
Re: Today I...
« Reply #808 on: December 20, 2015, 09:09:44 PM »
Between my wife and me, we removed the tiny stones and grim from my 77 gas pedal.  Not as much fun as changing a tail light bulb, but hey, it is all time well spent.
ddmurdock
Re: Today I...
« Reply #809 on: December 20, 2015, 11:18:45 PM »
At least you got your wife involved, I had to change the tail light bulb with no help or encouragement.  :sad:
1977 SE Y82 L78
1995 Y82
1998 WS6 SGM 1 of 26
Re: Today I...
Casey
Re: Today I...
« Reply #810 on: December 21, 2015, 02:08:11 AM »
That's because most people are scum and would rather do cheap shoddy repairs and hide things to try to sell it than be up front and honest and sell it as it is for less.
Spoon
Re: Today I...
« Reply #811 on: December 21, 2015, 04:42:16 AM »
77 TA man - sorry to hear about the body work. Hope you can get it sorted out.
DeCaff2007
Re: Today I...
« Reply #812 on: December 21, 2015, 07:19:44 AM »
Oh wow man.  Been there, done that.  I am permanently retired from sandblasting.
cal30_sniper
Re: Today I...
« Reply #813 on: December 21, 2015, 07:38:47 AM »
It's not too bad. I cover my entire body with a hoodie and coveralls, throw on a respirator, goggles, and earplugs, and I bought a plastic faceshield from Lowe's to go over that with a headlamp I strapped to it (makes it a lot easier to see when the shield starts dusting up).
My biggest pet peeve right now is the "super nice" 1/2" NPT PneumaticPlus air pressure regulator I bought from Amazon failed after 2 months of periodic usage. It's now leaking air like crazy. I tore it down to attempt to find the problem, but it does not appear to be reparable. It doesn't look like amazon will honor any kind of manufacturer's warranty, so I imagine its going to be tough to get that back. I ordered a new one from McMaster Carr last night, but I'll be pretty much down until I get that fixed. Guess it's back to sanding for a few days.
'73 Formula 350
Re: Today I...
« Reply #814 on: December 21, 2015, 10:33:34 AM »
Put my order into "Santa-Year One " for discounted parts
Re: Today I...
77 TA man
Re: Today I...
« Reply #815 on: December 21, 2015, 10:58:42 AM »
Bondo is like an iceberg, what you can see is just the tip. This 1/4 should be saveable with a lower patch panel but both rear inner 1/4s need replaced. Somebody has gone through already and used deck screws in an effort to keep the badly rusted inner 1/4 attached to the outer skin
This one is to be expected,
There is a lot more bondo on the passenger side rocker, at least it ran/moved and has solid frame rails.
« Last Edit: December 21, 2015, 11:01:00 AM by 77 TA man »
1986 T-Top T/A:
cal30_sniper
Re: Today I...
« Reply #816 on: December 21, 2015, 11:25:46 AM »
That looks incredibly similar to the repair work I found on the 78 I used to have. I was washing it one day and a 4" tall section that ran the entire length from the rear bumper to the wheel well fell out. It was pure bondo with a sheet of galvanized plate backing it up. I later found that the rear floor pan was a piece of tin roof held in by rivets and aquarium sealant.
I can thankfully say that only spot of rust in my entire car is now a quarter sized soft spot in the driver front fender. Just finished the trunk pan replacement and a-pillar/window channel repairs this week. It's so nice to see clean metal everywhere again.
'73 Formula 350
Casey
Re: Today I...
« Reply #817 on: December 21, 2015, 02:16:26 PM »
At least what little rust on mine is isolated to the pans and decklid, of course being anal I'd want to replace the entire pan versus just patching the one section.
I asked Santa for a T10, maybe there'll be one under my tree in a few days.
79merlin
Re: Today I...
« Reply #818 on: December 21, 2015, 04:24:13 PM »
There happens to be one for sale on pro-touring...
http://www.pro-touring.com/threads/118611-Borg-Warner-Super-T10
Not mine so I don't know anything about it...
GL.
Todd
Casey
Re: Today I...
« Reply #819 on: December 21, 2015, 06:21:55 PM »
I wonder if he takes payment in the form of Trident Layers...
Re: Today I...
77 TA man
Re: Today I...
« Reply #820 on: December 22, 2015, 12:46:23 PM »
I'm going to need a driverside inner 1/4 now that the bondo seal is removed
and....
100% Pure Bondo with a side of fiberglass
1986 T-Top T/A:
Casey
Re: Today I...
« Reply #821 on: December 22, 2015, 06:46:19 PM »
Ugh...that makes me sick.  Especially on a unibody car for people to do that crap should be a crime, it compromises the safety of the vehicle...
77 TA man
Re: Today I...
« Reply #822 on: December 22, 2015, 07:14:33 PM »
I went back after posting this and picked at it some more....It has 2 or 3 tin pieces on the inside holding everything together along with the bondo. Really shoddy job.
1986 T-Top T/A:
77 Pontiac
Re: Today I...
« Reply #823 on: December 23, 2015, 01:37:21 AM »
Seems like your car is trying to look like a corvette, with all that fiberglass..
Will you be able to mount new quarters by yourself?
77 TA man
Re: Today I...
« Reply #824 on: December 23, 2015, 08:59:23 AM »
I'm actually going to have my dad help me on that.  The thing is I wanted a '62-'64 Nova or a late 1960s Chevelle for a project car. I think that in addition to a more expensive vehicle that one of those would be in similar if not worse shape than my Trans Am
1986 T-Top T/A:
Re: Today I...
« Reply #825 on: December 23, 2015, 03:18:40 PM »
Got my Christmas Packages from Ames and Year One!! Should be most of the small bits I need to finish the int. Hopefully i'll have some time soon to get things going.
77 TA man
Re: Today I...
« Reply #826 on: December 23, 2015, 03:47:18 PM »
I pulled an 8"x6" piece of bondo out
Inner structure is intact and rust free so far as I can tell
1986 T-Top T/A:
  • Parts vender
      • Scarebird Classic Brakes
Re: Today I...
« Reply #827 on: December 23, 2015, 04:58:30 PM »
Fabbed up a fusible link fuse block out of UHMW on the mill.
cal30_sniper
Re: Today I...
« Reply #828 on: December 24, 2015, 12:04:29 AM »
Today I did lots, and lots of sanding...
I also got a bunch more sandblasting done. I should be able to finish up the front bumper tomorrow. Endura soaks up the blast like nothing I've ever seen before. It is a very slow process to get the paint off. I was beginning to dread blasting all the other stuff I'm planning on, until I hit some of the metal on the bumper. The metal stuff literally goes 10x faster. When you're blasting the Endura, you can actually see the paint being removed as the media hits, bit if you move the blaster too soon, the paint color comes back. All I can figure is the Endura is so porous and flexible that it bends under the pressure of the blaster, and when you remove the pressure it stops deforming and a new angle of the paint surface becomes visible. I've found that a very high blast angle, nearly parallel with the surface works best. If you try to blast at a 45-90 degree angle from the surface, it is almost completely ineffective.
Here's my super high-tech, protect the pilot eyes at all costs, sandblasting outfit:
'73 Formula 350
DeCaff2007
Re: Today I...
« Reply #829 on: December 24, 2015, 10:34:38 AM »
Cal30: Been there, Done that.  I'm permanently retired from sandblasting. Tooo much of a pita to get set up and then clean everything up when reloading media or the project is done.
Re: Today I...
cal30_sniper
Re: Today I...
« Reply #830 on: December 24, 2015, 12:16:22 PM »
I am getting rather tired of vacuuming up the fifty pounds of sand from the floor every 30 minutes or so. A will give a big thumbs up to the dust deputy that I bought though. You can seal it to a 5 gallon Lowe's paint bucket and put it inline between the shop vac and the hose you are using to vacuum. The media spins around inside the dust deputy and falls into the bucket, leaving your shop vac filter and bucket clean. I would have quit already if I didn't have that thing, haha.
Bumper is halfway down to endura. Hoping to get the other half done this afternoon. I can't wait to get on to the metal panels, they just go so much faster.
'73 Formula 350
DeCaff2007
Re: Today I...
« Reply #831 on: December 25, 2015, 06:57:49 AM »
I'd be interested in seeing pics of this setup if possible.
Edit:  Today I... Got an email notification from Rock Auto that the AC Delco reman distributor is now in stock.  Couldn'tpass it up for the price.  Bought myself an xmas gift :-)
« Last Edit: December 25, 2015, 12:24:27 PM by DeCaff2007 »
Spoon
Re: Today I...
« Reply #832 on: December 27, 2015, 03:29:41 AM »
Best wishes with your training. Give us some updates as you go.
EOD9339
Re: Today I...
« Reply #833 on: December 29, 2015, 05:53:52 PM »
Did the PITA heater core. Man I don't wish that job on anyone. Since I made the car A/C delete I thought I could just by a non A/C heater core, nope. They use different holes. So I got the A/C core and shortened the one snout. Got the heater box together only to find the one vacuum line was dry rotted. Of course it was the line that goes inside the heater box. Then I was tightening the lower hose clamp (the hard one to get to) when the clamp broke, ugh.
But it's done. Funny thing. Went for a test drive to make sure no leaks. Came to a stop sign and decided to have some fun. Pulled out sideways with rubber burning and smoke bellowing. Coming the other way was a 74 formula, dude had his hand out the window giving me the thumbs up as I past.
Spoon
Re: Today I...
« Reply #834 on: December 29, 2015, 06:38:46 PM »
Funny story!
Heater core replacement = good times.
TA6.6Liter
Re: Today I...
« Reply #835 on: December 29, 2015, 06:57:31 PM »
I put my 98 into its winter hibernation :sad:
Casey
Re: Today I...
« Reply #836 on: December 29, 2015, 08:55:59 PM »
I much rather do the heater core than the transmission, should've arranged that somehow. :P
b3nny
      • My TA
Re: Today I...
« Reply #837 on: December 29, 2015, 09:19:09 PM »
I did rotors and pads all the way around on my F-150 yesterday. Am i supposed to feel beatup the next day?
1980 Turbo TA (Olds 403)
My TA
DeCaff2007
Re: Today I...
« Reply #838 on: December 29, 2015, 10:13:37 PM »
Oh I don't want to hear it!  We all know I'm smack dab in the middle of a transmission rebuild...
Today I had one LONG azz day.  Tried to fit tooo many things into an 18 hour period.  I'm quite tired.  I guess I'll go to bed.
Casey
Re: Today I...
« Reply #839 on: December 30, 2015, 01:13:40 AM »
Want to rebuild mine too?  I pay in cash and booze.
Re: Today I...
