Author Topic: hood/fender alignment help  (Read 3833 times)
Ledesordre
« on: January 20, 2014, 02:36:38 PM »
I know this has been asked a million times, and I've read other threads on it, but please help me based on the picture I am providing, rather than past questions.
I just bought this car recently.
Does it look like my driver side fender needs to come down a bit? Or just a hood hinge adjustment?
You can see the hood is slightly not aligned on the back end of it on the driver's side, and the trim pieces are a bit off as well. I am trying to correct that.
http://i.imgur.com/NAOheJL.png
« Last Edit: January 20, 2014, 02:43:15 PM by ledesordre »
'76 Trans Am  - LS1/T56
'98 Firebird - LS6/A4 + Turbo
2008 Corvette - M6
78 455 HO
Re: hood/fender alignment help
« Reply #1 on: January 20, 2014, 02:41:02 PM »
It look's like the door needs to come up a bit, the gap between the door and the A pillar should be smaller
« Reply #2 on: January 20, 2014, 02:42:08 PM »
The hood hinge can be adjusted up or down, I would start by adjusting it down which will pull down the hood.
Ledesordre
« Reply #3 on: January 20, 2014, 02:43:47 PM »
Thanks, I'll look into that as well.
2008 Corvette - M6
Black Sheep
« Reply #4 on: January 20, 2014, 03:23:52 PM »
Just by going off that pic, there is a whole lotta wrong going on there.  If you look at the reflection of light on the door, it looks like the front corner of the door (between mirror and fender) is bent in.  Also the hood looks bent, like the hinges were frozen and someone tried to muscle the hood down.  How is the gap, door to rocker, front to back?  Even all the way or at an angle, front to back?
Like I said, could be the pic.  More pics from different angles would help.
455 Olds/Th350,3.90
11.05
121 mph
1.46 60'
3125lbs.
silver78
« Reply #5 on: January 20, 2014, 08:45:04 PM »
I agree the hood looks like it was bent at the hinges.  You do need to start with the door properly aligned with the rear qrtr panel and rocker, then align the fender.
Previous builds:
65 Galaxie sold
67 camaro RS sold
68 camaro RS sold
69 camaro sold
72 Nova SS
81 T/A 4 spd sold
86 IROC sold
88 Formula 350 sold
92 Z-28 sold
93 9C1 Caprice sold
94 Impala SS sold
Ledesordre
« Reply #6 on: January 21, 2014, 08:27:29 AM »
darn, that's no good. Sounds like it's going to be a pain to correct these issues.
2008 Corvette - M6
Ledesordre
« Reply #7 on: January 22, 2014, 11:34:07 AM »
Does anyone have a guide on how to adjust some of these body panels for someone who is new to these cars?
2008 Corvette - M6
78 455 HO
« Reply #8 on: January 22, 2014, 12:41:19 PM »
If you are going to dive into this project, make sure you replace the door hinges or rebuild them. The only other advice I can give is take your time, because that is what it takes.
Doug
« Reply #9 on: January 22, 2014, 03:07:05 PM »
I'd get a body shop to adjust it if you are not really comfortable doing so.  I had one guy straighten out a hood a while back that was bent by poor hinges. He put a two by four under the front running side to side, put a long 6x6 block of wood on top, running front to back over the hood frame rails and beat it with a sledge hammer.  Darn if it didn't fit like a glove when he was done with it and required no filler!  Of course we used some new hinges after that as well.  Watching him do that made me cringe.  I figured that was one destroyed hood but the guy obviously had been there done that before.  In the end, he ended up saving us some good money.
« Last Edit: January 22, 2014, 03:15:29 PM by Doug »
Black Sheep
« Reply #10 on: January 22, 2014, 04:50:51 PM »
That's why I never let people watch me work on their cars :lol:  Had one guy about have a stroke when he saw his car with the door, fender, and hood off, and I was "only" supposed to straighten the quarter :lol:  Hey, everything has to line up :lol:
He was happy in the end 8)
455 Olds/Th350,3.90
11.05
121 mph
1.46 60'
3125lbs.
Ledesordre
« Reply #11 on: January 24, 2014, 12:43:52 PM »
You can come do mine too :)
2008 Corvette - M6
