Author Topic: "key" style stud for stud welders / dent pulling  (Read 2060 times)
T_MAC
« on: June 04, 2012, 07:43:41 PM »
I was watching a show on Velocity (Wheeler Dealers).  One of the Mechs pulled a dent with a unique pulling system.  I saw the word "Flatliner" on the tool stand and it looks like it might be a European system.  He fixed a series of studs along the dent and then slipped a rod through the holes in the studs and then levered on the rod thereby picking up many of the studs and spreading the load out.  The studs were not pins but "keys" that welded on just like normal studs (see my 2 cent drawing below).  I was wondering if anyone knew where to get just the ''key" style studs?  Thanks if you do.
Re: "key" style stud for stud welders / dent pulling
« Reply #1 on: June 05, 2012, 04:17:24 AM »
Can't help on the name.....but my panel shop pulled a dent out of my rocker panel with one of those units...very handy. If they hadn't had that unit, they'd have had to cut a section out of the rocker.
T_MAC
« Reply #2 on: June 05, 2012, 07:15:33 PM »
Thanks. I will keep digging on the web (or make some one day).
MD79TA
« Reply #3 on: July 03, 2012, 06:05:37 PM »
saw the same shows. Never seen it before sure look like it did a nice job
1979 Trans Am
307 RWHP 380RWTQ / 13.8@103
1979 400 Block, 1970 Heads, Cams, Comp Cam Lifters, Edelbrock RPM Intake, Hedman Headers, Holley 750 Carb, WFO Drop Base
1968 GTO convertible
400 auto with A/C
