Author Topic: Today I...  (Read 696863 times)
Casey
Re: Today I...
« Reply #600 on: October 20, 2015, 04:36:10 PM »
Today (really yesterday)
while touring a friends engine shop I saw a Ford Aftermarket performance engine block, that he said was stroked out to 590 C.I.D! I put my hand into a fist and put it in a cylinder and the cylinder wall wasnt even close to touching my hand! Just massive bores on that thing.
Pffffftttt.......
DeCaff2007
Re: Today I...
« Reply #601 on: October 20, 2015, 06:38:50 PM »
Pffffftttt.......
LOL @ pffftttt!!!!!!
77 TA man
Re: Today I...
« Reply #602 on: October 20, 2015, 07:04:46 PM »
So back to my mess of a Pontiac 400, timing gears and distributor are in the right positions so timings out.
Somebody suggested doing a compression check but it ran solid before and we didnt take the heads off, just took rocker arms off. Can an engine just loose compression sitting on a stand? Oil comes out of the lifters, valves open and close properly. New HEI distributor, plugs and wires, fresh gas. Just cranks and cranks and cranks.
« Last Edit: October 20, 2015, 07:06:23 PM by 77 TA man »
1986 T-Top T/A:
Casey
Re: Today I...
« Reply #603 on: October 20, 2015, 09:59:21 PM »
I just had someone offer me a 2001 Accord Coupe 5-speed, that's the first offer somewhat close to what I'm looking for.  Supposed to have someone look at it Saturday and someone was supposed to today but they ended up having to take their mom to the hospital and plans to set up another day to see it.
If timing is right and you're getting spark then that'd leave lack of air or fuel.
77 TA man
Re: Today I...
« Reply #604 on: October 21, 2015, 05:05:49 AM »
Then my suspicion would be the orignal carburetor as the problem.
1986 T-Top T/A:
Re: Today I...
pancho400cid
  • Viva los PONCHOS!
Re: Today I...
« Reply #605 on: October 21, 2015, 10:56:41 AM »
Why not post this question in the "Mechanical section".
The engine won't lose compression "per se".  Did you put a compression gage on it?  If it "for sure" has low cylinder pressure, most likely something is off with the valve adjustment (pushrods/rockers holding one or both valves open).
I see it is a Pontiac 400.   Does it have a stock valve-train (non-adjustable) or aftermarket (adjustable) valve-train?
« Last Edit: October 21, 2015, 10:59:12 AM by pancho400cid »
77 TA man
Re: Today I...
« Reply #606 on: October 21, 2015, 01:23:28 PM »
I did awhile ago, its not quite stock with a aftermarket cam and lifters and noisy gear drive but still uses the stock 4X heads.
« Last Edit: October 22, 2015, 09:11:17 AM by 77 TA man »
1986 T-Top T/A:
  • TAC Webmaster
Re: Today I...
« Reply #607 on: October 21, 2015, 02:46:44 PM »
....Rebuilt the frontend site for TAC.
pancho400cid
  • Viva los PONCHOS!
Re: Today I...
« Reply #608 on: October 21, 2015, 08:33:04 PM »
Looks Great!  Thanks!
72projectbird
Re: Today I...
« Reply #609 on: October 22, 2015, 09:11:11 AM »
Went to Providence, right in the heart of the ghetto, and picked up another set of Recaro seats. I'll recover these ones in black leather and take my 81 Recaros and put them back in the Daytona.
70 GTO 455
71 Trans Am LS Swapped
79 Trans Am SE 301 4 Speed
81 Trans Am Daytona
"Put the evidence in the car"
pancho400cid
  • Viva los PONCHOS!
Re: Today I...
« Reply #610 on: October 22, 2015, 10:36:32 AM »
Nice...  Those should look VERY nice covered in black leather... (like a girl I used to know!!!   :lol:  )
72projectbird
Re: Today I...
« Reply #611 on: October 22, 2015, 10:45:37 AM »
Both things look great in black leather!  8)
I plan on all black leather, but in the center inlay I want to do a diamond stitch pattern. I'll use all black thread, I don't want them to look too crazy. The best part is the netting in the headrests is perfect! And both seats were only $100.
70 GTO 455
81 Trans Am Daytona
pancho400cid
  • Viva los PONCHOS!
Re: Today I...
« Reply #612 on: October 22, 2015, 10:51:58 AM »
Sweet deal.  Good on you for seeing the diamond in the rough.
Casey
Re: Today I...
« Reply #613 on: October 22, 2015, 10:58:47 AM »
When I think O.E. Recaro's I think these:
If it doesn't hug you in place without belts there's not enough bolstering. :lol:
72projectbird
Re: Today I...
« Reply #614 on: October 22, 2015, 12:13:53 PM »
Surprisingly these seats really hold you in good despite the fact they're from the 70's/80's.  They're very comfortable too.  :cool:
70 GTO 455
81 Trans Am Daytona
Re: Today I...
Casey
Re: Today I...
« Reply #615 on: October 22, 2015, 03:28:33 PM »
I imagine they're worlds better than the standard seats, but the bolstering looks lacking for a Recaro.  I'm sure someone there at the time was like, Americans... oi vey... :lol:
Re: Today I...
« Reply #616 on: October 22, 2015, 04:05:50 PM »
72 project, those are exactly like the ones that were in my car when I got it, except mine were tore pretty bad. I gave them away to a guy. I wish I would have held on to them sometimes.
Lucky Phil
Re: Today I...
« Reply #617 on: October 24, 2015, 03:46:22 AM »
Today I did nothing to any of my cars....hmmmmm
But my wife made me do tiling...... :???:
Tomorrow will be all mine....mine I tell you..... :lol:
« Last Edit: October 24, 2015, 03:49:42 AM by Lucky Phil »
1979 10th Anniversary TA
1978 W87 Currently Restoring Rat Rod Style
1959 Aussie Delivered RHD Bel Air
77 Pontiac
Re: Today I...
« Reply #618 on: October 24, 2015, 08:50:54 AM »
Made a mounting bracket for my electronic fuel pump.. going to mount it in front of the fuel tank, so it won't be the first thing hit in an accident like it is at the moment (a previous owner mounted it to the rear bumper brackets many yeas ago)
TA6.6Liter
Re: Today I...
« Reply #619 on: October 24, 2015, 09:08:42 AM »
Replaced the driver's side fog lamp bulb in my 98 WS6. I pretty sure the bulb is the original, so I may as well change the passenger side at the same time, since it will burn out next week :smile:  Nothing is simple on this car with the tight locations and myriad of covers over even the little things, like lights.  The Chilton guide has two photos that begin with unbolting entire lamp housing. The bolt heads are shown, but it is taken from a angle not even visible on my car and zero information on how to actually get to it.  Best I can tell, to remove the fog lamp, would have to remove the front bumper or some other unseen shielding :shock: Fortunately, I was able to squeeze a hand through with the headlights up to get the fog lamp bulb.
Casey
Re: Today I...
« Reply #620 on: October 24, 2015, 12:57:58 PM »
Had someone last night offer an '88 S-10 4x4 and another offer a '71 F-150.  Just now had someone drop by and offer a Suzuki 1500 or an early '00's Mazda truck.  Supposed to have someone dropping by in an hour or two to look at it that I presume is looking to buy with money, but at this point it wouldn't surprise me if he's planning to trade.  I'd understand if I put up a generic, "Would trade" and left it at that but there's no mention of trading in the listing.
Re: Today I...
« Reply #621 on: October 24, 2015, 02:45:44 PM »
You're right those are ghetto looking, I'll take'em off your hands... how does $120 sound?
77 TA man
Re: Today I...
« Reply #622 on: October 24, 2015, 03:15:15 PM »
Today I turned a couple of bolts before I realized I didnt know what I was doing I mean I started taking the nosepiece off my '77 today. Woo-hoo for the winter tear down!
« Last Edit: October 24, 2015, 03:17:08 PM by 77 TA man »
1986 T-Top T/A:
72projectbird
Re: Today I...
« Reply #623 on: October 24, 2015, 03:32:25 PM »
 :lol: They're not ghetto!
I'm strongly considering those Honeycombs you're selling without tires.
70 GTO 455
81 Trans Am Daytona
Re: Today I...
« Reply #624 on: October 24, 2015, 04:02:27 PM »
...cleaned the garage out so now I can actually put 3 cars in a 3 car garage.
77 TA man
Re: Today I...
« Reply #625 on: October 24, 2015, 04:34:09 PM »
Actually I forgot the part about killing a brown recluse in the garage! Makes me want to spend less time in the darker parts of the garage now  :shock:
1986 T-Top T/A:
79merlin
Re: Today I...
« Reply #626 on: October 24, 2015, 06:52:22 PM »
received a copy of "swap LS engines into camaros and firebirds". bought off amazon. Read 3 chapters so far. mostly listing out the differences between the series of LS engines. interesting reading. In skimming forward it looks like it doesn't cover wiring much, but the info it does have seems useful enough.
Scooby doo
Re: Today I...
« Reply #627 on: October 24, 2015, 08:22:26 PM »
Put cab lights on my F250
It seemed like a better idea than raking (blowing) leaves, I can do that tomorrow.
-Jeff
1978 Blue Blackish Firebird Skybird T/Aish http://www.cardomain.com/ride/4021169
1992 Red Trans Am Convertible -Sold http://www.cardomain.com/ride/2913386/1
1999 Black Trans Am Ram Air WS6 -Sold http://www.cardomain.com/ride/3067706
2002 Black Monte Carlo SS http://www.cardomain.com/ride/3385801
2002 Ford F-250 http://www.cardomain.com/ride/4085603/2002-ford-f250-super-duty-crew-cab/
DeCaff2007
Re: Today I...
« Reply #628 on: October 24, 2015, 08:47:00 PM »
Yesterday I... fixed a random misfire on my Camry.  The coil pack on cylinder 6 bit the dust.  Runs great so I decided to tackle the Ebrake problem.  Not a wise idea.  3 hours later I now actually have rear brake hardware and cables...  but I pulled the parking brake lever in the cab and felt something snap AGAIN  :evil: This car isn't meant to have an Ebrake.
77 TA man
Re: Today I...
« Reply #629 on: October 25, 2015, 06:15:55 AM »
I dont know your area Box, but around here that F-150 would be an easier flip than any Firebird especially if the truck is decent body wise.
1986 T-Top T/A:
77 TA man
Re: Today I...
« Reply #630 on: October 25, 2015, 03:32:17 PM »
Damage Report on the great Trans Am Teardown of '15:
-Minor damage on very bottom on radiator core support,
-Bottom rear of driverside fender is rusted through in places
-Found traces of "tailight blue" and red paints on/near marker lights.
-the last core support to bumper bolt i need to take out just keeps spinning w/o loosening. How do I stop this from spinning?
I got all fender to bumper bolts out, almost all of the core suport to bumper bolts, grills and hoodlatch are removed, and bolt locations identified in white grease pen and the removed bolts bagged and tagged.
I Really wanted to get that bumper off but I feel like I got a lot done.
1986 T-Top T/A:
Casey
Re: Today I...
« Reply #631 on: October 25, 2015, 06:46:14 PM »
I despise trucks and SUVs with every fiber of my being though.
Re: Today I...
« Reply #632 on: October 26, 2015, 07:32:03 AM »
Except of course if you ever need to haul or move something, then they're awesome.   :-D
« Last Edit: October 26, 2015, 07:56:42 AM by 76455sd »
DeCaff2007
Re: Today I...
« Reply #633 on: October 26, 2015, 07:35:28 AM »
Ok I have to ask why?
Casey
Re: Today I...
« Reply #634 on: October 26, 2015, 09:00:21 AM »
I also despise vans and sedans, but that wasn't relevant at the moment.  I don't like being high off of the ground or how much they roll and dive.  Some of the 60's and earlier trucks look cool, but outside of that I lump them with the other undesirables.
If I ever had to tow something often that's where the custom Cadillac flower car comes in.
DeCaff2007
Re: Today I...
« Reply #635 on: October 26, 2015, 10:04:57 AM »
Uhmmm...  coupes roll and dive, too.  I agree on the hatred of vans but sedans... well... I drive one and it was free.  Can't complain.
Casey
Re: Today I...
« Reply #636 on: October 26, 2015, 05:16:51 PM »
Nowhere as much though if they're proper sports cars, and once I'm done with them it's nearly nonexistent.  The Celica I had would break traction before you could feel it really start to roll and slamming on the brakes you really didn't dive any either.  I miss that car.
Of course if you adjust your driving to any given vehicle it doesn't pose as much of an issue, but I don't like doing that initially apparently.  I remember the first time driving the Durango I ended up drifting it through an intersection because I was like, "Oh I take this one at 30-35 all the time" and then proceeded to slide the rear of it out as I made the turn. :lol:
« Last Edit: October 26, 2015, 05:18:34 PM by Box »
77 TA man
Re: Today I...
« Reply #637 on: October 26, 2015, 05:25:08 PM »
Trucks have their purpose, as daily drivers? No.
I switch vehicles a lot, one day I'm driving the '07 1500 and the next I'm out in the '99 1500 and then Im in the S10 or the VW. Thats what gets me the most, when I'm used to driving one I have to switch.
Back to the '77....
So I got 2 of the 4 headlight bezels off and all screws but 1 stuck screw on each on the other bezels. I got the inside pass. Side bezel off and the headlight pops out! Not even connected just put in! I think new bezel screws and headlight bucket screws are in order because I found a lot of already stripped out screws.
« Last Edit: October 26, 2015, 06:03:48 PM by 77 TA man »
1986 T-Top T/A:
Casey
Re: Today I...
« Reply #638 on: October 26, 2015, 08:49:30 PM »
Well, the Accord Coupe guy is supposed to be here tomorrow around five so I can look at the Accord while he looks at the Firebird.  So far I know it has about 160K miles, 158K something on the clock but the speedo sensor went out a few weeks ago.  Says A/C works well and has new tires, just needs the speedo sensor replaced which is like $60 off RockAuto.  If anything being willing to drive it 80+ miles here and back twice shows at least it should be a fairly solid car.
ThKidd
Re: Today I...
« Reply #639 on: October 27, 2015, 07:53:27 AM »
Previously I had painted most of the interior pieces from my car, and then used the SEM Low-Lustre Clear Coat over it, but I didn't like the results at all.  It seemed "dusty", and the surface was rougher, and the scratches in the plastics seemed to be accentuated more by the clear coat.  I decided just to go with the color coat and be done with it.
This past weekend I repainted those pieces with the color coat.  I originally used the SEM preps and paints, but ran out before I was finished, and switched over to some OER paints for the second coat.  I didn't have very good results with the OER; it seemed to spray in a more narrow pattern, and as a result it left visible stripes.  I went to a local O'Reilly's, as they carry SEM paints, and bought another can to cover the OER paint, and the results were much better.
1977 PHS-documented SE black-on-black (work in progress, ok, not much progress)
Re: Today I...
