2020-B1-7
Author Topic: 2 Firebird Esprit T/A Clones become ONE Formula Clone correction, Esprit!  (Read 12990 times)
mark369
 Unfortunately this complete 77 Esprit was total RUST !
Making it a "roller"
Interior looks nice.
Never Had a Lug Nut rust in half like this before.
Engine was said to be "good"
Check out the high tech shaker mount.
Kept the 231 Buick V6 out of it.
Firewall only rusted on bottom.
Engine after pressure wash.
Prepping the good sub frame.
And all Por15
Engine painted and going in good sub frame. Started engine to make sure it ran before swapping.
Issues found in "good" car.
Explains why the front end is red under blue/green and the shell is light blue under blue/green.
The Fix.
Remove cowel end.
"This car is on FIRE!!!!!!
Broken shock bolts.
Got a hood.
found a spare set of Keys.
Not going together correctly.
Better!
« Last Edit: February 04, 2014, 11:19:53 AM by mark369 »
Re: 2 Firebird Esprit T/A Clones become ONE Formula Clone
« Reply #1 on: December 06, 2012, 10:51:27 AM »
Man, that first formula is rough!!
mark369
« Reply #2 on: December 06, 2012, 05:06:38 PM »
 The 77, Yea I took the carpet out and the door sills and roof where all that was holding it together.   The other car that I did not get a photo of before I started is a 80 that had a Chevy 350 with trans removed from it before I got it as a roller. Originally got it just for the 78 front end that was on it. It sat in my back yard for 15yr. They are or where both T/A clones.  I came across a formula hood cheap and was making the car for winter and the formula hood has no hole in it (shaker) to let snow and ice collect in. I put a 79-81 nose back on it. will keep the 77 door panels in it. It is sort of nice compared to the other project that needed almost everything redone. I am going to paint this one Martenique blue. Not light blue as original. Running is first objective on both projects.
Photo shows 80 bird on right in back of shell. nose for it came off one on left.
Ben
« Reply #3 on: December 06, 2012, 08:10:44 PM »
Wow is that rotten... nice work!  What's the plan with the result?
Home of the Mess
mark369
« Reply #4 on: December 07, 2012, 06:54:01 AM »
 It will be a daily driver for winter.
mark369
« Reply #5 on: May 23, 2013, 11:45:27 AM »
 Am at the point it is ready to start. I want it running before I start finish body work for repaint.  Have a few electrical issues to work out yet.  Horn blows when I turn on the lights!   Spits and wants to start with gas poured in the carb. Trying to get gas line off carb to check for gas flow.
« Reply #6 on: May 24, 2013, 03:22:57 AM »
Interesting...looks like you have an earlier model rad support in it? Seems like it fits OK.  :-D
« Reply #7 on: May 24, 2013, 04:50:26 AM »
Nice job, most would have passed on that clone. Can't wait to see some more progress.
mark369
« Reply #8 on: November 23, 2013, 04:01:37 PM »
It will start on its own, but have not worked on getting it to idle. It looks mean in the front end. It sits up so high. have v8 springs and only a 6cyl.  will get a photo soon. Got the steering pump line issue worked out.  Involved in another project. Got to learn to say "No", but the price was real good.
72blackbird
« Reply #9 on: November 24, 2013, 04:39:01 PM »
Mark,
My compliments to you for bringing another 2nd gen Firebirdback from the dead, even if it's only in parts. A running Firebird, even with a V-6, is better than no engine at all.
Geno
1977 SE T/A (sold :( )
1974 455 T/A (sold :( )
1972 Esprit restomod
1976 T/A restomod
mark369
« Reply #10 on: November 25, 2013, 08:17:49 AM »
Thanks. I am leaning more towards putting it back to stock Esprit looks. They seam to be harder to find.
mark369
« Reply #11 on: November 29, 2013, 07:26:51 AM »
 Stands real tall with a 6cyl on v8 springs.
IM002171 by [url=http://www.flickr.com
pancho400cid
  • Viva los PONCHOS!
« Reply #12 on: November 29, 2013, 11:48:39 AM »
Thanks dude.... I foresee rust in my nightmares after looking through this.
Looks like you're winning though.  Keep it up... that stuff never sleeps you know....
Power to ya!
nocturneTA
« Reply #13 on: December 01, 2013, 08:28:28 PM »
Man, I gotta give ya props for taking on a project like that!   I look forward to seeing the end result.
LS1 / 6SPD /  3.90 gears / C-5 Brake kit   Etc...
mark369
« Reply #14 on: December 01, 2013, 09:41:50 PM »
Thanks, working with what I can afford as I find it . Originally got car just for the 78 front end nose that was on it. Kind of cool to run across parts to turn it back towards original!
PMANN
« Reply #15 on: December 01, 2013, 10:11:39 PM »
Is this a restoration or an autopsy?
Seriously, you are energetic and ambitious.  Nice work.
mark369
« Reply #16 on: December 02, 2013, 02:52:33 PM »
 Autopsy was the 1/2 shell replacement.
80 T/A under 1/2 shell replacement in projects
http://transamcountry.com/community/index.php?topic=49370.0
« Last Edit: December 02, 2013, 02:54:48 PM by mark369 »
IFLYBY
« Reply #17 on: December 22, 2013, 09:51:21 AM »
Following this thread...is it driveable? How about a pic of the finished product?
Everything is a car , was a car , or will be a car . 79 W 72 T/A--05 GTO--69 GTO Judge ( very , very sick )
mark369
« Reply #18 on: December 22, 2013, 10:38:46 PM »
 It runs but does not Idle on own. Brakes work but need more work. Plan to do body paint prep work this spring. It got stuck in a holding pattern.  :sad:
