well today i, got my engine tore back down. installed new rear main seal, new distributor, new oil pan, crank pulley, water pump, lifters, pushrods, put the engine back together, freshened up the paint a bit, put that on hold, took of drivers side fender. stripped down the subframe and core support, got it in primer and semi gloss black paint. the subframe is getting a ruberized undercoat spray (using a wagner electric sprayer). got my new brake booster assy. re wired some of the wiring harness. cleaned up my starter, started stripping down the fire wall. figured out i had a fender mounted antenna at one point. took out the saginaw and cleaned it up. blasted and sprayed my tie rods and pitman arm. setup a job interview! and now i think its time for a break!
