Author Topic: DOUG NASH 4+1 TRANSMISSION??????????  (Read 3748 times)
JupiterBandit
  • Guest
« on: September 26, 2012, 08:21:50 PM »
Anyone ever here of this as an option in a 1977 Y82?
Re: DOUG NASH 4+1 TRANSMISSION??????????
« Reply #1 on: September 27, 2012, 07:03:05 AM »
I am pretty sure that wasn't a factory option, but was something that Herb Adams offered aftermarket.
richduty455
  • Trans Am isn't just a car, its a way of life!
« Reply #2 on: September 27, 2012, 07:40:22 AM »
not a factory option....but my 80 has one in it.....its a cool trans......super low first gear abnd heavy duty, supposed to be able to handle 600hp, not sure about that but i will tell you its the heaviest stick box I've ever picked up!!
Our Current Birds:
70 Ram Air III auto
71 455 HO T/A auto white (pop's 1st car)
71 455 HO t/a auto blue (pop's)
71 formula 455 HO auto (little bros)
73 SD 455 auto
74 SD 455 auto (pop's)
77 T/A
78 Y88 ws6, w72 4speed 79k
79 TATA 400 4spd 38k orig (pop's)
79 trans am 350
80 y84 455HO doug nash 5 spd
80 T/A 400 pont auto
84 L69 auto areo T/A
94 firebird 3.4 t-top daily
97 WS6 lt1 au
  • TAC Webmaster
« Reply #3 on: September 27, 2012, 08:20:48 AM »
As said, it was an available over the counter tranny.  VSE and TA Specialties used them a lot.
fiream773
« Reply #4 on: September 27, 2012, 08:38:55 AM »
I replaced the broken T-10 in my '77 with one (now called a Richmond 5 speed).  I've been very happy with it.
The Doug Nash 4+1 was specifically designed to replace automatics and make use of their numerically lower rear gear ratios to improve performance and fuel efficiency.  My '77 had a 3.23 which was almost too steep for the 3.27 1st gear of the 5-speed.  I swapped in a set of 2.73's & the car drives just like stock, but with the 2.73, I run 2,500 rpm at 70 instead of 3,100, which bumped hwy mileage from 15 to over 18.  Doesn't sound like much, but it's over a 20% improvement which makes a huge difference at $4.00/gallon.
To answer your question directly, no 5-speed transmission was ever available from the factory in any 2nd gen...
Life is short - Drive sideways.
