Author Topic: Today I...  (Read 855620 times)
Re: Today I...
« Reply #8440 on: November 30, 2019, 07:50:55 PM »
Today I bought 2 BRAND NEW 1996 Ski Doo snowmobiles. Under 200 miles on them. Had to drive 250 miles to pick them up but they were almost free they were so cheap.  They were a client of mines. He and his wife bought them new and only rode them a few times. He fogged them, drained the carbs and put stabil in them (which didn't help the 22 year gas... They were stored in a climate controlled room on the house. One was on its original pallet/crate.
Re: Today I...
« Reply #8441 on: December 01, 2019, 08:58:47 AM »
Never been on one, we don't get enough snow to run them, sounds like a good opportunity for a quick flip with our friends up north, eh!
Re: Today I...
« Reply #8442 on: December 01, 2019, 11:42:37 AM »
I have always had one but they are really old, like 1974... we can usually run them pretty much every year.  The kids will love them. But... if I was smart, I would flip them. I could more than double my money.  I may try to trade off the big one for a quad.
« Last Edit: December 01, 2019, 04:07:48 PM by FormTA »
Re: Today I...
« Reply #8443 on: December 01, 2019, 01:53:13 PM »
Wow...those are in amazing shape...makes mine look wore out!!
DeCaff2007
Re: Today I...
« Reply #8444 on: December 01, 2019, 09:19:53 PM »
I thought those were watercraft at first.  Never been on one, either.  Although....  I like the green one just because it says "SUMMIT" on it.
Re: Today I...
Re: Today I...
« Reply #8445 on: December 04, 2019, 08:09:34 AM »
Got the red one running.  Cleaned the tank and removed and cleaned the carbs. I ordered a new primer as the seals were all dried out and it leaks fuel everywhere.
Now, the green one has issues.  The fuel has eaten all of the lines inside the tank and all of the grommets the lines run through.  Also the sludge inside the tank is like roof cement and red tacky grease.... I finally got the tank cleaned up after a bunch of rinses with large bolts thrown in to help break things up. I finally poured sea foam straight in and let that sit for a few minutes.  That stuff really loosened up the junk in there.
Now I will have see what the carbs look like on that one. Not good I'm assuming... Below is the red one pictures.
Before, main jet gummed up.
Floats gummed up, won't float..
Clean.
Re: Today I...
« Reply #8446 on: December 04, 2019, 11:46:19 AM »
Turned out nice. Good thing you have the knowledge to take things apart, most people would've most likely put gas and tried to start, then wonder why they wouldn't run!
Y88 TA
Re: Today I...
« Reply #8447 on: December 04, 2019, 11:57:49 AM »
Formta make sure you clean the pilot jet also. It is down the hole beside the main jet. It screws out with a flat screwdriver. Any crud in it will cause it to run lean and burn a hole in a piston.
Re: Today I...
« Reply #8448 on: December 04, 2019, 01:37:52 PM »
Thanks. I'm pretty sure I got them as I cleaned every little hole and passage way but it's easy to pull them so I'll double check.  Thanks for the heads up!
Y88 TA
Re: Today I...
« Reply #8449 on: December 04, 2019, 03:41:49 PM »
No problem, just wanted to make sure you were aware of the consequences of a partially clogged pilot jet.
Re: Today I...
Re: Today I...
« Reply #8450 on: December 06, 2019, 07:39:53 AM »
I got a score of a bunch of motor parts that I want to resell figure I will start here first but my darn flickr wont let me download pics, I had the problem once before and it seemed to fix itself. Anyway, I guess I will sort through the stuff and give descriptions.
  • Parts vender
      • Scarebird Classic Brakes
Re: Today I...
« Reply #8451 on: December 07, 2019, 01:21:43 AM »
Re: Today I...
« Reply #8452 on: December 07, 2019, 01:38:32 AM »
Scrubbed the bottom of the 71
build post:  http://forums.maxperformanceinc.com/forums/showthread.php?t=835404
I know how you feel, been doing a lot of under body scrubbing as well!
1970 Firebird
Re: Today I...
« Reply #8453 on: December 07, 2019, 08:06:09 AM »
I read the thread on PY. I'm too lazy to take apart a car that looked so good (even if there were hidden things). I know the amount of work it takes to take them apart and put them back together.
Great work, it will be one really nice car.
« Last Edit: December 09, 2019, 11:45:16 AM by FormTA »
  • Parts vender
Re: Today I...
« Reply #8454 on: December 07, 2019, 01:17:43 PM »
The more tedious part of these restos.   I like how your Lemans tuned out.
I found the parts to the pressure washer, it won't start of course.  Kim has not run it in 3 years - I will buy some ether and give it a squirt but I think it needs some love at the Honda repair shop.
Re: Today I...
DeCaff2007
Re: Today I...
« Reply #8455 on: December 07, 2019, 10:14:24 PM »
Which reminds me, I should start mine up.  It hasn't been run since the temps were warm this year.
  • Parts vender
Re: Today I...
« Reply #8456 on: December 08, 2019, 12:30:41 AM »
Ether got it to run for a few seconds, so I pulled off the carb and blew WD40 (all I had nozzled) thru it and now runs - though not great.
Hopefully fresh gas will solve it completely.
Re: Today I...
« Reply #8457 on: December 08, 2019, 12:31:30 AM »
I should say I’ve been doing a lot of scraping dirt and grime. I’m just trying to get as much dirt off before I power wash it because I don’t want the dirt to become mud .
1970 Firebird
DeCaff2007
Re: Today I...
« Reply #8458 on: December 08, 2019, 07:17:29 AM »
The other day, we hosted an Xmas party.  I got tired of people very quickly, so I snuck in the garage and fired up the TA.  A buddy came out and said "Dang that's running rich!"
I was disappointed to hear that.  I had thought it ran fine....
Re: Today I...
« Reply #8459 on: December 08, 2019, 07:59:06 AM »
If I still had a carburated engine I would install O2 sensors so I could tell where it was at and adjust.  But I gave up and went EFI.
Re: Today I...
Re: Today I...
« Reply #8460 on: December 09, 2019, 08:03:09 AM »
2019-12-07_12-27-22 by Kerry Grubb, on Flickr
Amish F-150!
Y88 TA
Re: Today I...
« Reply #8461 on: December 09, 2019, 08:46:10 AM »
Wow........... At least they have a slow moving vehicle sign on the back.
Re: Today I...
« Reply #8462 on: December 09, 2019, 09:05:39 AM »
Yea, and they all run lights now also. Pic was taken in Quarryville PA, buggies about equal cars on the road.
Re: Today I...
« Reply #8463 on: December 09, 2019, 12:33:18 PM »
My son was out to help me move this from the garage, back out too the sea can. I will put this rusty block in a barrel and fill it with diesel to remain stored until I decide what I want to do with it.
20191207_111916 by Charles Marson, on Flickr
I also came across a few more pictures of "The Project" while I was looking for my restoration manual that I have on disc.
20191209_081017 by Charles Marson, on Flickr
20191209_081356 by Charles Marson, on Flickr
20191209_081138 by Charles Marson, on Flickr
Re: Today I...
« Reply #8464 on: December 10, 2019, 04:33:37 AM »
It's nice to spend time like that with your son. Even if they are not entirely interested. It's time well spent. I love the old car photos.
Re: Today I...
« Reply #8465 on: December 10, 2019, 09:50:50 AM »
X2 enjoy it while he is still interested.
Re: Today I...
« Reply #8466 on: December 10, 2019, 11:20:11 AM »
My son (28yo) has very little to no interest in cars, he is big into guitar collecting and playing. I have custody of my 7yo grandson (my daughters child) that loves cars right now. He has claimed the TATA im restoring as 'his car'. He will come out in the shop with me, and when I go out by myself he will ask if I am working on his car. I started to watch garage squad last night and he wouldn't let me change the channel. He watched the entire episode. It was funny when they struggled with a part on the show he told me to pay attention so I wouldn't have the same problem when I was fixing 'his car'.
nas t eh
Re: Today I...
« Reply #8467 on: December 10, 2019, 09:02:23 PM »
lol
current
73 T/A 4speed
past birds
75 T/A 455 4speed
75 T/A 400 4speed
DeCaff2007
Re: Today I...
« Reply #8468 on: December 10, 2019, 09:03:22 PM »
What...
Re: Today I...
« Reply #8469 on: December 10, 2019, 10:52:42 PM »
My son has also laid claim to the Firebird...i need to be careful he hasn't already plotted my death to get it sooner...He is on board with my ideas and we discuss what to do with the car often. He has been brainwashed since birth that these cars are the best!!
Re: Today I...
Re: Today I...
« Reply #8470 on: December 11, 2019, 08:20:37 AM »
Sounds like a good thing to brainwash with..
My 7 y.o. loves electronic stuff, computers pads etc. He loves Teslas because they have a big screen in the middle of the dash. He has already pointed out to me how he wants the dash of the Trans Am to be laid out with the touch screen as well as multiple chargers throughout the car,
Re: Today I...
« Reply #8471 on: December 11, 2019, 07:36:03 PM »
That's awesome!!
DeCaff2007
Re: Today I...
« Reply #8472 on: December 12, 2019, 10:17:01 PM »
My Dad has been mentioning for a while now that he wants new headlights on his 03 Focus.  The originals are complete junk, so, Today I... bought him an early xmas present and installed them lol.
Pics do not do the new lights any justice.  Holy CRAP what a difference!
Re: Today I...
« Reply #8473 on: December 12, 2019, 10:24:21 PM »
It makes a big difference. I did the same on my previous truck which was a 2001 GMC 4x4 pickup. So much nicer driving at night.
Re: Today I...
« Reply #8474 on: December 12, 2019, 10:39:26 PM »
So today I continued with a job I started on Tuesday with my 93 Exciter 570 St/Lt snowmobile. I took apart the skis and corresponding linkage to the steering components so that i could put new bushings and bolts in and make it safe to drive. While I was waiting for parts my dad had picked up for me, I went through his stainless selection of screws and found what I needed to put the windshield back on after I get it painted black.
After the parts came in, well most of them, I put the skis back on and decided to address the fact that the machines starter wasn't working properly. I took all kinds of things apart, trying to follow wires and see if there was a short in circuit and it now looks like a grenade went off near it. All that work went into taking it apart just to find out that there is no starting solenoid on the machine anywhere. Had I realized that at the beginning, I wouldn't have had to take much apart. On the plus side, all the wiring looked in good shape. Next session is to put everything back together, instal a solenoid and see if it will fire up with the key!! Sadly, I didn't take any pictures as I didn't think there would be much interest. If I'm wrong, I'll take some its current status on Monday when I go back out!
gm muscle
  • Down but not out!
Re: Today I...
« Reply #8475 on: December 14, 2019, 09:55:17 PM »
Do they make them in glass? I did that recently with my 1997 Chevrolet Silverado. It was the single best mod. I made on my pickup.
Gene-73
Re: Today I...
« Reply #8476 on: December 15, 2019, 08:03:58 PM »
Today Santa came early and dropped off a 4 post lift for me!
I've been wanting one of these for a long time and my wife finally gets her parking space back inside the garage, so everyone is happy!
The bird gets the top perch until spring since it's too cold right now for body work.
Gene
Re: Today I...
« Reply #8477 on: December 15, 2019, 09:13:40 PM »
I'm not sure to be honest. I had never looked
Re: Today I...
« Reply #8478 on: December 15, 2019, 09:15:21 PM »
that's awesome. I anxiously await the hoist we end up getting. I anxiously await for the money to manifest itself to pay for it too...lol
Re: Today I...
« Reply #8479 on: December 16, 2019, 08:26:13 AM »
Looks like Santa was pretty good to you Gene! I would love to have a 4 post, not sure I would trust my wife parking under it though, I could see her hitting a post on the way in!
Re: Today I...
