2020-B4-2
Author Topic: Door Glass Adjustments  (Read 26573 times)
« on: June 22, 2012, 07:39:39 AM »
This is the only part of the Fisher body manual that is really good:
http://transamcountry.com/site/wp-content/uploads/2011/03/GM_Window_Adjustment_Guide.pdf
Re: Door Glass Adjustments
« Reply #1 on: June 23, 2012, 06:01:36 AM »
Without the Fisher Body Manual, I would have had a hard time assembling and adjusting the door glass.....its counter intuitive in assembly and adjustment sequences.
Great manual to have a copy of.
jeff425
  • 77/w72
« Reply #2 on: December 02, 2012, 11:53:21 AM »
I know this thread is a few months old but, would this be the same for adjusting the windows on a 77 with hurst hatch?  Thanks..
« Reply #3 on: December 02, 2012, 10:17:53 PM »
Yes, the hatch seal should be in the same location as the normal roof line seal.
1979SE
« Reply #4 on: January 18, 2013, 02:20:39 PM »
Excellent resource, thank you for posting this.  Was having trouble getting my power windows to go all the way up -
Joseph
1979 Trans Am (Sold - Stupid)
1982 Trans Am (Sold - Thank goodness!)
1979 Trans Am SE (Baby!)
71steve
« Reply #5 on: September 26, 2013, 11:53:34 AM »
Does the outer window sweep go on befor or after the glass is in place? Also would you install locks and outer handles before or after the glass?
Tnx
« Last Edit: September 26, 2013, 11:55:12 AM by 71steve »
ILLTA77
« Reply #6 on: September 26, 2013, 12:31:24 PM »
They are all easier to install before the glass goes in, but you can remove the lower stop and then drop the glass the rest of the way to gain access.
Farmer2
« Reply #7 on: February 23, 2015, 06:06:17 AM »
Does anyone have pictures of how the glass then sits on the weather strip once all is adjusted? I think i have the pass side dialed in but the drivers side I can not get the front edge to stop diving its top inward so far. Its hard to crank the handle. Any pics and Ideas would be great.
"We are what we repeatedly do. Excellence then is not an act, but a habit.”
VA79ta
« Reply #8 on: March 16, 2015, 08:15:30 AM »
Short of finding any other appropriate thread, I figured getting the tip here would help others.  I am replacing the rollers that are attached to the glass.  How do you remove the flat, threaded retainers holding the roller stud parts?
« Reply #9 on: March 16, 2015, 11:42:24 AM »
Do you mean the sides that have the two holes? Special tool:
http://www.amazon.com/The-Parts-Place-Window-Roller/dp/B00H87MFE2
VA79ta
« Reply #10 on: March 16, 2015, 11:55:22 AM »
Yes....Sheesh another tool to buy.
« Reply #11 on: March 17, 2015, 03:13:33 AM »
Take an old impact socket and grind it to look like this. I make tools, not buy.
« Reply #12 on: April 14, 2015, 07:30:23 PM »
Good one, grind a piece of hollow pipe if you get stuck. Drill hole through it for tightening with screwdriver!
1979 Black and Tan
  • '79 in Sunny San Diego
« Reply #13 on: July 16, 2015, 03:29:43 PM »
I followed these instructions and did a fairly good job of adjusting my windows this weekend ....I think you just have to keep at it until you get the best fit...I think I can move it back an additional 1/8 inch...but i'll leave it where it is for now
Thanks for the instructions
1979 Trans Am
100% California Car, originally Atlantis Blue/ Black...All Original Unmolested 403, TH350, 2.41
63,300 orig. miles
1971 Chevy K20 4x4
« Reply #14 on: February 20, 2016, 04:32:02 PM »
I fooled with my pass side for a couple hours until I got frustrated and packed up for the day. I have the assembly manual, and I have read through this thread. The problem I am having is the front of the window when all the way up is too far into the car. When up, the top of the window needs to push towards the outside. I think I have tried adjusting everything every which way I can and I cant seem to get it right. Can anyone who has done this give me a bit of insight. I don't want to sound rude but Don't tell me to read the directions. I have, and think I am following them but to no avail. HELP!!!!
DeweyOx
« Reply #15 on: March 02, 2016, 10:25:24 PM »
I feel your pain. One of the few small things left to do and for this very reason, I'm dreading it. Probably have my T/A Mechanic do it. AND That goes for the headliner as well. :lol:
1979 Black and Tan
« Reply #16 on: March 04, 2016, 01:27:24 PM »
Then when you loosen up bolts to adjust the glass ..you tend to get rattles in the glass frame ...
i finally got mine down to where I like it...but I have rattles inside the door now ..so it is all going to have to come apart again ..just to find the out what is loose and what is rattling around inside the door when I hit bumps
it is very frustrating
1979 Trans Am
63,300 orig. miles
1971 Chevy K20 4x4
Farmer2
« Reply #17 on: March 04, 2016, 02:56:47 PM »
I did get mine where it sealed nice but the drivers side window rolls up hard once I am 1/4 from closed. Can not seem to get the tracking right on the weather strip. Yes it is fustrating!
