May 18, 2013, 05:12:48 AM *
Author Topic: X7 block in a junkyard  (Read 1126 times)
77Bullet
Guest
« on: June 12, 2012, 02:54:44 PM »
Stopped at a junkyard today to see if I could find a few miscellaneous items for my TA and came across four birds that the vultures have pretty much stripped.  I couldn't find anything useful to me but one of the TA's had a complete block and Q-jet sitting on top.  The block is stamped X7 in the correct location but I was confused because the valve covers are painted.  I thought if this is a W72 block the valve covers would be chromed.  Of course someone could have kept the valve covers and put on a pair of painted covers.  I don't need another engine but someone might be interested.  There was also a pretty decent '78 shaker hood.  I hate to see these items sit and rot.
The junkyard is in GA.  PM me if you are interested in checking it out and I'll pass along the info.
Russ C
« Reply #1 on: June 12, 2012, 04:14:55 PM »
I would check the date code on the block,Pontiac used that code on 350,400 and 455.
1970 350 255 HP X7 A           8.8 254 11 1-2 7028062 Block Casting 9799916
1973 455 215/250 HP X7 A    8.0 067 4X 1-4 7043272 Block Casting # 485428
1976 400 185 HP (Late) X7 A 7.6 066 6S 1-4 17056564 Block Casting # 500557
1978 400 220 HP X7 A           8.1 402 6X 1-4 17058266 FB W72 Block Casting # XX481988
1972 Ventura II
11.67 @118 mph with a 3.23 single track rear end.
79ws6
#'s Matching-
« Reply #2 on: June 15, 2012, 02:59:25 PM »
what part of Georgia ??
79 W72-WS6
77Bullet
Guest
« Reply #3 on: June 16, 2012, 04:33:26 PM »
South GA
